458destroyer,
Like others have already said, I wouldn't shim the angle of the motors. The downward angle is to compensate for the under slung position of the motors, to give you a more neutral attitude when you have to throttle up quickly. If not for this, the aircraft might pitch up suddenly on a go around making an already slow airspeed scenario worst by aggressively increasing the AOA, inducing a possible wingtip stall that this bird is already infamous for. Not good at any altitude much less a few feet off the deck.
As for the mods, xviper is correct you can fly this bird with no mods whatsoever, some up elevator trim programmed in, along with a lot of expo and a reduced elevator deflection. However any time your are at flaps zero,... fly it like an edf that has high wing loading. With a take off flap setting it flies much more like any other twin motored warbird, albeit a we bit underpowered. I removed the weights, (I hate dead weight), along with a few other mods like cutting a rectangle hole in the back of the battery compartment right down to the belly of the bombbay which allowed me to move my battery back another 1 1/2 inches. I fly her on a 4000mah 4s pack, with a CG of 72mm. Some of us can't get a bird without modding it. But I had about 7 or 8 "exciting" flights on her before modding her to a much more docile flyer that she it now. I'd encourage you to use a light pack and fly her before doing any mods.
