  • 761st
    • May 2022
    • 392
ID:	346088 I always liked this picture.
    • SoCalBobS
      • 2761
      • Southern California
      great composition!
      • 761st
        • May 2022
        • 392
        Thanks SoCal. I always like an "in the field" moment.
        • SoCalBobS
          • 2761
          Some American tanks (and one surprise) driving by the camera.
          • 761st
            • May 2022
            • 392
            Very cool SoCal. I like your tanks. Pershing is the (another one) I want. That terrain is perfect. To me this tanks belong in the turf. Once I get the dio sorted out I will take some videos. Is that a 75 in the Sherman?
            • SoCalBobS
              • 2761
              The Pershing has been a project for me. The only way I could buy it is as a static model. I had to add a main board, a smoker, and I upgraded the gearbox and tracks to metal.
              Good eye! The Sherman sports a barrel sold as a "Fury" by Toucan. In reality it is (was) the Panther 76 long barrel. I cut it down to a reasonable size. On this tank, authenticity takes 2nd place to battle-worthiness. I added duckbill tracks for traction, and the barrel was shortened so the turret could traverse in tight spaces, or travel over rough terrain.
              • 761st
                • May 2022
                • 392
                Well done on all of them! Where did you get the M3? I may end up getting a static Pershing next. I still have not started on my static Panzer V, I will look up the Fury barrel. Thanks. I find that the detail I put on my tanks is quickly knocked off when my 7 yo tank commander is driving. Hhahahaha!
                • quitcherbitchen
                  • 928
                  • Altadena, CA
                  I bought a static Pershing as well. I am keeping the nylon gears and tracks for now. Seems to be a reliable tank so far.
                  • SoCalBobS
                    • 2761
                    Neither is critical, but if there is a lot of climbing or bulldozing through thick brush, the nylon gears can slip or grind. On relatively smooth or level ground, no problem. The metal tracks lend weight for traction and stability, but again not needed on regular driving. The Pershing is one of the tankiest looking tanks, that's for sure.
                    • quitcherbitchen
                      • 928
                      • Altadena, CA
                      It is slow with the nylon gears and stock motors. The real one wasn't a real speed demon so I guess it is scale.
                      • SoCalBobS
                        • 2761
                        Yeah definitely a compromise between "fully detailed" and rough and tumble". The M3 is a conversion kit from Vandramodel.Hu, built on a Heng Long M4. There's a thread about it around here somewhere.
                        • 761st
                          • May 2022
                          • 392
                          Spray painted the mesh container from my bag of oranges. Close enough for a diorama set up.
                          • cpt.chaos canada
                            • May 2022
                            • 105
                            • Aulds cove, Nova Scotia, Canada
                            Hi all,
                            a lil late to the party but here are my first paint scheme attempts from last year.
                            Done with artistic water colours, they won't last long but are a cheap way to try IMHO.
                            CCC :star_struck:
                            • 761st
                              • May 2022
                              • 392
                              Great paint schemes and photos!
                              • cpt.chaos canada
                                • May 2022
                                • 105
                                Thanks,
                                like I mentioned the use of watercolors is cheap and gives you a chance to play with different scheme ideas.
                                If you don't like it, wash it off.
                                That's just one tip from a new tanker to another, eh.
                                I'll be looking into airbrushing way later.
                                Will try other methods as well.
                                Saw a video were someone was smearing acrylic paint with the use of a finger glove onto a sherman.
                                Turned it into a nice weathered look that way.
                                CCC
                                • cpt.chaos canada
                                  • May 2022
                                  • 105
                                  That is a cool Idea, may use that for a winter camo with a bit netting rolled up.
                                  CCC
                                  • Rubicon99
                                    • 3318
                                    Screen shot from M41 “getting air” during play day on test track. One of the toughest HL tanks a person can buy.
ID:	346364Click image for larger version
                                    • 761st
                                      • May 2022
                                      • 392
                                      CCC - I will be trying that on my Panzer IV build. Great stuff. Yes, the mesh works and is cheap.
                                      • 761st
                                        • May 2022
                                        • 392
                                        Rubicon - Your proving ground is set up nicely. Your Sherman is crazy! Great shot!
                                        • Zippersnapper
                                          Insane Unknown
                                          • Mar 2021
                                          • 502
                                          • SW Texas
ID:	346414Click image for larger version
ID:	346415Click image for larger version
ID:	346416Click image for larger version
