Official FlightLine RC 1200mm Spitfire Mk.IXc Thread
  • Beeg
    • 1335
    • Texas
    Using the full scale wingspan of a Mk.IX (442.9in) with a stated wingarea of 34848sq.in. gives you a mean chord of 78.68in
    Published wingspan of the FLRC Spitfire 1200mm (47.25in.)
    If you scale that down to 1/9.4 scale that gives you a wingspan of 47.12in. and a mean chord of 8.37in. for a wing area of 394.36sq.in.
    If you scale it at 1/9.3 you get a wingspan of 47.62" with a mean chord of 8.46" for a wing area of 402.85sq.in
    So, I'd say maybe, probably, almost but just barely if the model wing planform is exact scale without taking actual measurements..
    .......and, if my calculations are correct...
    • Randy H
      • 63
      • Surprise AZ
      Thx that helps a lot!!! Appreciate your help
        • 5385
        The EFlite 1200 is 416,9 so should be similar. https://www.horizonhobby.com/spitfir...basic--efl8650
        • Blanefieldbonty
          • Sep 2020
          • 4
          Hi, I'm looking to purchase the Spitfire. How did you get on with the Spektrum receiver (JustGoodBusiness) in SAFE and AS3X mode?
          • coyote137
            • 14
            photos of my weathered spitfire
            • highland
              • Sep 2018
              • 6
              • West coast of Scotland
              I'm trying to remove a main undercarriage leg. Is it necessary to open the motor mechanism to get at the grub/screw that's holding the leg ? The very small screws in the casing are proving very difficult to remove.
                • 5385
                Shouldn't have to. They are accessible from the retract sides.
                • highland
                  • Sep 2018
                  • 6
                  Evan, thanks for your reply, so I dug a little deeper into the side hole and found a grub screw(one each side) loosened by a 1.5mm allen key.
                  Thanks for the backup. Bill
                    • 5385
                    Cool
                    • highland
                      • Sep 2018
                      • 6
                      Thought I'd send you a pic of the patient, now recovered from mild leg surgery.
                      Two years down the line, still a joy to fly.
                      Click image for larger version  Name:	spit1.jpg Views:	0 Size:	98.1 KB ID:	276469
                        • 5385
ID:	276475 Nice, here’s mine.
                        • SanExup
                          • 912
                          • Western Wy.
                          Click image for larger version  Name:	0F18D2B3-C190-45E1-9FB5-BCA43EC90739.jpeg Views:	0 Size:	18.4 KB ID:	276475 Nice, here’s mine.
                          Is that a folding prop you are using!?? If so what variety? And stock esc? I'd rather keep buying batteries than props! (It's hard to tell from the photo but it looks like the spit in the foreground has a folder)
                            • 5385
                            APC electric not a folder. I run the 1200 on 4, 5, and 6s! It also has FPV. That is my 1200 and 1600.
                            • Stuondrums
                              • Nov 2020
                              • 2
                              Hi folks - hey Highland, ( Or indeed anyone else ) do you think you could post a picture of where that grub screw is? I am wondering if I am missing something or just being dense. Thanks !! :-)
                              EDIT:
                              Found them! Thanks.
                                • 5385
                                When you extend the gear the set screws are in one of these holes...
                                • Stuondrums
                                  • Nov 2020
                                  • 2
                                  Thanks Evan, I had found them ( Having misinterpreted your first description) but I'm sure someone else will get it wrong like I did :-) Really appreciate your help.
                                  Here's mine after a slightly sweaty maiden : she was VERY sluggish, I suspect a nose heavy situation ( as did a few more chaps at the club who were watching) I tip stalled her into the ground and the bend undercart and a tiny crease on one wing were the only damage after cartwheeling to a stop.
                                  • SanExup
                                    • 912
                                    • Western Wy.
                                    It looks great with the invasion stripes!
                                    • Belly74
                                      • Jun 2021
                                      Hey All, I'm looking for some guidance on set up... Internal - receiver position, sound system and speaker position... Anyone got photos or sketches?
                                        Hello Belly and welcome to the Squawk.
                                        This plane is likely not a candidate for a sound system due to it's size - just not enough room as well as the additional weight.
                                        Sound systems like the MrRC Sound are rather tight for space even in the 1400 size warbirds.
                                          • 5385
                                          I put a MR RC Sound in mine early on. The transducer was in a cutout in the block behind the main wing at the center of the fuselage and the board was at the rear of the battery area. I’ll see if I have any pics….
                                          I made the cutout and added a ply floor. Worked well. Later on I got more into FPV and got the 1600 Spit so I removed the system from the 12 and put it in the 16, where it still is. And I put a FPV system in the 12...
                                          . Click image for larger version  Name:	image-51e16a23.jpg Views:	0 Size:	55.8 KB ID:	314893Click image for larger version  Name:	image-e506614b.jpg Views:	0 Size:	52.5 KB ID:	314894Click image for larger version  Name:	image-169315bb.jpg Views:	0 Size:	72.3 KB ID:	314895
