V2 arf release 2026 ??????? i really doubt they would not just change the scheme and keep making money since it is very popular , Robert s Johnson would be a easy arf production scheme ,
Hi James: Is this pretty reliable info that they might be coming out with a V2 version of the P-47? There are a lot of great liveries to paint a new version up in, for instance, Little Chief flown by Lt. Frank Klibbe would be a great one if they do that. You have a little picture of it in your name tag info on your inputs. If I ever did get another razorback P-47, that might be one I would use. Or, just leave all the markings off and let the buyer have a "clean slate" to put whatever scheme they choose on the plane.
Cheers
DavegeeComment
Hello All: I've been a member of HobbySquawk, I think since about 2013. A couple years ago, my account disappeared somehow and I had to have the techs at HobbySquawk help me. For years it was just "Davegee" but they couldn't get that to work. So now, I had to go by Davegeee with the extra "e" on the end to access the site.
Recently I tested it and it looks like my old "Davegee" that I used for many years still works. So, I prefer if you contact me if you could use the original Davegee with the two "e's on the end instead of Davegeee, that would be great. Looks like both will work for me now and I'll answer to either one.
Cheers
DavegeeComment
I was getting so frustrated trying to get back on. Mike J at MRC was trying his best. Today, he tried again to get me to log in using a different password he'd set up for me. I'd been trying this for almost a week since the hack, but nothing. Today, I just hit the log in with my old Password and it worked! Once in, I changed my password and hopefully everything should be good.
(Dangerous Dan)Team Gross!👍 1Comment
Craig,Originally posted by f4u ausieHey guys. Hope U all well. I've been busy.. now wrong Thread but close.. just couple pics 4 those that matter. Hence wrong Thread. U all no the drill. Rub rub rub. Bla bla bla. Happy with SNAFU progress.
Which manufacturer produced your P-47?
Great work by the way.
Best, Steve"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
Good progress on Snafu, Craig! Gonna be a beautiful looking and flying airplane when done.
Cheers
DavegeeComment
Yes Dave once wings are at the same point as the fuse all will have a final rub down. An even green coat overall then grey on the bottom invasion stripes. Matt clear. Onto graphics and electronics done I'm sure maiden will not be till next year. And thanx looks close. Matched it myself. Black green red oxide yellow Ochre bit of white b safeComment
you have the master's touch! Good work on the paint scheme!Yes Dave once wings are at the same point as the fuse all will have a final rub down. An even green coat overall then grey on the bottom invasion stripes. Matt clear. Onto graphics and electronics done I'm sure maiden will not be till next year. And thanx looks close. Matched it myself. Black green red oxide yellow Ochre bit of white b safe
DavegeeComment
