Official FMS 1400mm P-51D V8 Thread
    • 7430
    Originally posted by possum
    Hi,
    I am new to this. I have the FMS 1400 P51 and would like some advise on how to get a bit more speed out of it. It seems a bit sluggish to me.
    Thanks Possum.
    Xviper is right. I have all my Mustangs (2xFMS and 2xFreewing)running on the 650 kv with an 85A mantis ESC and they perform great I also did the zip tie mod on the prop which will give it a bit more pitch which helps as well. In case you don't know. you cut a zip tie and put the piece behind the prop blade at the front of the blade to increase the pitch when you tighten the blade back down on the spinner. You don't have to use a very thick zip tie, I used the thinnest ones I had laying around just to see and it worked out fine.
    • JamesonC
      MRC fanboy
      • 619
      • Laurens, SC
      I converted mine to 6s with the 550kv Olympus motor.
      Stock speed - 67mph
      Current setup - 93mph
      Much more like it!
      • handyman220
        • 160
        Way late to the party here, but I have a couple of the FMS V8 Mustangs both B & D versions. I'll have lots of reading to do before assembling mine. Glad I bought them while they were available. :Whew:
          • 7430
          Great airplanes! I have both as well and have been flying them for going on 4 years
ID:	204984Click image for larger version
          • handyman220
            • 160
            I hope mine are still flying after 4 years. I have Snoops Sniper, Dallas Darling, & Big Beautiful Doll. Bought a couple spare props, spinners and retracts along with the aluminum spinner back plate. Should be good for a while I think/hope!
            • Flyboy69bond
              • Jul 2019
              • 3
              Anyone having problems with lights on Freezing P-51 Old Crow Mustang? Can't make mine work either using the year sequencer or direct to receiver using Aux channel. Tried a second new lighting module, still no luck. Wired per I installation video from Motion RC. Need help
                • 8834
                Did they ever work? Some of these LED lights don't work well if hooked up directly to a RX or to a servo tester. Too much juice. If you did that first, they may have burnt out right away. Also, if you hook them up with the wrong polarity, they can burn out without showing any light. Then, if you put them on a light module, they may already be burnt out.
                  • 8834
                  My BBD is also 4 years old and still flying really well. In this video, the plane was about a year old and had just gotten the higher kv motor transplant. It currently runs the 6 cell drivetrain from the P-47.
                    • 7430
                    Check into the aluminum retract sides from Smallparts CNC. They're awesome.
                    http://smallpartscnc.com/index.php?route=product/product&product_id=193
                    You'll break a wing before a retract side
                    Also, I replaced the aileron and elevator servos with metal geared servos.
                    My P-51B lawn darted earlier this season, but I rebuilt her and she's flying again. From this...
                    Click image for larger version  Name:	IMG_4308.JPG Views:	0 Size:	137.7 KB ID:	205084
                    Back to this Click image for larger version  Name:	IMG_4371.JPG Views:	0 Size:	109.8 KB ID:	205085
                    Yep, it can be done!!
                    • Flyboy69bond
                      • Jul 2019
                      • 3
                      Followed all instructions to hook up. New plane. Did not try anything out of normal until no results. Wing lights and landing lights not working.
                        • 8834
                        The only thing I can think of is the polarity of the LED plugs. If those were inserted correctly (red wire to positive, other wire to neg.), then I can't see anything wrong unless the LEDs are duds but they can't ALL be duds. Do AIL, gear and flaps work like they're supposed to? One of those supplies power to the lights through that white box.
                        • Flyboy69bond
                          • Jul 2019
                          • 3
                          Everything cycles correctly but lights. Got me stomped
                          • handyman220
                            • 160
                            Very nice repair job. Like to see the modelers that come out after a crash! I do have the CNC retract plates already, almost forgot about them.
                              • 7430
                              Anyone know of a source for the retract pins? I've sourced out Motion, FMS and Horizon, but none to be found.
                                http://www.fmsmodel.com/fms-1400mm-p...ing-gear-strut
                                RC Castle has these too, but for just the pins...…. I came up empty too. :disappointed_reliev IDK if they are 4mm, but whatever the diameter, use some old nitro wire landing gear or music wire and cut your own with a Dremel and file the flat spots with the abrasive wheel.... Sorry Bro!! I tried!!
                                  A little P-51 action for you Dan!!
                                    Have Snoot's Sniper and the Red Tail still in the box!!
                                    • farmflyer
                                      • Mar 2015
                                      • 1164
                                      • Quitaque Texas
                                      Sorry wrong thread don’t know how to remove post🤪
                                        What did you post? There is nothing here on this end!! LOL
                                        • farmflyer
                                          • Mar 2015
                                          • 1164
                                          • Quitaque Texas
                                          I edited it out but couldn’t figure out how to delete the entire post.
