I got one flight each on all four of these before the wind started kicking up this morning. About 80 degrees with just a little breeze when I got to the field just after 8, and surprisingly, despite nice conditions, I was the only one there. By 9:30, the wind was building in strength, so even though I had three more batteries charged, I decided four good flights would do it. I even managed to land the Stinger EDF without bouncing it today.
Earlier this week, I disconnected the WISE stabilization system in Fawkes, which I suspected was causing some of my stability issues. The new foamboard wing's ailerons are reversed from the original wing, and even with the stabilization set to the advanced mode, the WISE system would try to keep the plane level with no stick input. The problem was, if it started banking a bit to one side, it would end up throwing aileron in to make it bank more to that side. It was much more stable without the WISE system today.
Did I mention I landed the Stinger without bouncing? I'm not sure if the landing was such that it should be described as greasing the landing, but I was pretty darned happy with how smooth it was, though a bit upset to see that, despite having my P&S camera aimed well for the runway before hitting record, for some reason, it zoomed in just a bit on the record function, so the bottom of the screen barely shows the runway, and the camera didn't capture the touchdown. Yeah, I know. Pictures or it didn't happen.
