    Thanks! Wish you could have made it out.
    • PlaneCrazy
      Expert Novice
      • 120
      • Bend, Oregon
      Originally posted by fhhuber
      Well... my opinion on strut spring tension is: You want appx 1/4 to 1/3 compression just from the aircraft sitting parked.
      Then the struts will kind of act like an RC car's shocks.
      Clip or shim the springs to your personal taste. If you need stiffer, just insert a dowel piece that is
      ca hardened.
      That is what has worked best for me on several aircraft, from appx 2 lb to 25 lb with functional scale struts.
      Hi,
      Well, I'm not an expert on these things but if you shim (put some dowling) the struts, then you take a chance of bottoming out. Rather than treat the symptom it would be easier to solve the problem and insert heavier springs. Just my two cents...........which is probably what it's worth.
      • FLTRI
        That Guy from (Viva) Las Vegas...
        • Jul 2013
        • 214
        • (Viva) Las Vegas, NV.
        Well, I went out to the garage to detail the plane a bit more, and adjust some rates. I was disappointed to find the nose gear door servo is bad. It'll open the door, but not close it. I isolated it from the "blue box" and determined it is the servo, and not the sequencer.
        I received the plane 3/25/16 so I'm still in warranty. I opened a ticket with Motion, so I'm sure they'll warranty it. Down side is, It probably the most buried servo in the plane. I'm assuming it's just glued in, so hopefully a little prying will get it out...
        Video below. Sorry for the portrait format, just did it for Motion, as I know they like Proof of Life videos...
        I hate that motorcycle they make me ride. I'm here to tell you, there ain't nothing in the world I hate more than that elephant under my ass.
        -Officer John Wintergreen-
        ElectraGlide in Blue, 1973
        • FLTRI
          • Jul 2013
          • 214
          And a little over an hour later, the warranty servo is on the way!
          Thanks Motion, this is why I buy all my planes here!!!
          • Arycon
            Hobby Squawk Intermediate Pilot
            • 137
            • Melbourne, Florida
            Motion is great. Not sure how many have noticed, but while weathering the plane today I noticed the bottom portion of the rudder fins are hard plastic just like the nose cone. Likely to prevent rash or damage from tail strikes during a bad landing.
            So much thought and effort went into this plane and it shows. Fantastic job, Motion. Keep em comin.
            • PlaneCrazy
              Expert Novice
              • 120
              • Bend, Oregon
              Especially that P47 Razorback with retracts, flaps and drop tanks............!!!!! :rolleyes:
                • 8211
                We got yer back. ;)
                • PlaneCrazy
                  Expert Novice
                  • 120
                  • Bend, Oregon
                  I went to Home Depot today to get some paint and asked for acrylic..........he told me that it was latex/acrylic and now I'm reading the label and it says satin/enamel.....is this wrong???
                  • Arycon
                    • 137
                    Not sure. What brand did you buy? I buy Behr interior matte paint in sample cans. Has a sort of drab grey label with white flowers on it. I would take a photo but my phone photos are too large for the site. I will see if I can reduce the resolution and snap a photo of the jar. Highly recommended these for paint applications. Goes on very well and if you have them color match a piece of the plane you wont be able to distinguish where you have used it for touch ups.
                    OK...trying to post pics. Photo of the sample bottle...again, from Home Depot. The other two are the labels for the olive drab and ventral grey colors on the Allied Green P-38. You may be able to give them the color code table underneath where it says "custom color match." The table says things like...CLRNT. BL. FL. KXL. TL. I think the numbers in those colums designate the computer color code. Not sure if they can match it that way for you. Hope this helps.
                    Awesome! Changing the resolution worked. Photos attached, guys. I included a pic of my plane, still a work in progress, but it has the color matched olive drab in various areas to dull the weathering. Hopefully it gives you an idea of how well the Behr paints work.
                    • Chalredline1
                      • 60
                      Could someone please tell me the dimensions (length/width) of the portion of the wing that is removable? I want to make a wing bag for them prior to the plane arriving.
                      Thanks, Mark
                        • 8211
                        Nice work there Arycon! She's sure lookin' the part!
                          Thanks, Mark
                          19.5" long for the wing panel itself, add another 5.5" to account for the wing spar that sticks out from it (not removable)
                          9" wide at the wing root
                          4.5" wide at the wing tip
                          • Chalredline1
                            • 60
                            Thanks Pat!
                            • downwindleg
                              • 1279
                              • Friday Harbor, Washington
                              Love the weathering on your plane Arycon! What methods and materials did you use?
                              • pmisuinas
                                • 35
                                Originally posted by mz34334
                                Andy: Thanks for the info. I hadn't seen these before.
                                Anybody: Has anyone gotten a good match from Lowes or Home Depot on Silver? If yes, would you please post the paint codes?
                                Thanks,
                                Mike
                                I don't think they can do a paint match on the silver. However, for spray, the Rustoleum Aluminum (says Metallic Aluminum on the can front) is a perfect match, see picture one for a painted stab tip sitting on an unpainted wing. For brushing/spraying, another guy found the paint in the other 2 pictures. He found it at Hobby Lobby, a craft store chain...Pete M
                                • mz34334
                                  • 13
                                  • Ocala Fl
                                  Thanks Pete M. It's a big help.
                                  Mike
                                    • 7340
                                    I posted this info in the Painting Tips and Tricks. The Silver mentioned hear is a great match and the Sergeants is a slightly darker, which is great for varying the color of individual panels. Anyone with paint color tips and matches, fell free to add to this thread, then we'll all have easy access to the info.
                                    • MikeT
                                      Here......Hold my beer.
                                      • 1060
                                      I finally started assembly of mine ( stepped away from the Avenger build for the day) and man this has to be the best thought out ARF I've seen. My FMS was such a PITA to assemble and the nose wheel steering was a joke. I hooked up everything for testing and all work as advertised. Just attach the pod balance the props and decals and I'm done. Maiden Sunday if the weather holds.
                                      Well done Motion and FlightLine.
                                      Mike
                                      • Arycon
                                        • 137
                                        Thank you, sir. I cant take too much credit. You and Flightline did most of the real beauty work. Im just roughing the plane up a bit.
                                        Thank you. Glad. You like it. The weathering is very simple, actually. It is pretty much nothing but chalk pastels. I bought a small box with about ten sticks for dunno...maybe $10 or so? Important to use chalk and not oil pastels. I just use a knife or exacto to shave the pastel into a tiny pile of powder. For the dorsal side I used a mixture of dark green, black and brown. Use a small brush the width of a pencil shaft (diameter wise) and mix the different powder piles into one. I make sure to ly newspaper under the plane cause the powder gets everywhere. Just dab the brush in powder and gently brush it against the panel lines and once the powder density lessens in the brush, gently blotch the overall surface of the panel. Less is more. You can easily add more as needed. The ventral side was done using white and a touch of black. Same technique.
                                        Once the power goes on, seal it with matte clear in a spray can. Locks the powder to the model. The paint chips are done using a tiny detail brush for model painting. I use model master chrome silver, which has the best metal reflective quality. Again, less is more. Gently scrape the edge of panels and add dabs here and there.
                                        That is it. Feel free to PM me if anyone has any questions.
                                        • TSHobbies
                                          Hobby Squawk Warbird Pilot
                                          • Nov 2015
                                          • 671
                                          • Cartersville GA
                                          Back and ready for action...and the damn wind to calm down....new center section, nose art and new name as well...
                                          used FMS gear for the mains and FW gear for the nose,along with a 2.5" Robart wheel..bought the 2.75 diamond tread ,but Im using the stock control arm,so the larger one wouldnt quite fit, even with trimming the inside of the well...and with the 2.5 I had to trim the rear wall of the well, as well as cut the spring by a little less than half to clear the rear of the well. Also had to tie the scissor to keep the gear from extending fully after lift off. Think if I had used the 2.25" wheel I wouldnt have had to do that.
                                          www.TSHobbies.com
