Ah, I see what you're saying. As someone who has never played around with flight modes, I can see the benefits from it. Setting the flap switch to activate flaps and flight modes makes sense.
(Dangerous Dan)
That's one way to do it, however, there is another that is much better and easier to do. I've found virtually all experienced pilots use this method (not saying I'm experienced, but they all taught me it-especially those flying big expensive turbines).The flap elevator mix is fairly simple if you set your radio up to trim the flaps on the fly. I recently found the video on just how to do this.
No more guessing and landing to readjust. Check it out.
The one thing I did find is that my NX 8+ trims the nose up if I push the slider up and down if I push the slider down, opposite to what he has. Check on the ground first to confirm which direction is which.
(Dangerous Dan)
All Spectrum and most other TX's ket you set up Flight Modes (not to be confused with FM's on a Spektrum RX). Go to flight mode setup in the menu and select FM switch. Then select your flap switch. This gives you 3 FM's assuming you use say switch D, your 3 position flap switch (the IX TX's will give you 9 seperate FM's, but that's another story). Now go to Trim Utilities. Leave throttle as common digital, but on elevator change it to FM. Also do aileron to FM, rudder you can also, but not necessary as flaps won't affect rudder. You're Done!
What this does is at each flap position, you can separately trim both elevator and aileron in flight to your preference and it keeps those trims individually at each flap setting and allows you to adjust on each flight if you need to for changing conditions. The elevator compensation you initially set stay where you started, but those are just a guess starting point. Elevator is a must, aileron is suggested as well in case each flap does not deflect the exact same amount, which in my experience is the norm, not the exception.
This, IMO, is the SINGLE most beneficial TX setting for any aircraft with flaps. Forget setting up mixes as the above video suggests, use FM's for flap trimming as TX programmers intended it for, not just elevator but also aileron. Using mixes, how crazy, like using a 500 foot extension cord to plug a lamp in 2 feet from the outlet! Keep It Simple!
All my aircraft with flaps have this set up, one of the first things I do when setting up a new plane.
Takes me 1-2 minutes on a maiden to perfectly trim a new plane with flaps for consistent level flying in every position from then on, no landing, retrim, do it again for ever! And if you decide to alter any flap deflection later on, simple retrimming operation.
My 2 cents for the day.
(Dangerous Dan)Leave a comment:
the problem you are experiencing is CTE (coefficient of thermal expansion). the steel pushrod changes very little with temp. but the foam fuse expands greatly with temp. so i would bet the last time u flew it it was colder than today.Leave a comment:
Maybe a 1/8"? CG is about on the black pinstripe but it's not critical so +/- 1/4" at least.Leave a comment:
Hi all - flew my plane 3-4 times and it seems to need a lot of up elevator trim (64 on a Spektrum radio) to get the nose to stay somewhat level. I even tried moving the battery back from the book CG to see if that was the issue, but still get it to want to nose down all the time. Flight surfaces all are level (flaps, ailerons) and everything looks aligned per the book. Any thoughts here?Leave a comment:
Almost lost mine on the maiden in 2017. When we got it up in the air it would fly ok then suddenly do an uncommanded wingover, or try to. Finally got it on the ground and with another flight decided that something was messed up with the flap servos. Randomly, one flap would go full down, and then back up again, then the other. Totally crazy! I went to MRC about it and they said they had a few other people around the country that had the same thing. The fix was that they sent me two new flap servos, and I haven't had that problem since. They are still in there now.Leave a comment:
I agree with chabd. I have had my 1600mm Flightline Spit for 8 years now, and set them up from the beginning with scale positioning of flaps up or 85 degrees flaps down for landing. I have found this works very well for my model. And, it looks realistic and cool, too!
On real aeroplanes flaps produce lift and little drag for the first 10 to 15 degrees of movement. After that the drag produced increases significantly while any extra lift produced is negligible. At the same time as flaps extend the centre of lift of the wing moves rearward, therefore the nose drops. As mentioned Spitfire flaps are drag flaps, at full extension they have an angle of 89 degrees, if memory serves.
And there was only full extension.
That said I do use them on the model as flaps and have them on a slider.Leave a comment:
On real aeroplanes flaps produce lift and little drag for the first 10 to 15 degrees of movement. After that the drag produced increases significantly while any extra lift produced is negligible. At the same time as flaps extend the centre of lift of the wing moves rearward, therefore the nose drops. As mentioned Spitfire flaps are drag flaps, at full extension they have an angle of 89 degrees, if memory serves.Leave a comment:
i agree with you 100%! BUT my flaps are all mixed now so i don't have direct visibility to this but my flightlog has in bold letters in the header "requires 16 clicks of up elevator with flaps". all my other planes have the click count in the pro's because they are as expected.
Joe
Yes, most of the Flightline and FreeWing planes that had decal choices now don’t. I think the B-25 and I know the Mirage come with decals not applied or at least not all.
Worse a lot of the Flightline planes are gone.Leave a comment:
Thanks for digging that out.. shame they've decided to do that. More work for them for no reason.https://www.motionrc.com/products/fl...an-pnp-flw303p
OMG,
According to the Q & A page on the Motion RC website, all markings are in situ.
If you're doing a repaint, it shouldn't matter much, but it will be a bit more work.
Best, LBLeave a comment:
I read a post from last year that indicated these models are now coming with decals pre applied. Can anyone who has purchased one recently confirm or deny? I've been hankering after one for a while but would really like to use my own markings.Leave a comment:
