This is the official thread to discuss the Roban 120mm A-10 Warthog EDF Jet. Product page: https://www.motionrc.com/collections...mm-edf-jet-arf
A-10 Warthog Arctic Camo 120mm EDF Jet from Roban - Composite ARF - RBN-A10SC
Version Info: This is the V2 version of the Roban A-10 Thunderbolt II. The V2 addresses known issues from the V1 version such as gear and wing strength. This V2 now comes with a steel landing gear pin and improved wing design and construction for higher strength and durability.
Roban isn't just known for outstanding quality, scale helicopters. They also manufacturer impressive airplanes with the same level of scale detail, quality and precision you can count on.
The tradition continues with the impressive Roban A-10 Warthog. This 82" wingspan A-10 is a full composite construction model ARF which comes with electric retracts, scale oleo struts and wheels. The highly detailed cockpit is lighted and ready to install. Scale details include raised rivets and recessed panel lines complete the striking scale appeal of this A-10.
The front of the fuselage is removable for easy access to your chosen batteries. The bomb bay door section is removable and can be made operational with slight modifications. The Roban A-10 Warthog is impressive and ready to impress at your local flying field!
FEATURES:
AGE LEVEL : 18 AND UP
SKILL LEVEL : ADVANCED
BUILD TIME : 6+ HOURS
FEATURES:
- NEW! V2 landing gear (scale oleo struts, aluminum/rubber wheels and included electric retracts)
- NEW! V2 Improved wing design and construction for higher strength and durability
- NEW! V2 Improved landing gear steel pin (no longer aluminum)
- Full composite construction with highly detailed surfaces
- Scale details such as raised rivets and recessed panel lines
- Highly detailed lighted cockpit that is assembled and ready for install
- Painted livery in the Arctic Aggressor scheme
- The bomb bay door section is removable and can be made operational with slight modification
- Removable front for easy access to batteries
- Painted and ready to assemble
- Roban A-10 Warthog V2 Arctic Camo 120mm EDF Jet - ARF
- V2 Scale aluminum/rubber wheels
- V2 Scale oleo struts
- V2 Electric retracts
- 6+ Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6+ Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- TWO 120mm EDF Units with motor
- TWO 120 Amp Brushless ESCs - we recommend TWO ZTW Gecko 120A ESC OPTO High Voltage Brushless ESC
- 20 Amp UBEC - we recommend Castle Creations 20A BEC Pro
- 9x high torque metal 40g servos - (recommendation coming soon)
- For 12S setup - we recommend TWO Admiral Pro 6000mAh 6S 22.2V 50C LiPo Battery with EC5 Connector Multi-Pack (2 Batteries) for 4 total packs
- 2 to 1 EC5 series adapter - we recommend Admiral EC5 2 to 1 Series Adapter
- 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
| Model Scale | 1/8.5 |
| Wingspan | 2060mm / 81.1in |
| Length | 1905mm / 75in |
| Weight | 11000g / 388.01oz |
| CG (Center of Gravity) | 95.25mm (3.75in) From leading edge at the wing root |
| Power System | 2x 12S Brushless Inrunner (required) |
| Electronic Speed Control | 2x 120A (required) |
| Propeller / EDF | 2x 120mm EDF (required) |
| Servos | 9x 40g metal gear standard (required) |
| Landing Gear | Electric retractable tri-gear (included) |
| Required Battery | 4x 6 Cell 22.2V 4000 - 6000mAh LiPo batteries (required) |
| Required Radio | 6+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | Yes |
| Hinge Type | Nylon |
| Material | Composite |
| Skill Level | Advanced/Expert |
| Build Time | 6+ Hours |
