The mounting holes on stock HSD are 28mm W 25mm L , strut alone is 102mm strut & retract look to be about 140mm
sounds like it could be made to work with some mods to the wing and mounting position.. basically carving out some foam..but it might put the bottom of the wheel right at the trailing edge of the wing/flap join (leading edge of flap)
