  • Phatbob
    • Apr 2013
    • 118
    • Baldwinsville, NY
    Originally posted by Fast Eddie
    Which plane did the drop tank come from?
    FMS Corsair
      I like it alot
      • Fast Eddie
        • Oct 2016
        • 119
        • So.Cal
        Originally posted by Phatbob
        FMS Corsair
        Thanks
        Eddie
          • 7340
          Looks great Beeg!!!
            Originally posted by Beeg
            I'm going to call it good. This is taking way too much of my time.
            But that is all part of making it not look like everyone else's and with a great scale depiction to boot.......very nice job Beeg !!!
            • Beeg
              • 1335
              • Texas
              Thanks guys. Tigercat air tankers have been kind of special for me since I was a little guy. Back in the 70's, they used to fly over my house on the way to the fires in the Cascades. All the other tankers were pretty cool as well with their roaring radials but the Tigercat would make two runs for everyone else's single run. It really moved out.
                They are fast indeed
                • Wesnc
                  • 52
                  • Orange NSW Australia
                  Maidened my F7F on the weekend, beautiful plane great flyer, two clicks of up trim was all that was needed.
                  I wanted to share the battery arrangement I ran with: 2 x 4500mah 4s 45c. Balanced using Great planes CG Machine perfectly as per the attached photo on the rear battery deck. (transitions to nose heavy when the U/C is lowered)
                  I mounted the rx to the underside of the canopy, however if you had extension leads you could swap out the provided ones, run the longer leads under the rear battery ply (as per nose wheel servo leads) and mount the rx on the unused front battery deck.
                    • 7340
                    Hey Wesnc, welcome to the Forum!!
                    Great to hear the Tigercat is working for you, a great airplane!
                    Keep us posted as to your flights, must be nice to be in the middle of Summer!!
                    • Beeg
                      • 1335
                      • Texas
                      Making a new VOR antenna characteristic to most F7F air tankers though some had them on the nose.
                      • Phatbob
                        • Apr 2013
                        • 118
                        • Baldwinsville, NY
                        What is your cg setting? I was using the same configuration.
                        Thanks
                          I saw this on RCG...
                          and it inspired me to do this...
                          Click image for larger version  Name:	20170117_153219000_iOS.jpg Views:	1 Size:	128.4 KB ID:	58250
                          Click image for larger version  Name:	20170117_153306000_iOS.jpg Views:	1 Size:	132.6 KB ID:	58249
                          I used the tanks and mounts from an E-Flite 1200mm Corsair so they'll slide right off.
                          Click image for larger version  Name:	20170117_152632000_iOS.jpg Views:	1 Size:	136.9 KB ID:	58251
                          Click image for larger version  Name:	20170117_202348100_iOS.jpg Views:	1 Size:	59.4 KB ID:	58253
                          Click image for larger version  Name:	20170117_202330429_iOS.jpg Views:	1 Size:	69.8 KB ID:	58252
                          • Phatbob
                            • Apr 2013
                            • 118
                            • Baldwinsville, NY
                            Nice! I used that same wing strap to mount my bombs.
                              Those look great!
                                I had a buddy make a drop system with his fms zero that worked great. I was thinking about doing a setup like it to drop the tanks on my p38. Just need a micro servo and some piano wire, and a couple of small wire loops. Simple, and it works every time
                                • Wesnc
                                  • 52
                                  Thanks for the warm welcome Grossman56. Very hot here currently.
                                  Hi Phatbob, I C/G'd as per the manual @ 73mm.
                                  • Phatbob
                                    • Apr 2013
                                    • 118
                                    • Baldwinsville, NY
                                    Thank you !!
                                    • Wesnc
                                      • 52
                                      Anytime Phatbob, I kept doubting myself as I hadn't seen it configured that way before....but it balanced & flew beautifully!
                                        Thinking about possibly running a single 5000 like I do my p38. Wonder if it would still balance out?
                                        • Phatbob
                                          • Apr 2013
                                          • 118
                                          • Baldwinsville, NY
                                          Probably would balance if it fit. All kinds of room up front. I went to a single 6200 on my P38.
