Official Nexa 1870mm DHC-6 Twin Otter Canadian Yellow (Balsa ARF) Discussion Thread
  • KC Air
    Stupid question time, or more appropriately question from a stupid person time.. switching the wires on one motor will make them counter-rotating, true?
  • KC Air
    Just ordered mine. What a great looking aircraft. Paypal Credit is 6 months with zero interest, can't beat that.
    @dutchwhite001 Very nice! I wish I had the room for a second one in the Canadian theme. There are few planes that I have duplicates of and I'll eventually get rid of one duplicate, keeping the "best" one. I just don't have the space to store them.
    Floats for this plane must be huge to hold up all that weight on water. I have a couple water planes but I fly them off grass or snow in winter.
  • dutchwhite001
    Xviper, forgot to tell you I got the set of floats for the Canadian version from VQ delivered yesterday. Here we have a pond at the house, and so does everybody else within earshot, and we fly off them when bored with losing things in the corn fields and Catfish ponds out by the Ag strip! Hope you get another day of Spring in the near future!!!
    Dutchman
  • dutchwhite001
    Hey Xviper, Just ordered my Canadian version Twin Otter to match my Nature Air. And while I was at it, I ordered both the Tigermoths. Figured since I had the one already, mine as well have all three!
    Dutchman
  • Sureshot
    Me three!
  • jobinseattle
    Just ordered mine also.
  • GreenMTN_Boy
    They're in stock, mine is on the way!!!
  • tab28682
    With this (excellent) livery, it is technically a military aircraft, not a commercial aircraft.....: )
    Love that it is a short nose Twotter. If I recall correctly, there have not been any short nose versions done as an ARF before.
    While 10% smaller than the excellent Hangar 9 Twin Otter, it is a real value at the price shown. The list price on the H9 Twotter was $599 when it was discontinued.
    I ned to get the old H9 Twotter out and fly it. I have been procrastinating on a minor repair to the mounting ring on the fiberglass nose.
  • jobinseattle
    Thanks, I think I will go with the Admiral 4S 4000mah since I already have four of them. The difference in weight from the Admiral 3S 5000 to the Admiral 4S 4000mah is 16 grams. I am sure a 3S 6000mah is heavier than the 4S 4000mah (388g). Besides that think I will go with most of Motion RC recommends except I will use these motors: Leopard 3536-10T 780kv Brushless Airplane Motor
    Yes, you can use one battery if you like. It’s just a bigger one that equals that of 2 smaller ones. If you build this plane on 3s power, the recommended battery is up to 6000mah. So, you could go with one of those or 2 smaller ones equaling that mah. I built mine to run on 4s power and I use 2X3000 mah, but I could just as easily go with one 5000mah to 6000mah battery. I have a lot of smaller batteries. You just need enough weight to achieve the correct CG in the space available. One or two batteries doesn’t matter. It’s what you have or what you want to buy.
  • jobinseattle
    According to Motion RC their version uses only one battery. I even sent them a message and they confirmed it.
    Originally posted by jobinseattle View Post
    Anyone planning on running 4s 4000 batteries in this plane? Looks like the Admiral motors and the ZTW Mantis will support it.
    As this is the same plane as the VQ Twin Otter "Nature Air" version, it's been done. I use 2 Graphenes, which are about the same size and weight as non-graphene 4000, 4s. I stack them one on top of the other "longitudinally", but staggered. In order to balance the plane, one has to be slid underneath the pilot seat, leaving about 2/3rds of it sticking out behind the seat. The second battery goes on top (with some non-slip matting in between) and the rear of it hangs past the end of the bottom battery. A fairly long velcro is needed to hold it in place. Depending on how you built yours and the motors and ESCs you use, you may be able to use a single large 4s battery or put the two 4000's side by side with a bit tucked under the seat.
Name:	HobbyKing (VQ) Twin Otter_Moment(3).jpg
  • jobinseattle
    That looked pretty good on 3S. They are using 1250kv motors, so total rpm is still up there.
  • jobinseattle
    Thanks, I have not seen that one.
  • nuts-n-volts
    Here ya go... Not my video or plane. I just found it on YouTube. 3 cell flight Looks pretty good!
  • jobinseattle
    Sure would be nice to see some videos of this plane especially using a 3 cell on such a big plane.
    bkjohns Welcome to Hobby Squawk!
    The choice of ESC is really dependent on what motors you plan to run. If you were to run the Admiral GP2 3520 950kv motors mentioned in the listing, you could go with the ZTW 45A ESCs. The burst rating for the motors is 42A and the burst rating for the 45A ESCs are 65A. The burst power rating is for about 10 seconds.
    It's often a good idea to have a little more margin between the upper limit of the motor and the ESC.
    It looks like the 85A referenced is a carry over from a cut and past when creating the listing.
  • bkjohns
    "2x 85 Amp brushless ESCs - we recommend TWO of the ZTW Mantis 45A ESC with 5A SBEC"
    So which is it - 2 85 amp or 2 45 amp?? (note the underlines)
