Hi, does anyone know the exact paint colors of the Flightline 1.2m spitfire, i cant find the exact paint, I'm trying to repair after a paint scrape
Official FlightLine RC 1200mm Spitfire Mk.IXc Thread
Hi Joe, welcome to the Squawk!
The best way to color match is to take a piece of the plane to Ace or Lowes, even Wally world and have them scan the color. Get it in a satin/pint can, just went through this with another member. All others finishes require you to buy a quart can, which you don't need.
When finishing, I apply Minwax Spar Urethane Gloss to seal the decals and then spray Minwax flat on it. layer it until it's as flat as you want.
The Gloss seems to seal the decals better than the flat to my way of thinking.
My Rule Of Thumb is if you want a very flat finish, spray, if you want a glossy finish, use a brush.
Grossman56Team Gross!
Hi all,
I did the mainden flight of my 1200mm spitfire 2 days ago. Generally speaking it was good but the plane needs about 2-3mm up elevator to fly straight, even though it's normally balanced. I have tried moving the battery a bit to the back but the plane still dives if I don't trim the elevator. Is there any way I can fix this problem?
Thanks!
Hello! I maidened my spitfire a long time ago and I was extremely inexperienced for that plane at the time, and now that I'm fixing it.... I can't find a way to get rid of propeller wobble, I bought a new prop, and prop mount?( i think its called) but i cant get the original one off, so is there a way to do that?
It takes a 6ch radio and there are way too many brands and choices. Spektrum makes a nice 6ch that would require almost no programming. They have a large selection of receivers with or without gyros, AS3X and SAFE. Most 4s batteries in the 3000 or so size work. I caution you buying either a Spektrum or Admiral brand as there are many as good but much less expensive.
Hello everyone! Just found out I was getting a Spit for Chritmas from my daughter's! Cant open the gift before then but was wondering if I will need to get more batteries. I have 1 4s 3200 and a bunch of 4s 2200's. Also a couple of 4s 6750's. Wondering if anyone has had some experience with these sizes?
thanks
Understood. My point is that Motion makes a battery recommendation on what they sell and there are other choices out there. Mine has a 2 bladed APC prop that is more efficient than the stock 4 bladed one and I have flown it 4, 5, and 6S. The 4S I use is either a Secokin 3700 that weighs 300g or a Hobby Star 4600 that weighs 380g, the 5S is a Zippy Compact 3700 that weighs 418g and the 6S a Hobby Star 3500 that weighs443g.
I understand that you are happy with the 3000 pack which is listed at 306g, just saying there are other choices plus the Spitfire handles the heavier battery well. My Spit is also FPV so it's even a bit heavier.
Originally posted by Evan D View PostUnderstood. My point is that Motion makes a battery recommendation on what they sell and there are other choices out there. Mine has a 2 bladed APC prop that is more efficient than the stock 4 bladed one and I have flown it 4, 5, and 6S. The 4S I use is either a Secokin 3700 that weighs 300g or a Hobby Star 4600 that weighs 380g, the 5S is a Zippy Compact 3700 that weighs 418g and the 6S a Hobby Star 3500 that weighs443g.
