    Don't know if any of you Mustang lovers down in Texas saw this yet, but here's a good deal....
  • seaviper
    Yeah I figured that. Today I found that the guide tubes for the elevator and rudder pushrods were not glued in the fuselage. The controls were extremely spongy due to the unsupported pushrods bending.
    So I went and glued the tubes in correctly. I also dispensed with the EZ connector on the elevator since it was in too far on the servo horn for proper throw, Put a z-bend on the rod and moved it to the outer hole on the servo for perfect operation.
    The rear end is now sturdy enough for flight.
    Another thing was the blades came out of the box pretty darn close on balance. But the spinner was another story. Anyway, she is balanced and ready.
    I'm running my Admiral 4s 3600 flush with the forward end of the battery tray. The CG is spot on.
    Hope to maiden her tomorrow if the weather will cooperate.
    I recently replaced the main struts on my Stinger 90 because they were worn out and those were the parts I kept from the old set and added to the new ones to give double the support. Your best bet is to find a M3 (I think) shoulder screw and cut it down. Leave the shoulder part a little long so it protrudes past the edge of the strut and you can tighten or loosen them with pliers if need be.
  • seaviper
    While building the P-51, I noticed that the retracts struts have these fully threaded screws acting as followers for the compression action. Mine were both loose (because the threads were biting into the channel) and the compression was not smooth.
    I replaced them with these smaller smooth-headed screws from a Freewing T-45 nose gear strut. These work much better.
    Click image for larger version  Name:	20171221_213919.jpg Views:	1 Size:	94.9 KB ID:	109859 Click image for larger version
    Does anyone know where I can get more of these little screws? Maybe someone from Motion can chime in?
    I also added a small bead of Foam Tac to the foam hinges. And, I went ahead and glued the tail components with Foam Tac since the screw attachment didn't seem so secure. Overall though, I like the plane. Can't wait to fly her.
  • Shirty
    Awesome grats! Nice choice, the blue nosers fly best! ;) (Don't oook at my avatar, I'm not biased at all...).
  • seaviper
    My wife told me I am getting a 1450mm P-51 (Petie 2nd) on Monday as a Christmas gift!
    Looks like I will have to transition from Jets to warbirds. I cannot wait!
    Hey ICM, I have a D and a B. The D has a 580 and the B has a 650kv.
    If you are going to upgrade the motor, go with the 650. There's not a big difference between the 540 and the 580 and yet not another big difference between the 580 and the 650, so if you really want to notice the change that you invest in, go for the 650 out of the FMS Tomahawk.
    Heck, my next step is to try the 6s system out of the FMS P-47. Saw Warbird Charlie's P-40B with the P-47 6s system at Nefi and it was unbelievable! So, if it can work in the P-40, no reason to think that it won't in the P-51.
    Grossmnan56
  • Shirty
    Best of luck :)
  • ICM
    Thanks to all who replied. I think I'll go with the 4s 4000 40c and see how it flies. If all is good I'll then install the sound. I suppose I can do the zip tie or drop in 580 kv if necessary.
  • gooniac33
    Originally posted by ICM View Post
    Just got the FMS 1450 P51 D v8 with stock 540kv motor and an Aspire sound sytem with 2 transdcucers and now choosing a battery. I intend to install the transducers near the cg just to the rear of the battery bay as shown in Andrew's video on Motion RC. I'm not interested in mods for extra performance as I want to fly it scale with the ability to to do scale maneuvers and 5-6 minute flight times or more if possible. After reading this thread, battery recommendations are all over the place, complicated by zip tie and motor mods. I'm looking at Admiral 4s 3600 40c (recommended by Motion RC website for this plane under specs), Admiral Pro 4s 3600 50c, or Admiral 4s 4000 40c. Given my parameters, what would you guys recommend?
    The Zip tie mod is not going to affect flight time much but will affect the way it flies in a very good way. You will have extra weight with the sound system so the mod will only help. I too use the stock motor and use a Roaring Top 4s 35c 5800mah and China Hobby Line 4s 30c 6200mah pack. The plane flies very scale and for 10-15 mins at full throttle the whole time! Now I also use a 5s 30c 4500mah pack in the plane too. I can get 8-10 mins flight time with that pack...
    Yep, I prefer the 4000 as well, slowly converting over to them.Lost two 4000's:Angry: at Nefi!!
  • quitcherbitchen
    +1 on what Charlie said. Mine won't balance without using a 4000 G-55 from China Hobby. My 3300s need a 1300 3s battery taped to them to make it cg the same.
    The 4000 40C is your best dollar value for giving extended flight time over the 5 dollar cheaper 3600 40C and is the go to Lipo for use in other 1400 size warbirds as well as in the Tigercat and Lightning twins.
    I have yet to find a prop warbird that needs a 50C battery and as C ratings increase you pay more for that premium.
  • ICM
    Good to know, I have a 4000 40c as well, the 4500 's would fit in perfectly with the Avanti as well, thank CB
    Originally posted by Grossman56 View Post
    I got thinking about upgrading the motor in BBD to the Razorback motor and running 6s. I already have an 85A Mantis in her so it would be a basic engine swap. So as a matter of interest, I started sizing up what 6s battery would fit in her. I have some 3300's and they seem to be a pretty good fit, the 4000 PRO seems too big. What are you using in your P-40 CB??
    4500 40c
    On Motions battery page (filter 6S only) the 4500 40C and the 4000 60C Pro are side by side for size comparison.
    That PRO is just a BRICK and truth be told is way more C rating than needed for any of your birds(including the Avanti).;)
    That 4500 will fit nicely in BBD's batt tray.:Cool:
    Flight times average 8 minutes and you saw my throttle management style on the Warhawk.
  • e4dragongunner
    Thanks OV! :)
    CB took the motor/ESC right out of the P-47 Razorback and stuffed it in the P-40. I have personally seen this plane fly and in my opinion, this would have been the hottest plane of the year if it had been released this way. There were at least three of us watching right by Charlies's side when he went vertical at Nefi and we all lost track of it before it stopped climbing. Loops are amazing!!
    Definitely something to consider, although I haven't heard of anyone trying it with the P-51, I can't see any reason why it wouldn't work.
    One other thing, I replaced the prop shaft when I went with the 650 kv with a shaft that Charlie recommended and there is no extra gap, can't remember the stock number but its worth adding to the parts list.
    It's the shaft from the Olympus:
    e4DG...............as Gman noted it is the stock FMS 1500 P-47 Razorback power set up is what I used and will certainly give those Stangs a kick in the butt.:Cool:
