  • Bearcat
    Hobby Squawk bomber Pilot
    • Oct 2017
    • 176
    • Cincinnati area
    This has been dead for months, I just picked up one up on a trade and had to dig back in memory and here for the fixes you had to do, I seems to remember my old bird flew very well with minium work, it was until I changed the tires that the problems with touching the props and ground became an issue.
    Just let me fly so I may be free
    • Jetbird
      • Jul 2022
      • 31
      My friend bought one and had me do the maiden, the plane would porpuse up and down the whole flight , I was lucky to get it down in one piece. Found the elevator servo was junk as it would never go back to center. Put a new better servo and now flies great. I ended up with the plane. Great flyer , seems like it could use more weight to it. I fly mine with a 4s 6000mah because thats what I use in my Flightline P-38. Takeoffs off nice , lands smooth as butter . I think it has more then enough power. I fly mostly at 3/4 power . Im going to change the wheels to something more scale looking , Paint the sturts silver and give a good weather job . Also need to find better looking pilots
      • jetfool
        • Nov 2022
        • 1335
        • Crawfordsville, Indiana
        I just received one new model for New Years eve. Going to follow everyone's advice to check all aeras and will add the tail shim. Out of the box w/no problems. installed rec. and checked all control functions. Everything works as advertised.
        Best Regards, Rex
        • jetfool
          • Nov 2022
          • 1335
          While checking my list of things to check on I removed the wing and labeled all the disconnects of servos under the wing. after removing wing, I found all the wing hold downs were not glued and easily removed. This will be a first priority. Reassembled complete plane and hung up until I finish my P-47. At least I can look up and see it hovering over the workbench.
          Best Regards,Rex
            • 7385
            • jetfool
              • Nov 2022
              • 1335
              Thanks for the photos. I want to paint mine like it has been used well. In pictures of the B-26 they show a lot of paint chipping and more weathered than the fighters in Europe. Planning on painting mine from the 320th bomb group with the shark mouth.
                • Nov 2013
                • 2765
                • Cody, WY
                Good choice! That will look great!
                Davegee
                  • 7385
ID:	417803 Click image for larger version
                  • jetfool
                    • Nov 2022
                    • 1335
                    Thanks Dan. I am getting all the Documation together so when I get to it, I can move right along. Send any photo's you want.
