Official Black Horse Heinkel He-111 1750mm ARF Discussion Thread
Sorry, no paperwork! Just a lot of fitting, cutting, re-cutting, fitting... and so on! I do not think two of my 3S 5000s will fit without some major mods. I may just go with a couple of 3300s at first. Maybe I can find a nice 3S 6000 later.
BobComment
Good job! Where did you get these struts? I need them...I have been working diligently on this He-111. I wanted to put some decent gear doors on this one as I did not use the stock struts. There was lots of trial and error, and lots of scrap balsa and plywood but I finally got a working prototype today. It still needs some tweaks on the linkages and well as some adjusting of the hinges to close the gaps - but that is for tomorrow!
Sorry, no charts or graphs! ;)
Bob
https://youtu.be/BnFWjA1Q3Rw
https://youtu.be/_Y3Tx4JLtwUAny day you can fly is a good day! :D
DaveComment
My Heinkel He-111 is nearly finished. I did a short taxi test today. I still need some cosmetic details, but she is almost ready to maiden. Sorry for the out of focus pic. I forgot to wear my glasses!
Thanks again to MotionRC for carrying the Black Horse He-111!
BobComment
Actually the two 3S 5000s do fit in this plane. I was mistaken earlier.
BobComment
well.....Mossy landing gear are like hens teeth. I have been digging around.... ESM has a 70" DC3.... the other DC3 gear I found was only 140 bucks, but the pics looked a little spindly..... Those Mosquito gear look good
Has anyone found a suitable replacement yet?Comment
After 3 almost identical conversations.....( 2 with B-25 jockys, 1 with a Bristol) I ordered a spare canopy nose. You get all the nose glazing and the dorsal windscreen for 60 bucks. I also got a pair of the recommended retracts. They will have to suffice until I find a suitable set...***The ones on VQ website, for their 70" (?) DC3 are 149.00....very reasonable.....but man do they look spindly. I want to find someone that has them in hand, for a quality report
The B-25 guys all took one look, and said: "You're gonna want to order a replacement nose while you can. Guarantee you will booger that one up in short order"
So I didComment
A few months ago, I dumb-thumbed my Graupner He-111, letting it tip stall as I was turning from Base onto Final on a blustery day. One of the wings was mangled beyond repair. I'm just now getting around to repairing the 111. Thinking that the BH Heinkel was a rebranded Graupner, I bought a replacement BH wing. On the BH wing, the servos install in a different orientation, but no big deal. The big deal is that the BH wing installs differently to the fuselage. It's gonna take a bit of cutting and drilling in order to be able to put the new BH wing on my Graupner 111. Also, the BH wing uses a larger diameter wing spar. So, I'll have to find a way to make an sleeve so that the smaller diameter Graupner spar will fit and support the new BH wing. Anyway, just FYI.---
WarbirderComment
I am considering this plane and it calls for 2 Cell 11.1V 2600 - 3700 mAh LiPo Batteries. Anyone use 1 4S 4000mah battery? The other question is for the propeller it calls for APC 11.5.5 thin electric. I would like to use 3 bladed props but I am not sure what size to get. Could use some help.Comment
My upcoming maiden will have 2 each 4S 4000 batteries. On my recommendation sheet, it calls for (2 each 3s-4S 11.1v - 14.8v 3250 -3700mah batteries) I am running two 3648-770kv motors with 3 bladed FMS Ki-61 Tony props. I tried to balance the CG with 2 4S 3300 batteries and was still tail heavy. As for spinners, I found that the Dynam Spitfire spinners, although not the right shape, fit well.I am considering this plane and it calls for 2 Cell 11.1V 2600 - 3700 mAh LiPo Batteries. Anyone use 1 4S 4000mah battery? The other question is for the propeller it calls for APC 11.5.5 thin electric. I would like to use 3 bladed props but I am not sure what size to get. Could use some help.
BobComment
You may consider to your heart's content but there is no stock and even Motion can't say when they will be getting a new delivery. Not sure why they took on the BH line when there were such inventory issues.I am considering this plane and it calls for 2 Cell 11.1V 2600 - 3700 mAh LiPo Batteries. Anyone use 1 4S 4000mah battery? The other question is for the propeller it calls for APC 11.5.5 thin electric. I would like to use 3 bladed props but I am not sure what size to get. Could use some help.Comment
don't think it was going to be as popular as they turned out to be. There weren't many of any they brought in.....few too many of that Canadian plane maybe.
