Bomber Bums....
...another update....
Sized windows and doors, designed/printed frames for those and with surgical precision cutout the holes
I then glued the frames to the fuselage, filled where required
, primed and painted color.
I like it a lot though I will need to do an overall quick wet sand to even out the paint lines.
I had already cutout all the plexiglas bits, so after I paint in the window sills, I'll glue those into place.
This is a good step forward to finishing the fuselage.
Looking forward to finishing out the greenhouse and gluing in the cockpit glass.
Best, LB
...another update....Sized windows and doors, designed/printed frames for those and with surgical precision cutout the holes
....I then glued the frames to the fuselage, filled where required
, primed and painted color.I like it a lot though I will need to do an overall quick wet sand to even out the paint lines.
Best, LB
.. b getting cooler there!!! We've had couple good days,, but overall. Cold. Summer next month ,, yet dtay is 14 degrees.. go figure.... So much 4 global warming...:face_with_raised_ey b safe
