Sturmgeschutz III - don't do this at home, kids!
Gathering 1-2x monthly/All Ages & Experience levels welcome
I know this an old thread but have been referencing it for ideas and guidance while upgrading. SoCalBob would you mind posting pics and/or explaining how you mounted the IR sensor in the cupola?
Also has anyone added traversing to their Stug? Would appreciate info, pics, part #s etc….
Thanks
DD, your last question first: I didn't incorporate traverse. I use my tanks in IR battles, and there is enough "beam spread" to simulate the 10 or 15 degree swing. The IR bulb is in the barrel, about 1cm in from the muzzle.
Regarding mounting the IR sensor, it's a LegoDEI. You'll have to solder wires or otherwise make the connection with the main board. For placement in the Stug III's case, it's simply a matter of removing the hatch and placing the receiver in it's place. Most of Heng Long's parts are glued with some sort of CA, and a good debonder will allow you to remove the parts required. I keep the hatches just in case, but I've never found the need to reinstall them.
I use a little "Blu-tack" or something similar wrapped around the wires to the LED that keeps it from sliding into the barrel. Stays put when it needs to and easily removed for maintenance.Originally posted by DevilDog77 View PostThanks Bob. I have the LegoDEI also. So if I’m understanding correctly the sensor is glued in place?
Also how did you mount the IR bulb?
Hi, I just found an older video about the StuG3.
Thought it might be interesting enough because a lot of you are detailing experts.
Here is a rare example of an original colored Stug3 in a museum.
Hilary Doyle shows StuG III G in amazing original condition | NACC Ft. Benning - YouTube
CCC
That wire that hangs down from the BB Shooting Machine? What does it plug into? I removed the wires to solder one of them and now I can't figure out what it plugs into. Doesn't look like there's a port for it on the main board.Originally posted by karltrek View Post
Thanks!
There are a few different wires. Are you talking about the yellow set?Originally posted by WasatchViking View Post
Thanks!
Thanks!
Only US$10.99. Enhance your RC tank car with the Heng Long BB Shooting Machine with a 130 motor and pull-back spring. Perfect for the 3818 and 3819 1/16 scale models. Shop now at Banggood!
The BangGood listing is the simplest BB shooting system. The BB motor (130) plugs into CH10. It is the same port from TK-5.3, 6.0, 6.1, 7.0 to 7.1 MFU. There is a trigger motor at the back which has yellow wires in newer units that plug into CN6. On the BangGood unit, both pair of wires are black and red.
Show a picture of what you are working on for more concrete help.
