    • 7430
    Thanks Rex
    Dan
      • 7430
      Panel lines, panel lines, panel lines! I swear they take the longest of the detail work and probably the least noticed !
      This represents three plus hours of work a bit at a time because you start losing your 'edge' after awhile.
ID:	448938 Click image for larger version
ID:	448939 Click image for larger version
ID:	448940 Click image for larger version
      Since I filled in the panel lines a few years back when Chris the RC Geek was doing his P51, I had to redraw them on the whole airplane. I used a fine tip Sharpie and painted just to the outside of the line to give the illusion of the end of a panel. Turned out pretty good so far
      Dan
      • jetfool
        • Nov 2022
        • 1367
        • Crawfordsville, Indiana
        Grossman56,
        Excellent job, Dan..Looking more realistic every post.
        Best Regards, Rex
          • 7430
          Thanks Rex, yeah I hang around Dave too much
          Click image for larger version  Name:	t725.png Views:	0 Size:	81.6 KB ID:	448944
          Just finished an N9 Gunsight for her as well, then I can seal the canopy on. It ain't perfect, but when you reduce the size (17.8mm length x 10.3mm width x 13.49mm height)
          it's not going to show too many mistakes. Anyone wanting an STL file for it, let me know.
          Hey, it ain't no hoola girl, but it'll do
          Dan
            • 7430
            Oh, and just 'cause you care, How'd you like to be an enemy pilot, look in your rear view mirror and see this.... Click image for larger version  Name:	20260524_142716a.jpg Views:	0 Size:	81.0 KB ID:	448946
            Grateful Memorial Day everyone.
            Dan
              • 7430
              The riveting has begun!
              In the pics, the fasteners on the nose appear as silver from being opened and closed for maintenance, so... Click image for larger version
              There was also this little panel just behind the exhaust stack so I added that in too. I plane to position the gun camera in the wing as welll
              Dan
