Official Black Horse Heinkel He-111 1750mm ARF Discussion Thread
Figured out the last bits of the install. Designed some servo Mounts, got servos and linkage stuff and gave it a go. Couple caveats - I just used a servo tester to run it, so its a bit herky jerky. I also don't have the rear mount support glued it so its a bit creaky :) Looks like I can't upload a movie, so I'll put that on Youtube under my username - Spinnetti
That's a sweet look Bob
I like it a lot, Bob! Great job. When is the maiden of Heinkel 2?Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Any body used nitro or gas for this nice model? I am looking for my first twin and this could make a unique one. I really like the shape of its wing. 2xOS 46?Comment
Looks good Bob.. Latex for paint or?
Gear is done and all the servos installed, first time on the full gear today (waiting on motors, props escs and batteries). In a rare event, I got my spinner design exactly right on the first print. Its for 3 blades, the profile is close to scale as I can get (the stock one is too bulbous) and still uses the stock back plate. The Gun emplacements are done using Tom Hunt's MG15 off Thingiverse, scaled to size then added ring sights and ball mounts where needed. I have a feeling that belly gun will be an early casualty! A scale control column is next. The exhaust bugs me, but I don't want to cut the fiberglass cowl apart.
I'm a little unclear on how to mount the nose glazing - there's no mounting tabs and it seems too small to fit over the nose section. How does this work?
Gear is done and all the servos installed, first time on the full gear today (waiting on motors, props esc and batteries). Printing a scale 3 blade spinner now using the stock back plate, and a scale control column is next. The Gun emplacements are done using Tom Hunt's MG15 off Thingiverse, scaled to size then added ring sights and ball mounts where needed.
I'm a little unclear on how to mount the nose glazing though - there's no mounting tabs and it seems too small to fit over the nose section. How does this work?
The white paint is Rustoleum flat white primer. The green and yellow are both latex paint from Home Depot. I really like the detail you are putting into yours! The nose glazing is pretty much a pressure fit. Mine is held on using the rubber-type cement that comes with lots of planes. it goes on pretty easily. Once I got it in place (with glue) I taped it down until cured.
BobComment
Today my bomber bug is getting squished again. Was so excited to se the HE-111 come out from Motionrc. I’ve been eyeballing this kit for some time now and it’s finally time to make the dream a reality. It’s definitely a gorgeous model and I can’t wait to fly this at Nall this year. It’s absolutely beautiful as to be expected from a product found on Motionrc. I will start a build thread on this once I get going. Coming off the Nexa P-47 I can definitely see this ones going to take a little more time. Nothing bad just a little more to assemble on this model. Can’t wait to see this one in the air I’m sure it will be an absolute sweet heart.1 PhotoComment
Stuff has been out of stock forever, but thinking about the following for power.. Thoughts? I want scale diameter 3 blade props, so everything has to work with those
2x Turnigy Air Brushless Motor 3730-1000kv (3s-4s 580w)
2x Master Airscrew 3-Blade Propeller 11x7
2x 4000 3SComment
I went with;
FMS 3648-770 kv motors
Props from the FMS Ki-61 Tony
Spinners from the Dynam Spitfire. They are a bit more pointed than I cared for, but it was what I could find with the correct prop shaft hole.
This power set-up makes for a fast bomber, it will run on 3S or 4S. It has only run on 4S so far which would account for the speed. Between scheduling, work and the Wuhan virus - flying has just not been happening for me. My second He-111 has not maidened yet!!
Bob
Take a look at the props and spinner for the LA7 at MotionRC. They look very scale to me.Stuff has been out of stock forever, but thinking about the following for power.. Thoughts? I want scale diameter 3 blade props, so everything has to work with those
2x 4000 3SComment
I ordered the spinners but the blades are currently out of stock but yes I was thinking the same. I also ordered the xwave retracts and I’m hoping the A10 struts I have end up fitting I think the will look close enough for the boozer and function wellComment
Excellent work creating the gear. You have some very good skills! The best I could do was to use the Freewing Mosquito gear.
BobComment
