HSD 1600mm A-1 Skyraider WIP
  • Originally posted by Jerry's Flying Circus View Post
    Just discovered on the HSDGO site that they have the "HSDJETS GENERAL LANDING GEAR CONTROL BOX" listed as a replacement for the HSD A1 retract control box. Excited to get this and verify it works so this SPAD can get some airtime. Grabbed a couple props also. Thanks again to OV10 for the hints!
    • Ok fellow A1 flyers, I have bypassed and removed both of the junction boxes in this plane and direct wired the lights and replacement FMS P40 Retracts. Everything works great and I am very happy with the set up. This leaves me with a set of fully functional HSD main retracts (no struts or wheels) that are available. Message me if you need these and we can work something out.
      BTW - The FMS P40 retracts worked perfectly as a replacement retract for this plane. It did require some minimal foam carving because the body of the retract mechanism is longer than the stock body. I made no modification to the strut, it was a perfect fit on the retract. I did need to remove about 1/8" or so off the top of the retract to fully seat the strut.
        If you drill out the stock strut 1/8" deeper you can leave the retract the full length and by re-drilling the retract mounting holes and cutting out a little foam in front of of the retract cavity you won't have to crave up the wheel wells.
        • OV10, I am reviewing your modification of the gear fix. I am just getting around to it as I had extensive hand surgery and could fly. This is probably simple; however, let me make sure I understand the fix. I am going to remove the current pin and insert the roll pin with a vice, and re-insert the pin remover. In other words, the roll pin goes over the original pin to prevent failing out. I hope I understand this correctly. If not, please let me know where I am wrong. Many thanks for your help.
          • The roll pin replaces the pin removed. The roll pin is also known as a tension or spring pin and it is slightly oversized and it compresses along its longitudinal slit to go in the hole and stay there very firmly which is why it has to be pressed in.
              Seems like they were too long, I'll check tonight.
              What was the length of the struts, both FMS and HSD?
              Just let me fly so I may be free
              • Here are a few pics of my newly complete A1. I love the foam this plane is made with and really look forward to flying it this spring!
                • Great flying plane.
                    The HSD Skyraider is one of the best built planes I've ever seen, I just don't understand why it had such a short lifecycle...I wish Flightline would buy the molds and refine it even more.
                    I had also indicated this back in post#28 so just wanted to keep this thought alive for Alpha by posting some Sandy "blast in the recent past" flight pics.
                    Alpha, give us 1700 Sandy...........plzzzzzzzzz.
ID:	115454Click image for larger version
ID:	115455Click image for larger version
ID:	115456Click image for larger version
ID:	115458Click image for larger version
ID:	115459Click image for larger version
                    • Yeah! I like it!
                      • That’s a VA-176 Thunderbolt’s A1.
                        I was a Thunderbolt from 1981-1984... A-6E Intruders and KA-6D Tankers
ID:	115527Click image for larger version
                        • Always liked the Skyraider.
                          • Ha
                            I held out to join the Navy until they replaced em ;)
                            • Looks like HSD is bringing it back...hope they do a PnP version.
                              Sean
                              • I missed out on the first run. I'll take one kit form or whatever :)
                                • I chatted with HSDgo this afternoon and found out this plane is discontinued. They have a few kits in stock that the factory had in their warehouse. So when these kits are gone, they're gone.
                                  Sean
                                  • Originally posted by EDFjetpilot View Post
                                    Sean
                                    Did you per chance ask what the kit consists of ?? When Dragon Hobby carried the kit it included all electrics except the motor and ESC.
                                    • Yeah the website has nothing about it at all
                                        Requires:
                                        • 6 channel transmitter and receiver (not included)
                                        • Battery and charger (not included)
                                        • Brushless electric speed controller (not included)
                                        • Brushless motor (not included)
                                        • Nine servos (not included)
                                        • Retracts (not included)
                                        • So you get a box of foam...
