Great photos! I have the same one, awaiting a weathering/detailing summer, possibly a bucket mod. It's a fun boat to run, and it looks sharp alongside your heli!
I need to repaint the teeth on mine:
Official RotorScale UH-1A Medic Green 450 Size Helicopter Discussion Thread
I have the Proboat PBR. Took it out a few times with the 500 Huey and had tons of fun! Will be great to do the same for the Seawolf.Originally posted by Alpha View PostThe light gray mast and blade grips really bring it all together! I need to do that for mine!
Which PBR boat do you have?3 Photos
My Seawolves Bird is almost finished now, paint is complete, ammo belts added! Just needs the decals, pilot windows, and a set of clear chin bubbles. I ordered a clear parts set from RC Aerodyne, but they only sent the windshield. Their customer support is shut down, so guess I may be waiting for a while. Happy with how things have turned out so far though, may need to get it out and do a few flights over my RC PBR riverboat!5 Photos
Thanks Ed, name is Michael thought ;).Originally posted by eawings View PostWell done Alex.
That would be awesome! Difficult to squeeze pilots in there either the battery placement, but I may give it a try.Originally posted by Gravythe clown View PostLooks great. You now need to get a Rambo action figure to pilot that puppy.
gravy
Thanks, I am using symmetrical main blades on this one. These are Align 380mm blades that I cut down and refinished to get the characteristic squared off tips.Originally posted by RCFlyer51 View PostVery nice build. Are you using semi-symmetrical main blades?
Danny
Danny
gravy
Thanks for the tips Alpha! Planning on adding the carbon tubes once I get ready to attach the pylons. The biggest difficulty now has been trying to match the Seawolves paint color. It is a very dark, glossy green. Working on mixing a few different colors to get something close.Originally posted by Alpha View PostF106DeltaDart I designed those ordnance pylons to attach to each other with 3mm carbon tubes. This reduces the side twist.
Also, the ammo belt is shaped by passing it through a lighter's flame for a split second, then bending it while its warm and holding it in place for a few seconds until it cools and rehardens in its new shape.
3DPUPs for my Seawolves Huey are printed, assembled, and primered. Also placed an order with Callie for the decals. Next step will be painting, whenever we get some good airbrushing weather.3 Photos
That sounds better. Overall length 152mm: tip to tip with equal length bars. Got it.
Thanks.
Sorry, overall length is 152mm. Was working on another project, and typed the measurement for one of those parts instead. Need to stop doing 3 things at once..Originally posted by RCFlyer51 View PostTotal length is 17mm? I assume that is the length of each bar, one on each side of the center piece. When I look at your pictures of the stabilizer, the bars sure look longer than 17mm. So the length of the entire stabilizer is only about 50mm?
It’s fixed and rigid, so it doesn’t do anything to the flight dynamics. Just make sure the screw is loctited, and the length is the same on each side. Total length is 152mm.Originally posted by RCFlyer51 View Post
Interesting. Did you need to adjust anything on the flybarless flight controller to compensate for the stabilizer? What length did you use for the bar?
Interesting. Did you need to adjust anything on the flybarless flight controller to compensate for the stabilizer? What length did you use for the bar?Originally posted by F106DeltaDart View Post
Thanks, it is a Trex 250 pitch gauge: https://www.rcjaz.com/align-pitch-ga...-90062071.html (mounting hole needed to be drilled out), a Trex 250 flybar that was cut down to length, and some 1.5mm wheel collars from eBay.
Thanks, it is a Trex 250 pitch gauge: https://www.rcjaz.com/align-pitch-ga...-90062071.html (mounting hole needed to be drilled out), a Trex 250 flybar that was cut down to length, and some 1.5mm wheel collars from eBay.Originally posted by RCFlyer51 View Post
I really like your stabilizer bar. Where did you get it? You indicated you made it out of some spares. Did you mean spare old flybars? Are the weights at the ends actually a specific weight? I assume it attaches/replaces the tophat? Would really like to get one.
Danny
I really like your stabilizer bar. Where did you get it? You indicated you made it out of some spares. Did you mean spare old flybars? Are the weights at the ends actually a specific weight? I assume it attaches/replaces the tophat? Would really like to get one.Originally posted by F106DeltaDart View PostLooks like it’s flying great Ed, nice work! Finally decided to start modding mine a bit more. Planning on a complete redo into a US Navy HAL-3 Seawolves Bird. I dremeled out the windshield to scale size and made a flybar out of some spares and a Trex 250 pitch gauge. Next will be printing out all the 3DPUPs to get it armed up to spec!
Danny
Looks like it’s flying great Ed, nice work! Finally decided to start modding mine a bit more. Planning on a complete redo into a US Navy HAL-3 Seawolves Bird. I dremeled out the windshield to scale size and made a flybar out of some spares and a Trex 250 pitch gauge. Next will be printing out all the 3DPUPs to get it armed up to spec!3 Photos
