For you guys that are painting the foam, is there a specific paint I need to ask for when I go to the hardware store? I was going to take a piece in tonight on my way home to have it matched.
Hey planecrazy, just getting back to you. I actually painted my invasion stripes instead of using Callie's. It just seemed like the compound curves would would be too much, esoecially on the booms. Also, in answer to dkalwishky, I used Tamiya spray paints, they don't react with the stock paint and great colors including matt white and matt black for the invasion stripes. Also the best tape for masking is "frog tape". Get the yellow ,not the green. It's great and almost never lifts the paint. Good Luck
Originally posted by downwindleg View PostHey planecrazy, just getting back to you. I actually painted my invasion stripes instead of using Callie's. It just seemed like the compound curves would would be too much, esoecially on the booms. Also, in answer to dkalwishky, I used Tamiya spray paints, they don't react with the stock paint and great colors including matt white and matt black for the invasion stripes. Also the best tape for masking is "frog tape". Get the yellow ,not the green. It's great and almost never lifts the paint. Good Luck
thanks,
Andy
Originally posted by downwindleg View PostI did my invasion stripes over the weekend and was noticing there was quite a bit of difference in the widths of different people's stripes. My understanding was that on twin engined planes they were supposed to be 24" wide on the real planes and 18" on single engine planes. Does anybody else have any info on that?
The stripes were five alternating black and white stripes. On single-engine aircraft each stripe was to be 18 inches (46 cm) wide, placed 6 inches (15 cm) inboard of the roundels on the wings and 18 inches (46 cm) forward of the leading edge of the tailplane on the fuselage. National markings and serial number were not to be obliterated. On twin-engine aircraft the stripes were 24 inches (61 cm) wide, placed 24 inches (61 cm) outboard of the engine nacelles on the wings, and 18 inches (46 cm) forward of the leading edge of the tailplane around the fuselage.
Originally posted by tdevince View Post
That's also my understanding. Can't find my reference, but got this from Wikipedia:
https://en.wikipedia.org/wiki/Invasion_stripes
Originally posted by dkalwishky View PostFor you guys that are painting the foam, is there a specific paint I need to ask for when I go to the hardware store? I was going to take a piece in tonight on my way home to have it matched.
As for invasion stripes, I painted mine on. Masked off the stripe area and sprayed it with white primer. Masked off the black stripes and brushed them on with Apple Barrel paint from Walmart. Voila. Much less hassle than vinyl stripes IMHO. Going over those booms with vinyl has got to be a pain.
I will get around to posting pics at some point. Im still weathering the plane little by little. Takes a long time but is worth it in the end. My planes look like hell. Worn in and battle hardened. Just the way they should be.
Hey Planecrazy, If your looking for acrylic paints in small amounts you can usually get them at art supply stores. I use the americana brand but there are many. The ones I use come in two ounce bottles and there are many colors. Although I use the spray for bigger areas, the acrylics are great for smaller things like cockpits, wheel wells ,etc. and water cleanup! Also, I mix colors allot to get that perfect match.
Hey, guys...
I just bought new lipos for my fleet and new to break them in. Charging new lipos can be hairy. Is it possible to parallel charge/discharge them safely for the first few times? I would likely be charging 2 at once at .5c or 1c charge and discharge. Never parallel charged and want to make sure I dont muck it up.
And trying to keep this question brief. I dont want to derail this thread. I just trust the experience here.
By the way,I would also use the acrylics for spraying but I haven't gotten around to learning how to use my airbrush. I bought a nice one years ago but haven't had the time to get comfortable using it - which is why I'm still building foamies instead of conventional kits. So until I retire, I'll have to stay with foamies and rattle cans. Cheers!
After four days of rain, the skies parted and the wind dropped to zero. I took Battle Axe back out and ran all three batteries through it. The invasion stripes helped a bunch with orientation. I backed out some of the down elevator to flap mix, but I need to add some back in. Showed some ballooning, and my landings were a little Captain Kangaroo bouncy. No damage, just embarrassing. I'm gonna pull another half ounce of dead weight out of the nose, it's still flying rock solid, and showing no tail heavy tendencies, gear up or down. I'm flying with single 5000 batteries, and 5 minutes is going to about the max flight time to keep the batteries healthy, and have some reserve for an emergency go around.
All in all, a very successful day. Had an absolute blast, and even got a compliment from a guy flying a big Edge gasser!I hate that motorcycle they make me ride. I'm here to tell you, there ain't nothing in the world I hate more than that elephant under my ass.
-Officer John Wintergreen-
ElectraGlide in Blue, 1973
Arycon: Charging in parallel not a good idea. How will you handle the balance connections? Even if you built a y connector for the two balance ports, the charger will only see the average across two cells in parallel. You might get away with it if you charged without balance and used a "blinkey" later to balance. Parallel discharging is not such a problem.
Originally posted by mz34334 View PostArycon: Charging in parallel not a good idea. How will you handle the balance connections? Even if you built a y connector for the two balance ports, the charger will only see the average across two cells in parallel. You might get away with it if you charged without balance and used a "blinkey" later to balance. Parallel discharging is not such a problem.
PRC Home - FPV Racing Drones, Fat Shark, Tiny Whoop - iCharger, iSDT, & FMA Battery Chargers - Mean Well & Iota Power Supplies - ProgressiveRC
Been using these for years. Often charge 4-6 batteries at a time depending on the capacity and if you have a good charger.
Andy
