    • 8817
    Thanks Brandon.
      • 7387
      [QUOTE=OV10;n52291]After several hours of research, have decided on the livery for me and of course it had to be Navy.
      OK Callie, here's another one to add to your files.
      Of course, I just naturally assumed that!!
      So what do you think CB, are you going grey are some sort of silver??
      If silver, I think I posted the Acrylic I used on Old Crow, it's a perfect match, plus a Sargents brand which is slightly different if you want to alter the color slightly it should be posted in the painting section.
        Dan.......a silver-gray blend
        • Brandon Moon
          Fly, Enjoy, Have fun!!!!
          • Oct 2013
          • 335
          Flap to Elevator mixing for flap deployment
          I did mix 2mm of down elevator to the 1/2 manual recommended flap setting and an additional 2mm more to the full flap manual recommended setting per Alpha's recommendations. He was dead on correct with these measurements in preventing the nose from pitching up when flaps were deployed at either setting.
          Brandon Moon
          • Brandon Moon
            • Oct 2013
            • 335
            Battery placements and sizes
            She's pretty roomy for her size and I had no problems fitting the admiral 4000's. However...I did have to re position the battery straps to fit them better over the center of the batteries based on my placement of the to get the desired CG between 65 and 75mm.
            A 4000 admiral is the biggest (Thickness wise) you can fit under the nose tray lip and it will require removing about 1/8 inch of foam from the tongue to allow it to fit under that lip....but you will also notice that I have the noose battery positioned much further back and actually overhanging the tray by almost half....so it's not even under the forward hatch lip at all.
            Brandon Moon
              Originally posted by Fast Eddie
              Now Headed over to the air museum that has an airworthy F7F-3. Will post close up photos.
              Yes, please! I'm excited for this! I'm curious which BuNos you're talking about...
                • 7387
                Sounds awesome Charlie! You'll know which one is yours in the crowd!!
                • Fast Eddie
                  • Oct 2016
                  • 119
                  • So.Cal
                  Here is some photos I took today of our local Tigercat. One of our R/C club members works there, but he was off today, so I will schedule my next visit when he's there so I can get some cockpit photos hopefully.
                  • Fast Eddie
                    • Oct 2016
                    • 119
                    • So.Cal
                    Here some more.
                      • 7387
                      Thanks Eddie!
                      You should see if you can get a picture with yours in front of it when you're finished building.
                      • Fast Eddie
                        • Oct 2016
                        • 119
                        • So.Cal
                        Thanks Eddie!
                        For sure, I can make that happen, especially if I go with the same livery, that would be awesome. This museum is a living museum, most aircraft fly, many aircraft from Pacific and European theaters. The B-17G has been static for about 5 years now, but soon will be in the air again. Was able to climb all over it on the inside today. Very impressive. P-51 rides will be available next spring as well as the C-47.
                          I love this bird! If I recall correctly Brandon Moon was looking at King of the Cats as a possible repaint livery option once he completed his two seater canopy mod. Very jealous of your location to be so close to a well loved and airworthy Tigercat. Seeing the serial plate is interesting because that conflicts with the warbird registry online. Proof is in the pudding!
                          • Fast Eddie
                            • Oct 2016
                            • 119
                            • So.Cal
                            Yes, pretty fortunate to have this less than 20 minutes away.
                            To everyone here, If there's any part or angle of the plane you want and I did not capture, let me know, and I'll make sure to take pics and post them next time I'm down there. I'll work on getting access to cockpit for pics.
                              • 7387
                              Where is that museum Eddie?
                              If they're offering P51 rides, that's on my bucket list.
                              Getting an F7F-3 is first though. Might take a few years but......
                              • Fast Eddie
                                • Oct 2016
                                • 119
                                • So.Cal
                                Palm Springs Air museum. palmspringsairmuseum.org
                                Another bonus is about 90 minutes away, the Planes of fame museum in Chino Ca.
                                • Brandon Moon
                                  • Oct 2013
                                  • 335
                                  I thought about it, along with "Here kitty Kitty" but I'm going to be doing something a little less scale (Livery wise) and more personal like, but realistic
                                  Brandon Moon
                                    For a fantasy scheme, I like this one. Although the numbers are all over the place, the scheme itself is neat and eye-catching.
                                    • Brandon Moon
                                      • Oct 2013
                                      • 335
                                      yep, like that one to...or these
                                      Brandon Moon
                                      • stitch
                                        • Dec 2014
                                        • 142
                                        well i just ordered one,ol, lady going to kill me i got 28 planes 17 are motions lol have not flown but of them hahaha! but could not pass this one,wanted the bear too but i like this one much better! wonder how many more they have before there gone on this batch?
                                        • stitch
                                          • Dec 2014
                                          • 142
                                          my 4 key sticks.i only flown 4 this year. got all planes this year too!
