F4U-1D Corsair 2280mm (89.7") Wingspan from Black Horse - Balsa Wood ARF - BHM1000-001
It's finally here, the largest fully sheeted balsa Corsair from Black Horse with a new design, new features, and new covering! The Corsair was designed and operated as a carrier-based aircraft, and entered service in large numbers with the U.S. Navy in late 1944 and early 1945. It quickly became one of the most capable carrier-based fighter-bombers of World War II. Some Japanese pilots regarded it as the most formidable American fighter of World War II and its naval aviators achieved an 11:1 kill ratio.
The model is scaled to approximately 1:5 and attention was paid to a true to original appearance and best flight characteristics. The model can be operated using an electric power system or with an internal combustion engine about 60cc displacement.
Factory Weathered Printing The printing on this model has a realistic weathering complete with rivet and panel line detail that elevates the model to a whole new level of scale appeal. Black Horse really takes it to the next level with their weathered covering. It serves as an acceptable flight-ready finish out of the box, and also provides a good base to help fast-track further DIY paint customizations to suit your preferences. |
| Full Retractable Landing Gear Aluminum suspension struts on the landing gear absorb rough landings on grass surfaces. The tail landing gear is fully retractable also, replicating the scale articulation. The tail wheel's mechanism hinges and extends just like the real Corsair! |
Gas or Electric Power You can choose between gas or electric to power your model depending on your preference. We prefer gas for a model this large, but there's cavernous space for an electric power system on 12s. |
| High Scale Fidelity Operate one of the largest and most realistic Corsairs on the market. Black Horse updated a variety of aspects of their previous smaller Corsair's design, then upscaled it to this giant! |
Large Wingspan The Corsair has an impressive 89.7" wingspan for impressive presence both in the air and on the ground. |
| Removable Main Wing Easy assembly and intuitive design allows for the main wing to be removed for transport. Durable nylon pin-hinges are used for all flying surfaces, instead of CA hinges. |
Scale Flaps The three-stage flaps are iconic and fully functional, with rounded leading edges. |
- All new design
- High level of prefabrication right out of the box
- Lightweight, strong, laser cut balsa and plywood construction
- Rotary 90 degree electric retract gear and CNC suspension metal struts
- Panel lines and details printed directly onto the pre-applied, high quality covering
- Model officially licensed by Northrop Grumman
- Airfoiled tail surfaces
- Pre-drilled hinge mounting holes
- Heavy-duty pin hinges on all control surfaces
- Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
- Painted and detailed cockpit, pilot and interior included
- Fiberglass control horns with ball link connector
- comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly
- Fiberglass cowl and glass reinforced landing gear covers/pants
- Mounts for both electric and gas power options included
... I would need to add in the price of a good divorce lawyer to this.. but dayum!... it's so tempting!
