  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    Originally posted by Mad Baron
    I set up the balance at 1/2 inch down from level CG at 70mm and when the gear extends the nose drops almost to the table like the pic in my earlier post. I am at a loss at what to do next.
    I fly my Tigercat with a pair of Admiral 4S 3600's all the way forward, no idea where my CG is but the plane flies really well there. I notice NO pitch changed when the gear is deployed or retracted.
    I'm sure I picked this battery location from the flight review video that Ryan & Mike did.
    • Dual Prop Dave
      Just another Prop Nut!
      • 144
      • Sunbury,Pa
      I fly mine with Admiral 3000's with both as far forward as possible and it balances very level gear up. when I drop the gear in flight, I don't really notice any change in attitude and have landed with no flaps using throttle management on descent and had no problems what so ever. Like everyone else on here has stated, this is a very sweet flying bird!
      Hope this helps.
      Dave
        • 7387
        Hey MB, I did the same as Dave did, just followed the video, but I did check it out just now as a matter of interest. Now I had her up for three flights just this last weekend and they were flawless with the batteries in the forward position
        Click image for larger version  Name:	IMG_4034.JPG Views:	1 Size:	122.2 KB ID:	152313
        with the bottom battery placed at the forward edge of the plywood platform
        Click image for larger version  Name:	IMG_4032.JPG Views:	1 Size:	106.7 KB ID:	152314
        Now, I have flown her with the top battery at the point of the strap...
        Click image for larger version  Name:	IMG_4036.JPG Views:	1 Size:	192.3 KB ID:	152315
        And she flies great there as well. With the battery at that position, the CG comes in about 65-68, close enough to the CG that CB is recommending...
        Click image for larger version  Name:	IMG_4035.JPG Views:	1 Size:	116.2 KB ID:	152316
        And of course, when the gear swings down, she'll get nose heavy, mine will touch the table and slide off if I'd let it.
        So, with that in mind and remember, both these positions have been flight tested, when I drop gear and half flaps, I have no elevator mix. At full flaps, I have a small amount of down elevator.
        On my DX 8 first gen, the mix is 6%.
        She's extremely forgiving and I really don't think you'll have any trouble flying this one.
        Hope this helps!
        • Mad Baron
          132 Aviation
          • 547
          • McMinnville Tn.
          I am going to order some 3000 batteries for my Tcat tomorrow so by next Friday I will punch some holes in the sky with it.:Cool: Think fly Tcat FLY!
            Sounds great!
            • Dual Prop Dave
              • 144
              • Sunbury,Pa
              Your going to really like this one! She's sweet!:Cool:
                • 7387
                Good idea, but the 3600's and 4000's work well too. What you might think about, as we've talked about earlier in the thread, is running the ESC's and batteries in parallel. One big tank feeding both motors.
                • Dual Prop Dave
                  • 144
                  • Sunbury,Pa
                  I agree with Grossman56, I run mine in parallel. It's comforting to know if something would go wrong with one battery, you still have the other feeding both motors. I fly all my twins in this fashion.
                    • 7387
                    Exactly, wanna know how bad it can be?? Try taxiing with one motor, it ain't pretty...
                    • Dual Prop Dave
                      • 144
                      • Sunbury,Pa
                      No Thanks! LOL Seen a beautiful OV-10 and a Really sweet B-25 go in due to One motor out, and that was at the hands of a very competent Pilot! (not me) I'm average.:P
                        • 7387
                        My thoughts exactly, I'm not great at soldering so I found two plugs to do the job. One from Motion and the other from RC Juice, through Amazon, so I scored it for free using my Amazon points.
                        Now I have one less thing to worry about.
                          Awesome stuff!
                          • Mad Baron
                            132 Aviation
                            • 547
                            • McMinnville Tn.
                            I bought some ec50(?) connecters and some wire from MRC and going to make some parallel connection wire. I plan to fly it before I paint it to get used to how it handles in the air. I'm always a little nervous when I put a new plane in the air.
                            • Woodcock
                              Old Returning Pilot
                              • Apr 2018
                              • 830
                              • SoCal
                              That's a smart thing. I always fly them several time prior to doing my final detailing. Make sure it's good model before investing the time.
                              Woody
                              PS the, "Great Race" was one of my all time favorite movies. Jack Lemon was really good.
                              • Mad Baron
                                132 Aviation
                                • 547
                                • McMinnville Tn.
                                I really like the Great Race I got the dvd to it "push the button Max!" LOLLOL
                                • Mad Baron
                                  132 Aviation
                                  • 547
                                  • McMinnville Tn.
                                  Started working on my parallel battery adaptors I went with Riflemans design (hope you don't mind) . Got my order from Motion today I was expecting it on Monday.
                                    Not at all! Heck it does the job, as far as I'm concerned its just a small contribution to the hobby for anyone to enjoy. :Cool:
                                    • Mad Baron
                                      132 Aviation
                                      • 547
                                      • McMinnville Tn.
                                      Got the parallel harness finished now I just need to wait for a good weather day for the maiden flight!:bluecool
                                      • Mad Baron
                                        132 Aviation
                                        • 547
                                        • McMinnville Tn.
                                        Tomorrow is the day for the maiden flight on my Tcat!
                                        • farmflyer
                                          • Mar 2015
                                          • 1164
                                          • Quitaque Texas
                                          Good luck I think you will like it I love mine.
