    How goes it Charlie??? Doing any good??? ;)
      Originally posted by Mad Baron
      Saturday is the hopeful flight of my tcat:Sweating:
      Best of luck to you Bro!!!! The wind is gusting over 35 mph here, so no flying for me. I think I will fly the tractor and mow the property....
        Jerry........see post #52 on my WBC Cojones thread ;)
        • Mad Baron
          132 Aviation
          • 547
          • McMinnville Tn.
          Took the cat to the club field didn't fly it I was too chicken and afraid to fly it. The wind was coming from different directions didn't feel comfortable putting it in the air but I did taxi it around. Maybe someday it will see the sky.
            It looks good, and glad you went with your feelings. When it is right, you will know, and then take her up!!! Blessings Bro!!
            • themudduck
              -TMD- Foaming at the Mouth!
              • 1041
              • Burton OH (near Cleveland)
              I went to the field and it was too windy... just not having good luck with the weather lately. Well MB your cat looks real good, its all in one piece and looks like its ready to go. I hope that you'll have some nice weather to get it in the air and fly it around. Once you have some "non-dramatic" flying time with this one under your belt you are going to settle down and love it!
              • Dual Prop Dave
                Just another Prop Nut!
                • 144
                • Sunbury,Pa
                Looks good MB! Happy you stuck with it and brought it back to life! Like Hardway said, You'll know when it's right and I'm betting you'll love this bird as much as the rest of us!
                • Ole-Timer
                  Warbird Enthusiast
                  • Dec 2017
                  • 344
                  • New Brighton, PA
                  I love flying the Tigercat on calm days but dislike it in windy conditions, especially when the wind is shifting around. I have no gyro installed and the wind plays on those big draggy engine nacelles and the tall fin n rudder causing it to waller back n forth a bit. By comparison the P-38 is a missile and could care less about wind.
                  • Gunner28
                    Novice
                    • 20
                    • GA
                    i think I’m going to go ahead with a gyro in my Tigercat. I flew the 1600mm Spitfire Saturday in 6-10 mph without a gyro then with a gyro. No comparison in the level of enjoyment with the gyro especially when landing.
                    • Mad Baron
                      132 Aviation
                      • 547
                      • McMinnville Tn.
                      Thanks for all the encouragement. It didn't look too bad once out in the sunlight the plane looked good even with the repairs.
                        I have an A3-L in the Tigercat and the P-38. I really appreciate the gyros when the wind picks up... It makes a difference for sure!!! More so on the Cat!
                        • Gunner28
                          Novice
                          • 20
                          • GA
                          Am I going to have to have a 7 channel RX? I just bought a new AR 620 for this tigercat. I don’t want to lose flaps.
                          I have AR636 I tried in Spitty and had to lose flaps. Also have Aura 8’s but looking for something less expensive and doesn’t require a pc or iPhone to tweak.
                            To keep it full boat 6 channel, 4 plus gear and flaps, I use the Spektrum 8 channel with telemetry (79.00-89.00)? I put the gyro on / off on channel 7 (aux2)… Then I use the other channel port (aux3) and the battery port for my 20amp BEC from CC. It has two leads...
                            • DPF4052
                              • 8
                              One aileron / one flap I know there are two of each, but since you are controlling each set with one channel each on the receiver, it is One/One...
                              Thanks to you and OV10 for your responses.
                              • Mad Baron
                                132 Aviation
                                • 547
                                • McMinnville Tn.
                                I was not satisfied with my first parallel connector so I made a new one it is smaller with no wires just 4 xt60 connectors and 2 battery bars that I used from my rc car racing days. Just need to get some heat shrink tube to insulate it.
                                • fhhuber
                                  • Aug 2015
                                  • 1476
                                  Liquid electrical tape... Lowes or Home Depot.
                                  • Fallguy44
                                    • Nov 2018
                                    • 52
                                    Those that have used minwax, Varathane spar urethane or similar, have you had any peeling issues? Thinking of doing this to the Tigercat and my F8F Bearcat. Post some pictures if you wouldn't mind.
                                      • 7340
                                      None whatsoever.
ID:	161512Click image for larger version
ID:	161513Click image for larger version
ID:	161514Click image for larger version
                                      And the list goes on. I use Minwax Spar Urethane gloss, which just absolutely rocks and Minwax Matte for the dull effect. EVERYONE of my planes has a coating of Minwax or Varathane with the exception of My Little Gal, who only has it on the wings as the rest is Flite Metal. I'm currently resurfacing the P-40 as the wings were badly gatored right from the get go, poor quality, I really should have sent them back. I'm layering Minwax Spar Urethane on them, to fill in the gatoring. I have two coats on them now and aiming for six, that should clear it up, worked wonders for My Little Gal, the wings look wet. The trick is to use a brush and put it on fairly thick, then hit it with a hair dryer all the while, watching for runs. I sit the tail up so the wing is level overall.
                                      • Fallguy44
                                        • Nov 2018
                                        • 52
                                        Thanks! So the hairdryer helps it to dry quickly? What heat setting?
                                          • 7340
                                          Heck, I just crank mine up to full and hold it about a foot back and keep it moving. It's a Wally World cheapy, bright pink to boot, but it does the job!
                                          Just finished putting on layer five over the P-40 wings as they are badly gatored, just as thick as I could get away with, and drying it, later on tonight, I'll add layer six, then let it dry until the weekend and wet sand them. We'll see what it needs from that point. I'm using the Minwax Spar Urethane Gloss, talk about the wet look!! Up until now, I've had the P-40 in a flat finish, but I'm really liking the gloss look, so I may go with that for a while, I can always spray it with the Minwax Matte finish if I change my mind.
                                          The other great thing about coating your airplanes is that it adds the UV protectant and coats the decals so they don't peel.
