"Grill food" for handicrafts | Page 15 | RC-Network.de
Du belügst die Deutschen schon wieder, Ralph! Der Einzige, der hier mit falschen Messwerten herumspielt, bist du: eine Timing-Einstellung von 0 Grad – etwas, das absolut niemand bei einem Außenläufer verwendet –, die *deinen* Motoren lediglich fälschlicherweise eine höhere Effizienz zuschreibt. Angesichts all der Brände ist offensichtlich, dass sie in Wirklichkeit gar nicht so effizient sin
Pinocchio is at it again Luke....
High power calls for high timing. He knows he is supposed to measure it there. Hes still running his mouth about ETA but were already real world proven with Andrew and Brenners in flight and battery consumption data.... Ralph is a sad case.....
Danke,
Hubert....
Good Morning.....
You hanging around EARLY looking for something to see Ralph????. Here you go. I don't think they care if you wind their heli motors again. But you already know how the story goes anyway coz you read it well before today... I certainly don't care about your xnova issues . You critique everything poorly but a scorpion but the best heli pilots in the world hardly fly them anymore. They fly Xnova and Egodrift and no heli pilot had really ever left a pyro in exchange for a scorpion in the first place. Be sure about that. Maybe they dont want your bloody hands rewinding their .15mm lam machine. If you had the right tools and know how then you break the edges......and get wire off without destroying it. All the wrong glue they used came from the copying YOU.... guess youve forgotten your own previous work with their machines before you realized its a pure insulator. Please find something interesting to post about because that basic winding and bogus editorial about XNOVA isn't it. Produce something from the ground up then and show them all how its supposed to be done.... Currently you use nothing to pot the wires and that's equally incorrect for optimal reliability.
Diesen Scheiß mit dem blanken Draht hast du von Thomas.
~helifreaks "who can rewind my motor"~Comment
Hallo! An meinem Geburtstag – dem 21. Mai 2007 – machte ein leitender Entwickler bei LRK folgende Aussage: „Meiner Ansicht nach ist bei Durchmessern von über 60 mm – im Bereich der Modellmotoren – ein Motor mit einem Verhältnis von Durchmesser zu Länge von mehr als 1:1 erforderlich, um die Vorteile wirklich nutzen zu können.“ Woher stammt also die Zahl 41? Heutzutage hört man nicht mehr viel über diesen angeblich überlegenen Motor – schon gar nicht im Bereich des Modellflugs. Er tätigt häufig derartige Aussagen, nur um seine eigenen Behauptungen später wieder zu vergessen; was er jedoch niemals tut, ist, den Motor in sein eigenes Boot einzubauen und praktisch zu beweisen, dass es sich tatsächlich um den besten Außenläufermotor für Modellboote handelt. Loring Miller und Brian Buass stellten den Rekord in der S-Klasse mit einem völlig serienmäßigen Scorpion-Motor auf. Und das hat sie übrigens auch keine 15,7 Millionen Dollar gekostet.
Ich bin mir sicher, dass er jetzt wieder lospoltern wird, aber ich möchte nur darauf hinweisen, dass keiner der beiden Motoren einen Durchmesser von über 60 mm hat und der 4140 im Grunde quadratisch ist – er erfüllt also gleich in zweierlei Hinsicht nicht die Kriterien, die der Konstrukteur selbst aufgestellt hat. Außerdem ist er nicht gerade auf dem neuesten Stand, was die hiesigen Gegebenheiten angeht; nur sehr wenige hier interessieren sich noch für deutsche Produkte, da die Zölle die Preise ins Unermessliche getrieben haben.
"Grill food" for handicrafts | Page 16 | RC-Network.de
Hallo, ich vermute, der Entwickler wird diesen Widerspruch wohl nicht aufklären – aber wie dem auch sei: Ich habe gelesen, was du geschrieben hast, und bin anderer Meinung. Wenn die Anwendung im Hubschrauber es zulässt, trotz der Zahnbreite mehr Windungen aufzubringen, dann wickelt man diese auch; denn mehr Windungen ergeben eine bessere Induktivität. Der Motor liefert dann bei hohen Drehzahlen eine bessere Leistung ab.Comment
While winding motors and building Class A audio amplification I'm also looking at different transistors. Lateral Fets, BJT's , GanFet , etc and hope to build a big boy bridge that can deliver 30 - 40 kw in a breeze and also be controlled with Talega. The Mundorf caps I'm sourcing for the Class A amplification for instance is giving me great component selection ideas for a heavily filtered clean limitless power 3 phase bridge for >50mm series machines.... In this 4 pin series iI can get 40000uf 63 volt caps. An inverter with at least a half of a farad never hurt anyone that really wants to supply the motors what it needs for heavy loads. These and the Supercaps are technologies plan to exploit in this journey
Danke,
Hallo Powercroco (Mr. BEAN), hier ist ein 4035 in einer 1.5 SL YY-Konfiguration. Die Wicklungen sind vergossen......
Können du und Von Lucas es sehen?
Hubert
AL from Helifeaks sent me this big boy Combove MENSA 12N10P. He inquired about 1.6mm but that's not an American size. I dont see anything wrong with it in its current state but since I've been given the flexibly to not wind it with 1.6mm the door is open to either wind it with an American equivalent which is going to be slightly larger or do something totally different. He just wants the kv around 525. Since he understand the cable size is not everything maybe he will get a 3 or 4 layer machine....
14 AWG is a minimum of 1.628 mm 15AWG is minimum of 1.450mm of bare solid wire.
Who cares about old pink cars in Gotha that need a larger radiator? 😏 They want a Tesla's , E Beemer, or Range rover's winding Tech inside and cooler rotors..... Gotha motors cant provide it because they cant wind it so they just make excuses and falsehoods how it doesnt work.
How would they know if they have never wound and run one sucessfully????
All you have to do is ask them for video.....
Hi,
Ive been really buzy setting up the shop, Lathe, and New top dog Bambu labs printer so I can show Gotha motors what America is truly like. CK Aero should be receiving small a batch of US hand wound motors from me shortly. Ive received the wire from BAE & insulation and have not had time to measure the MW35/200C* 14.5 AWG diameter yet. I also received about 5 pounds of polyester MW16/240*. I wind the F3A pryos with it. The Dro will give me easy repeatability to out class Gotha and Skywalker motors over and over again.....😀
Danke,
HubertComment
Happy 4th of July and enjoy flying.....
No more time to yap on a forum.... I gotta go. but have some very interesting things to show yall boys later......
Happy 4Th....
TTYL
HubertComment
Hi,
Es ist erstaunlich, wie du und Thomas die Desynchronisation einfach hinnehmt, ohne etwas dagegen zu unternehmen. Habt ihr beiden schon mal von Pufferkondensatoren gehört – oder sie tatsächlich eingesetzt? Ihr wisst doch, dass ihr mehr davon verwenden könntet als bisher – und wenn euch das zusätzliche Gewicht stört, taugt ihr ohnehin nichts. Die Leistungsangaben sind schon lustig, denn diese kleinen Motoren können kaum dauerhaft 80 oder 90 Ampere verkraften und dabei überleben. Baut einfach mehr Pufferkapazität ein. Es ist schon kurios: Ihr präsentiert Daten, als wären sie umfassend, aber dabei lasst ihr völlig außer Acht, was bei unterschiedlichen Kapazitätswerten passiert – und dass ein Motor eher aus dem Tritt gerät (Desync). Ihr messt ja nicht einmal die Temperatur der Motorglocke oder Ähnliches...Comment
Außerdem gibst du ständig deinen Piloten die Schuld, wenn sie das Material bei Speed-Wettbewerben zu hart rannehmen – echt lächerlich. Warum baust du ihnen nicht endlich einen Motor, der dafür taugt, anstatt so einen Mist zu verzapfen? Sie verheizen die Motoren, weil du ihnen quasi „Handgranaten“ in die Hand drückst. Das ist dein Fehler, nicht ihrer. Du weißt doch genau, wie beim Speed-Fliegen geflogen wird, bevor du einen Motor für den Wettbewerb vorbereitest. Der Motor muss also entsprechend mehr aushalten können. Du sicherst deine Kabel nicht richtig – wahrscheinlich, weil du nicht zugeben willst, dass du dir das bei mir abgeschaut hast; dabei würde sich dein Status als „Halbgott“ in der Szene glatt verdoppeln, wenn du die F3A-WM gewonnen hättest.Dann ziehst du über APD her, bewirbst aber gleichzeitig diesen Schrott aus China, der NIEMALS einen Weltrekord im Speedflying aufstellen wird. Sicher ist das Ding kaum.
I see ya still in class mr "Bean"
