Discussion Thread: Heng Long 1/16 Scale "Panther G" German WW2 Tank
That is a older 5.3 standard steel gearbox. I like those better then the new 6.0 standard steel gearboxes. They are IMO just as tough, a bit quieter and smoother. The difference is the steel gears have a black coat and are cut with slightly cleaner hence they seem to run smother. I would by the 5.3 steal gearboxes over the 6.0 any day.Comment
I didn't know gear box have different versions. Will this gear work with my 6.0 board and do I have to exchange out the left (working) box as well ? Dai
I replaced the gear box and the tank runs fine. I had to reverse the red/black connections to get the right control. You are right, the 5.3 gear box looks more refined than the 6.0 version. The latter looks crude while the former looks to be better quality. Dai
Just purchased this new Heng Long Panther G Professional Edition Tank from Motion RC and wanted to share my upgrade process as it may help others. This is my first RC Tank so please feel free to offer any suggestions or helpful comments...Thanks !12 PhotosComment
Welcome Studiocat13.
Great Job! Thank you for sharing...
Did you seal the battery box somehow to prevent any possible water from damaging the cotton for the speaker? Did you separate the speaker/cotton from the battery/wires? I like your mod for slowing down the turret speed.
I like my Panther G quite a bit although I haven't done much modding besides adding metal road wheels and paint and weathering.
Good stuff, keep it up!
ChefComment
I like the use of the battery box for the speaker. I usually end up cutting the battery box out and creating my own speaker box, but in a pinch that way would be quicker.
On the gearbox issues I would replace them both at the same time personally as then it mitigates any chance that there are differences in the gearboxes causing the tank to pull to one side or the other when driving straight. I would use the old gearboxes for spare parts. I guess it's all up to you though. You could also put the old ones up on Ebay as "Broken for parts only" and recoup some of your money as long as you remember shipping and Ebay fees are high these days.
DerekComment
Thanks Chef, Its coming along ! As for the battery box, I just have some foam weather stripping on the door currently but after I am satisfied with everything I plan to completely seal the door with silicone. With the speaker being low voltage, there is no real need to separate the speaker wires from the cotton filling and the battery leads have been relocated to the inside of the hull. And yes, the turret speed mod worked out quite well ! Would love to see some pics of your tank when possible.Welcome Studiocat13.
Chef
Thanks again !
Tank looks great Chef ! I am planning to do pretty much the same thing as far as painting the wheels just a different color layout. What did you use to paint and weather the metal tracks ? Also, where did you score the bucket for the rear ? Thanks !
The tracks I use Gun Bluing fluid then weather and paint to finish. Heres the fluid I like best- https://www.brownells.com/tools-clea...g/oxpho-blue~/
I've tried several bluing fluids and like this one the best. I buy the big bottle 32oz. it's more cost effective and provides at least 4 to 5 sets of tracks if not more.
Heres a video showing how to blacken/weather metal tracks with another fluid. The Brownells stuff does the same thing and is cheaper by volume-
The buckets you can get lots of places I had a few left over from Taigen Tanks- https://www.taigentanks.com/collecti...ket-set-1-pair
Did anyone figure out what these parts are for?Okay, I have three plastic parts left over and I have, to the best of my knowledge, gone through the instructions and I do not see where parts #8, 9, and an unnumbered part should go. I have attached pictures of the parts in question. On page 6 of the manual parts 8 and 9 are shaded. Part Private Messages (item on the left in the picture) looks like a periscope. Part Albums (item on the right in the picture) looks like a rangefinder. I have no idea as to what the third part is (center).
Warbirdfan, great looking Panther. What color(s) did you use on the towing cables? How did you attach the jerry can? Any other color suggestions for the accessories?Comment
