  • vrosi1963
    Hobby Squawk Pilot
    • Aug 2016
    • 76
    • Califorina
    Originally posted by davegee
    I am hoping it will come out well as a bubbletop. I will be shipping the fuse out early next week. It will take him about a month or so to get it done, and then ship back to me. That will just be the beginning of the project.
    You can judge from photos and my comments if you want to try one for an M model or something. I'll keep you posted with pics how it goes when I can get them. I would guess that would be in March sometime.
    Regarding the Spitfire rear view mirror, I did a couple of different techniques. One plane I used the whole mirror base and glued the stand to the wind screen top glass. The other one I cut off the base mounting part from the mirror and just glued it on directly to the same place on the top of the windcreen. I'll include a couple of pics. This thing is REALLY easy to knock off transporting the airplane to/from the field! Stays on flying but getting it to/from the field intact is dicey, sometimes!
    Cheers
    Davegee
    Click image for larger version Name:	IMG_3388.jpg Views:	0 Size:	59.8 KB ID:	442414 Click image for larger version Name:	IMG_3387.jpg Views:	0 Size:	59.1 KB ID:	442415
    do you have a stl file for the Mirrors
      • Nov 2013
      • 2785
      • Cody, WY
      No, this was part of the plastic canopy kit that comes with each Spitfire. I just used those as I didn't have an STL for it. They were inexpensive and were reasonably close to what I needed for my razorback P-47s.
      d
      • jetfool
        • Nov 2022
        • 1364
        • Crawfordsville, Indiana
        Davegee,
        Thanks for the pics. I like the mirror that you cut the base off, think that's how I will do mine.
        Dark blue is my favorite color and P-47M of Capt. Lanowski would be my choice. I have an old Jemco kit of the P-47D Razorback but I ordered Jemco's plans for the bubble top and retract plans at that time (mid 80s). It's 54" ws but would run like a bat otta _ell if I installed the motor and prop from FMS P-47. Hoping your conversion goes well as I like the way my FMS flys. A pic. of Johnson in Lucky, the front canopy, bullet glass and framing details show up
        Dan,
        Just for fun but here is the pic. of Bob Johnson and his buddies doing their walk. Would be a show winner if they walked in front of my P-47 by r/c control. LOL
        Best Regards, Rex
        Click image for larger version  Name:	IMG_3914.jpg Views:	0 Size:	113.8 KB ID:	442436
        Click image for larger version  Name:	IMG_3915.jpg Views:	0 Size:	126.4 KB ID:	442437
        Click image for larger version  Name:	IMG_3916.jpg Views:	0 Size:	159.6 KB ID:	442438
        • jetfool
          • Nov 2022
          • 1364
          Davegee,
          Won't do this to Lucky but have you thought of using thin g10 strip and making the ail., flaps, and tail feather trailing edges a sharp edge. I think if you slit the center line, installed strip of g10, sanded foam and used poly acrylic to harden the surface it would hold up flying and be more scale. Just a thought.
          Rex
            • Nov 2013
            • 2785
            • Cody, WY
            Originally posted by jetfool
            Davegee,
            Rex
            I have actually thought of that often. The thick trailing edge has always bugged me. What is "g10" I have not heard that term before? I might like to experiment with making sharp trailing edges to wings, tail, etc., if it doesn't add a lot of weight or is a total hassle to do. We should talk more about this.
            Davegee
              • Nov 2013
              • 2785
              • Cody, WY
              Davegee,
              Dan,
              Best Regards, Rex
              Hi Rex: Lanny Lanowski's M model as in your picture would be a good one. Be aware that the colors of the 61st FS and their M's was matte black. Some say it was blue, but I have good color photos and descriptions from pilots and mechanics of the 61st that said it was matte black, and that was all. In some lights, it may appear to be some other hue of black.
              My late Spitfire was painted up in one of Lanny Lanowski's planes when he was flying with the RAF. I know his son, Krys, who lives in England.
              Cheers
              Davegee
                • 4872
                What is "g10"? Davegee
                DG,
                Fiberglass/Epoxy laminate sheet, aka Garolite.
                G-10 is a grade of this 'branded' product.
                Best, LB
                • vrosi1963
                  Hobby Squawk Pilot
                  • Aug 2016
                  • 76
                  • Califorina
                  .There is this one designed by Tom Hunt , i think it needs a post to be glued into the canopy https://www.thingiverse.com/thing:176286/files
                  Chronicles of Courage: P-47 and the Double Wasp Engine ​
                  • jetfool
                    • Nov 2022
                    • 1364
                    Davegee,
                    Elbee's description is correct. You can buy strips in .005", .010" up to 1/4" thick from McMaster-Carr. Used a lot in 1/4 scale models, ding proof and lite weight in the smaller thicknesses. Thinking of doing this on the Phantom if I have time. I would use about 1/2" wide .005" strip and poly acrylic a 1-2" 3/4oz fiberglass cloth around the trailing edges. This process doesn't build much weight and blends in with the poly coating process. Just a thought that would set the model apart from a foamy. What do you think Elbee?
                    The black if right shade of black would be Ok, like you said certain lighting makes a black look a little blue.
                    Look up Garolite in the McMaster-Carr specs.
                    Best Regards, Rex
                    Snow and wind chill 2' today so I'll just have to spend it in the Skunk Works
                    • jetfool
                      • Nov 2022
                      • 1364
                      vrosi1963,
                      Thank you for the information. I have the Flight Line Spitfire mirror but will file the STL for future use. Glad to have you with us in helping convert this model. Join in with your thoughts and idea's so I can steal them. LOL
                      Dave, you just slit the center line with an x-acto or razor blade, slide in the g10 and glue w/thin ca. then you can sand a uniform trailing edge. Easy Peasy
                      On my P-47M 3 view the panel lines around the front of the canopy are different than my Razorback.
                      Best Regards, Rex
                      • vrosi1963
                        Hobby Squawk Pilot
                        • Aug 2016
                        • 76
                        • Califorina
                        vrosi1963,
                        On my P-47 3 view the panel lines around the front of the canopy are different than my Razorback.
                        Best Regards, Rex
                        we will see what i get in return for stl files in the future
                          • Nov 2013
                          • 2785
                          • Cody, WY
                          vrosi1963,
                          Best Regards, Rex
                          I have a few extra flight control surfaces that I could practice on. Do you have a link that would take me directly to what you recommend me using to get a nice trailing edge on the surfaces?
                          dave
                            • Nov 2013
                            • 2785
                            • Cody, WY
                            Thanks. I'll print it up as an extra and possibly replace one of the Flightline Spitfire rear view mirrors that I have on my razotback jugs.
                            davegee
                              • 7424
                              Just came up for air!
                              He's 99% finished, just a couple of minor touch ups and some gloss on the eyes, goggles and mouth and he's ready
ID:	442465 Click image for larger version
                              Again, it's hard to get a descent pic, but remember, he's only about 4" tall in real life!
                              God, took me a couple of hours just to paint the harness! Good thing I like doing it!
                              Now, Rex, get in there and win one for the gipper!!
                              (Dangerous Dan)
                                • 7424
                                Bob waiting in the pilot's pool waiting for his assignment to the 56th Fighter Group.
                                Bob is second from the right.
ID:	442468 Click image for larger version
                                • jetfool
                                  • Nov 2022
                                  • 1364
                                  Outstanding Dan! I will try to-do him justice at the show. Win or Lose I think he will be the best pilot there. He is a handsome cuss, probably have to beat the ladies off from trampling my plane to see him.
                                  Dave I will look on RCSB forum and try to find a tutorial but here is how I have centered my flying edges. I use my old Du-Bro center finder and a pencil. then slit the line and slide the g10 in. Hope this helps.
                                  Best Regards, Rex
                                    • 7424
                                    I think my next Tinker Cad project should be to design a beer bottle they could all be holding:wine_glass::champagne:
                                    • jetfool
                                      • Nov 2022
                                      • 1364
                                      Grossman56,
                                      I'm practicing on a German WW1 pilot and his coat is black leather. Do you use the same colors as you do on the brown leather to bring out different shades and shadows. Each pilot is getting better following your methods.
                                      Best Regards, Rex
                                      The beer bottle sounds good. Might have to have a beer myself. lol
                                      • jetfool
                                        • Nov 2022
                                        • 1364
                                        Davegee,
                                        If I shaded the backside of the cowl, would it look like the clearance of the real one? That foam flange is an eyesore to me. Thought of a dark flat grey or flat black with a thin cowling line showing. Your thoughts?
                                        Best Regards, Rex
                                        • vrosi1963
                                          Hobby Squawk Pilot
                                          • Aug 2016
                                          • 76
                                          • Califorina
