TD M60 A3 review.
Just finished the M60A1 upper and lower chassis magnetization. The fit is very good, no visible or feelable gap. It does not feel as snappy or as steady as the HL M4A3 Sherman magneted chassis. Being a much bigger tank (than the Sherman) with only 4 mounting posts, it is not unexpected. Magnet may be a poor choice for a M60 size used as a battle tank.
I cut a 7"x5"x1/16" plastic for the platform above the torsion bars. Marked out the notch on the side and will finish it tomorrow.Comment
I finally got the plastic replacement tracks in and swapped them out with my metal tracks. The plastic tracks matted to the "metal" M60 are IMO a far better match. The tank is lighter handling, more responsive and much quieter.
Shown here are the new plastic tracks rust weathered and just after driving for a 20 minutes of testing. They ran perfectly!!
I assume that you leave the metal sprocket and metal idler wheel on?I finally got the plastic replacement tracks in and swapped them out with my metal tracks. The plastic tracks matted to the "metal" M60 are IMO a far better match. The tank is lighter handling, more responsive and much quieter.
Yes. Although the idlers I would leave on even if it was plastic since the plastic ones also have rubber tires. One my second M60 now being worked on I am leaving the plastic idler wheels (though adding bearing) but will be swapping out the sprockets for metal ones.Comment
Are the bearings for the plastic idler wheels just drop ins? I am still rearranging the fapping around inside receiver MB, speaker and battery and waiting for the metal gearbox from DKLM. It did not leave Hong Kong yet after a week.Comment
The plastic wheels are "identical" to the metal wheels. I had no issues adding bearings.
DKLM takes a REALLY long time to ship out orders. I suspect the TD tanks and parts are being drop shipped from the factory so it takes even longer. But once shipped they arrive quickly.Comment
I used an unused mounting post to fix the plastic platform in position. It simply lay on top of the torsion bars.Just finished the M60A1 upper and lower chassis magnetization. The fit is very good, no visible or feelable gap. It does not feel as snappy or as steady as the HL M4A3 Sherman magneted chassis. Being a much bigger tank (than the Sherman) with only 4 mounting posts, it is not unexpected. Magnet may be a poor choice for a M60 size used as a battle tank.
The 5x7" has plenty of estate for the loose receiver motherboard, loudspeaker and battery. The 2S1P Lithium-Ion26650 pack can provide 2,5 to 3 hours of continuous runtime which should be good for a whole day's activities. It is velcro mounted to facilitate removal for charging. The MB and speaker are fix mounted.
The M60 is the perfect size tank for DIY upgrades. With torsion bar and metal suspension arms, it offers a lot of upgrade potentials.Comment
The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
The HL/Mato/Torro metal idler wheel uses 5x8x2.5mm sealed ball bearings, but I do not have any spare left to try. I will wait for @Rubicon99 answer before I order again.Comment
The bearings you have listed are to are far large, the TD bearings are much smaller. The bearings I test fitted where borrowed from my metal TD M60. I don't want to post the measurements of the bearings I ordered until they arrive and I make sure of the fit. That will be end of next week.
Also I have had JVM3Dconcepts design and make new bushing to replace the place bushing on the basic TD M60 suspension arms. The stock/basic plastic bushing are slightly to big and allow the suspension arms to wobble around. The JVM3D bushing are based on measurement taken from the metal M60s bearings and hold the suspension arms equally as tight as the metal bearings. Taking out the wobble enhances track retention which makes for more reliable running.
I will post photos of both the wheel bearings and new bushing soon.
After I completed mounting the components on the platform, I buttoned up the tank for a test run. It makes funny noise. Close inspection showed that one of the road wheel is flapping up and down. I inadvertently broke one of the torsion bar covers when trying to tighten down the platform. Go back to the workbench to repair and reinforce all the covers per Rubicon99 style. Sign!!I have the torsion bars "tightened" for more down pressure which caused the wheel to travel even further forward. Had I not "tightened" the torsion bar the SNAP and subsequent broken torsion bar mounting cover would not have happened.
So what was learned? The torsion bar covers need be be strengthened and a simple re-enforcement/modification to the cover will add great durability for harder use. Also I will be looking at adding a down travel limiter to the Special right and left road wheels
See photo of broken covers and my simple fix / modification.
The brass C brace was made to fit snugly and was attached via an epoxy resin. I will be installing this modification to all the covers at some point in the future.Comment
The photo shown above of the repaired "lock down" cover was my first attempt. I ended up having to go back and add a full brass plate covering the glued back together black plastic cover. This worked much better and has not failed. I have since had the covers reverse engineered by JVM3Dconcepts and printed in a high strength engineering resin which is slightly thicker on the top section and stronger then the factory plastic.
New improved "lock down" covers for TD M60. The one on the right is still wet and just out of a cleaning wash. These will be available soon for those needing replacement or that want upgraded parts. There are plans to make them in aluminum but those will be expensive.
Who is the manufacturer and seller of this "New improved "lock down" covers for TD M60"? I am very interested in getting a full set for replacing the TongDe OEM covers.Comment
Since I have been collaborating with JVM 3d Concepts I have entered into an agreement with them to market their products for the rc tank community.
I have an order for several sets of m60 tortion bar brackets that I should be able to start shipping in a week or so.
The MSRP on these is 16.50 plus tax and shipping.
pm me to get on the waiting list.
www.RichardSJohnson.net/id28.htmlComment
I am still waiting for the metal gearbox, sproket and idler from DKLM-HK. I will be lucky to get all the metal parts by end of May.
Finally, get the TongDe M60 prepared internally and magneted up for test runs. This is the slowest 1:16 scale RC tank I currently have! It is pathetic. I have not done any test to pinpoint the problem yet. The gearbox ratio too high? The TongDe 380 too slow? @Robicon99 already tried red390 and it does not fit. The Tamiya380 and Torro Black380 will help a little, but probably not enough.
I plan to test a Mabuchi RS-380SH-4528 Motor which is spec to run 25200rpm at 7.4 volts. Anybody has tried this motor before?Comment
The M60A3 isn't a really fast tank. From what I remember it's offroad speed is only 10-20mph and onroad of 30mph. That's pretty comparable to a Sherman. A guy at our museum was screwing around in the M60A3 doing neutral turns in our display area and threw a track pretty quickly. The curator was not a happy camper after seeing the bent sprocket because the dude tried to use some wood to pry the track back on. Of course it didn't work. Then we had to break track, replace the sprocket and put the track back on.Comment
Its the TD motors and plastic gearboxes. The metal gearboxes are the same ratio as HL basic steel gearboxes. My "metal" M60 with upgrade 380 motors at 7.2v the top speed was about correct for an M60 (30-35mph real world max). I am now though running mine on a 9.6v battery to get a little extra and scale top speeds are much faster when I want or need it to be. Also swapping out the heavy metal tracks for the plastic tracks was a good choice (for me) as this makes the tank more responsive by not taxing the available power overcoming the added weight. Even with plastic track it is still a modestly weighted tank to move around.I am still waiting for the metal gearbox, sproket and idler from DKLM-HK. I will be lucky to get all the metal parts by end of May.
You can't go wrong with swapping out the stock motors to something else that fits your needs better and I highly recommend it. The TD M60 is a really good tank for those that like to tweak all aspects of performance as it responds well to even little improvements.Comment
Great advise. I don't need to worry about the Mabuchi RS-380SH-4528 and will stick with the Tamiya380.
