Good points, and well-taken! I'll check out the position of the rudder servo arm. I believe it is not on the outermost hole but the second one in. I use 50 per cent Expo on lower and mid rates on the rudder and tailwheel, and high rates I reserve for taxiing with more rudder authority for tight turns on the ground. I've been adding some up elevator while on the initial takeoff roll and then ease out of it to neutral rudder as the aircraft accelerates. It pretty much flies itself off with very little up rudder command. Landings work out really well, although I got a minor prop tip strike when I landed just a bit too nose down attitude. But that was easy to sand the tips and repaint. Ready to go!
Cheers
Davegee
Cheers
Davegee
