Official 3DP Thread
  • Well guys I'm up and printing the bed adjustment knobs so it is not a pain to set the height, then front and rear braces the Y and Z belt tensioner. R.
    AMA 424553
    • Awesome! She does some great prints, you will be happy with it especially with the upgrades also suggest a cover for the terminal end of the power supply with the power switch and plug port. Adds a great layer of safety as well as a cleaner look
      • I found an F35 i may try. Looks pretty good.
        This plane was designed to be an incredibly fun and acrobatic modern style fighter jet. It has and EDF that is capable of producing plenty of thrust to perform the maneuvers that you want to pull off. The print time is relatively low on it since there are minimal parts, that also makes assembly quick and easy. Flight Video Build Video  - Coming Soon Instruction Manual You get everything needed to print your plane in your download: stl files, slicer settings and an instruction manual. Questions about printing? Check out our test file or our support page.
          I have that on the list of things to print, doing Y tensioner now, have X done and then power switch cover. R :)
          AMA 424553
          • Good times!
            • The edge 540 is complete
              • Also started the PBY
                • RMBTX, I will be checking in on this build of your PBY with great interest, Sir. Lookin' good so far. ;) Best, LB
                  • Sounds great, so far its going very well. Had a problem with the little extruder gear that caused some under extrusion. Got that fixed and back on the schedule. This looks like itll be fun, im going to spray the fuselage with polycyclic to help water proofing
                    • Good job Bro!!! You found yourself a hobby within the hobby!!! Awesome stuff!!! Jerry
                      • Thank you brother! This is fun to do, it truely feels like building something from the ground up!
                        • I have been printing away here, only parts to improve the printer right now. I have a problem getting my computer to completely see the printer, I loaded the software that comes with the printer but it only sees the printer and it won't let me look at it yet alone monitor it, I'm using ulimaker Cura 3.6.0 on the desktop and laptop but on the laptop I also have the Anet repetier program and it does see the printer but no controls, Cura does not see the printer at all.
                          What are you guys using?
                          Thanks Ron
                          AMA 424553
                          • :Straight-Face::Straight-Face::Straight-Face::Straight-Face::(:( not cool at all... I hope you get it worked out. I have no printer as of yet, but I feel your frustration!!! :Thinking:
                            • Originally posted by RRHandy View Post
                              Thanks Ron
                              How long is your USB cable?
                              • So far, I have not attempted to connect the Ender 3 direct to the computer. I'm putting the gcode on a micro SD and sicking that into the printer with the printer 20 ft from the computer.
                                I can shut down the computer and let the printer go ahead and do its 30 hour print task.
                                  I have a 25ft and a 5ft that I have, I have the desktop on the 25 and the laptop on the 5, they both are doing the same thing and I went on the net and looked around and found some things but nothing that is factual some talked about the changing the read rate to 115200 but it's there already, I want to update the firmware but not till I can get it kinked.
                                  AMA 424553
                                  • Originally posted by fhhuber View Post
                                    I have been doing the same and no problems there, just would be nice to monitor it at the computer is one thing. R
                                    AMA 424553
                                    • You need an amplified USB extension cable both of those are probably cheaper cables that won’t carry enough signal.
                                      • I have ran mine both from the PC, one was on 31ft of cable (anet A6) and the other on a 10 ft. Only difference would be im also running simplify 3D.
                                        • I use a Mac and haven't had any issues but I do have a good amplified cable (20').
