Originally posted by Aros
View Post
Official FlightLine 850mm P-51D Mustang Thread
It should be fine. If you are worried, spray several very thin coats. In any case, don't attempt to get the color in a single coat with pretty much any spray paint.
It's pretty awesome that you picked this P-51 scheme. My grandpa was the Crew Chief on this exact plane on Iwo Jima. He always spoke very higly of both of the pilots assigned to this plane, Darrell Bash and Ed Linfante.
Any enamel spray will work great. It's all I ever have used over many years.
I got myself one. Was wondering if i can use tamiya ts spray paint on it. Anyone knows?
Hey Jake, I fly with Admiral 3S 2200s (35C) and get about 8 minutes at 1/2 to 3/4 throttle. She is fun to fly once you get the hand launch down.Originally posted by Jake Bullit View PostHi all new here. Just got mine today so checking in for tips.🙂
What size batteries are you using?
I hold the top of the fuselage just in front of the canopy with my left hand and underhand it at 3/4 throttle. My right hand is holding the elevator slightly up w/right aileron to compensate for the left torque from the propeller.
Have a good time!
2200. I use 50c only because I have some 64mm edfs I share the battery with. I could fly it all day at scale speeds. I flew today for around 5 min and landed with around 80% remaining. Most of the flight was just above idleOriginally posted by Jake Bullit View PostGreat, thanks. What capacity packs and C rating?
a lower capacity battery would reduce wing loading and it should make the plane even happier to fly.
I fly it 4s, but usually throttle is just over 25%.Originally posted by Jake Bullit View PostHi all new here. Just got mine today so checking in for tips.🙂
Set the esc motor brake on, this way you can possibly break fewer props.
Flies great. I wish it had a rudder, but that's more about my style. You can do the mod, but I already painted mine and didn't.want to mess it up.
What size batteries are you using?1 Photo
I flew mines yesterday. And, all I kept hearing was, "Damn, that thing is fast." That's coming from guys flying 1600mm warbirds, turbines and big aerobatic gassers.
To answer the question about motor brakes, I have mine turned off.
As a general extension/continuation of my current... adventure with the P-51; I got the rates set on a 3-pos switch so I have more options to play around with it now. I also went ahead and took out the 8020T and the A3P and replaced them both with a single AR630 unit; with the space savings I was able to get more space to play with the CG.
On the subject of playing with the CG, I know that I said I didn't think that there was a CG issue; but now that I've had the opportunity to play around with it, I now suspect that I might have had my CG set extremely wrong and nose heavy (part due to my inexperience, part in due to not having enough space because of the 8020 and the A3P).
Originally, I had the CG set with the nose facing side of the battery practically in-line with the front edge of the canopy opening. It seemed okay at first just spot checking it on the field, but it wasn't until I actually had the manual recommendations (and the aft heavy recommendation from users on this forum) marked out with a sharpie and had the plane balanced on the bench that I realised that the battery was way to far forward on my first few flight tries.
Sigh... always either either the last things you check and the things you're most sure aren't the problem...
Anyways, now that I have my rates setup properly, a less mess-up-able gryo setup, and my CG/battery in its proper place; I should be able to at least get the plane flying.
Put brake off. Brake on, propeller could stop perpindicular with the ground and break. Brake off, propeller is free to move when it strikes the ground.
Throttle is calibrated and zeroed out. Just having the battery plugged in and working servos made it warm. One guy said it’s because it has a BEC in there?Originally posted by SanExup View PostI turn it off with hope of it spinning freely on landing. But others might have a different experience.
Is your esc hot? Is your throttle trim zeroed out?
Sorry, so many questions. Flightline P-51 850mm. Do you want the motor brake on or off? On the Motion website, James says have it off. On the forums guys are say have the brake on so you don’t break the props. 🤷🏻♂️
