Xviper is right. I have all my Mustangs (2xFMS and 2xFreewing)running on the 650 kv with an 85A mantis ESC and they perform great I also did the zip tie mod on the prop which will give it a bit more pitch which helps as well. In case you don't know. you cut a zip tie and put the piece behind the prop blade at the front of the blade to increase the pitch when you tighten the blade back down on the spinner. You don't have to use a very thick zip tie, I used the thinnest ones I had laying around just to see and it worked out fine.
I do have the CNC retract plates already, almost forgot about them.
