  • Sorry i had posted the same thing 2 times
    Last edited by PetitRic760; Aug 23, 2024, 12:14 PM. Reason: Posted 2 times the same thing sorry
    • Originally posted by Meter Rat View Post
      Took the Challenger and T72 down to the beach just for a fun run. Click image for larger version
ID:	408836 Click image for larger version
ID:	408837 Click image for larger version
ID:	408838 Click image for larger version
      Does running in sand makes your tracks come off?
      • Originally posted by PetitRic760 View Post
        Very fine dry sand, or hard packed sand. No. Very wet sand or sand with small stones in, will fetch the tracks off.
        • Definitely very small gravel is much worse for causing de-tracking than dry sand. It's murder on idlers
          • Jagdtiger all finished. Even had a General Staff officer show up for a photoshoot 😀
ID:	409479 Click image for larger version
ID:	409480 Click image for larger version
ID:	409481 Click image for larger version
            • That is a fantastic job you have done on this.
              • A wee run out for my T72, and Challenger. The T72 is a lot more nimble than the Challenger. Click image for larger version
ID:	412147 Click image for larger version
ID:	412148 Click image for larger version
ID:	412149 Click image for larger version
ID:	412150 Click image for larger version
ID:	412151 Click image for larger version
ID:	412152 Click image for larger version
ID:	412153 Click image for larger version
                • Meter Rat
                  Very nicely done, Sir.
                  Best, LB
                  • My Churchill Mk VII in desert camouflage with the fenders removed. Based loosely on photos online. It participated in the San Diego event on November 24th. Acquitted herself magnificently.
ID:	414744 Click image for larger version
                    • Took advantage of a day off work, and the wee bit of snow we had, to give the T72 a run out.
                      • Sharing a photo of my entire tank collection. I've since added a Tamiya M4 Sherman 50th anniversary release, but with several tanks needing my attention, I am in no hurry to build it.
                        Foreground to back:
                        Tamiya KV-1
                        Hooben T-55 (converted to Tamiya DMD T-08 MFU)
                        Heng Long T-90
                        Tamiya Tiger I
                        Tamiya Panther G (Danville VA veteran)
                        Tamiya Leopard 2A6 (converted to Ludwig 2A4 turret)
                        Tamiya Leopard 2A6 x2 (one to be converted to something else in the future, perhaps a Buffel)
                        Tamiya Centurion Mk. III (converted with an L7/105mm gun, so I guess that makes it a Mk 5/2)
                        Heng Long Challenger 2 (pending electronics conversion)
                        Tamiya T26E3 Pershing x 2
                        Heng Long M1A2 Abrams (converted to Clark TK22)
                        Tamiya M1A2 Abrams
                        Tamiya Type 10​
                        Click image for larger version  Name:	IMG_6158.jpg Views:	3 Size:	147.8 KB ID:	415616
                        • Awesome collection! Thank you for sharing. If possible, can we see the Type 10 a bit closer :-) ? Thank you!
                          • Awesome collection and cool way to show them off.
                            • Click image for larger version  Name:	IMG_1549.jpg Views:	0 Size:	109.0 KB ID:	415677 Click image for larger version  Name:	IMG_1552.jpg Views:	0 Size:	63.5 KB ID:	415678 Click image for larger version  Name:	IMG_1550.jpg Views:	0 Size:	111.3 KB ID:	415679 Click image for larger version  Name:	IMG_1551.jpg Views:	0 Size:	105.0 KB ID:	415680
                              Here you go. It had once had its stock electronics replaced with Clark by the previous owner (who also did the rather fetching digital camouflage scheme), before I bought it and reverted to stock Tamiya electronics. I also bought it Kenny Kong metal tracks for the rubber pads, but it did not run well, so I bought AFV track tensioners to fine tune the track tension better. Despite the track tensioners, the performance of the tank was lacking and it is back on its stock plastic tracks.
                              • You have such a rare tank....nowadays in this hobby. It looks mean and awesome :-)
                                • Highly modified TongDe M60 on IR battle field during a practice day.
                                  Click image for larger version  Name:	IMG_1996.jpg Views:	0 Size:	529.2 KB ID:	415705
                                  • Tongde's M25 Chaffee, Korean War vintage.
                                    Click image for larger version  Name:	TD M24 Chaffee 11.jpg Views:	0 Size:	131.6 KB ID:	415758 Click image for larger version  Name:	TD M24 Chaffee 14.jpg Views:	0 Size:	135.4 KB ID:	415757 Click image for larger version  Name:	TD M24 Chaffee 15.jpg Views:	0 Size:	187.4 KB ID:	415759 Click image for larger version  Name:	TD M24 Chaffee 13.jpg Views:	0 Size:	157.6 KB ID:	415760
                                    This one took a while, many steps:
                                    Remove side skirts.
                                    Make sure it runs and works for IR battles first. This required replacing the TD electronics with Heng Long & LegoDEI's. The IR LED required a brass tube extending out of the mantlet.
                                    Replace the rigid plastic radio antennas with flexible wire ones.
                                    Treat the tracks with Perma Blue gun blacking liquid.
                                    Masked the LED lights (head, tail, IR muzzle flash) for the duration.
                                    Paint the body overall US Olive Green with a Vallejo spray can.
                                    Mask it so the sections that aren't to be painted are covered, paint the exposed surfaces a white base.
                                    Mask and cut to cover the teeth.
                                    Spray the remainder yellow.
                                    Mask the yellow and spray the black area.
                                    Remove the masking tape and brush paint the red areas.
                                    Spray everything with Clear Flat spray paint.
                                    Flow corners and edges with AK Streaking Grime Effect.
                                    Fill the engine grills with AK Dark Streaking Grime Effect.
                                    Foam dab dark brown paint on high points and flat areas.
                                    Rub AK Iron Paste on high points and flat areas.
                                    Streak the grime with White Spirit on vertical surfaces, dab it on horizontals.
                                    Dry brush AK Vietnam Earth pigment.
                                    Final Clear Flat spray.
                                    The spare track links were painted NATO Black, flowed light rust, and rubbed with Iron Paste.
                                    Original stock appearance:
                                    Click image for larger version  Name:	TD M24 Chaffee 05.jpg Views:	0 Size:	201.7 KB ID:	415763
                                    • Originally posted by SoCalBobS View Post
                                      Looking good👍👍👍
ID:	415863 Click image for larger version
ID:	415864 Click image for larger version
                                        Taigen M4/76 is ready for IR battle
ID:	415869 Click image for larger version
ID:	415870 Click image for larger version
