View Post
What did you fly today?
Originally posted by Hemidoo View Postxviper , you bring a large mix like i do to the field !
Originally posted by F22trainer View Post
Great looking glider!
- Likes 2
Originally posted by xviper View PostIt's a longish drive to both my flying fields, so I try to take at least 4 each time, plus I've got too many planes right now and I feel I need to rotate through them to get my money's worth.
Thanks. It's my oldest and most favourite of all my sailplanes.
Today sucked for flying in Phoenix...but I did get my Mac returned to service so the M-600 Build is ON again.
- Likes 2
Originally posted by Hardway View PostLOL Dove hunting!!!! It IS a nation-wide tradition!!! Like AAA over Baghdad, even in California??? LOL Too funny. In Texas, you just carry a Kevlar umbrella Rednecks will be red... And I resemble that!!!
One of these days, I'll remember the camera!!
I took the Spitfire out yesterday as well as My Little Gall II, flew the Spitfire twice and did taxi tests on MLG. Since I last flew her, she received a new motor so now she's running a 650 kv like all the other Mustangs in the fleet.
Typical of my Freewing P-51's, the landing gear needs constant attention, so I'm doing adjustments on everything to get a fairly even take off run. The good thing is that with the different prop shaft, the spinner really hugs the nose, the best fit yet. The strange thing is that contrary to what I would expect, she pulls to the right and not the left and the tail wheel, although bigger than the FMS P-51's, is not very effective. Which reminds me, does everyone have some slop in the retracts. Mine will tend to slop towards the retract position. Not sure what caused that, short of the trunnion needing to be adjusted. Tried that but it didn't seem to help.
Today, I reluctantly left the Spitfire home and took out the P-40 and Big Beautiful Doll and again did taxi tests with MLG. Getting closer to what I want, but the winds have been coming up at mid day so called it quits. After having lost Shangrila again, she spun in don't know why, but hey, I got a few flights after the first crash so I can't complain, she just wasn't the same. What really made me mad was that I lost the Bearcat through pure and simple pilot error (to put it nicely) flew into the sun and I couldn't see her, I could hear her, and finally caught sight of her heading straight for the ground at about ten feet. No one else at the field so no one was hurt, but man, I was choked to say the least. moral of the story, if performing maneuvers in the early morning, perform them at the opposite end of the field to the sun.
Grossman56Team Gross!
- Likes 3
Originally posted by DCORSAIR View PostOff work for the holiday and could hear nothing but shotguns going off do to Dove season here in Ca., so I loaded up these two and went after them this morning, was a little worried though, some of those hunters were close to my house...............Hugh "Wildman" Wiedman
Hangar: Mig 29 "Cobra", 8S EuroFighter-Bronze Tiger, A-10 Arctic, F18 Canadian & Tiger Meet, 8S F16 Wild Weasel, 8S F4 Jolly Rodgers & Blue Angel, 1600 Corsair & Spitfire, B-24, Stinger 90, Avanti. Extreme Flight-FW-190 Red Tulip, Slick 60, 62" Extra 300, 62" MXS Heavy Metal, 62" Edge Demonstrator. FMS-SU-30,1700mm P-51, Corsair, Viper, Beast Bi-Plane 60", P2 Bi-Plane, P51.
Originally posted by Hugh Wiedman View Post
DCCORSAIR, nice looking birds. I'm just finishing building the 90mm F-16 (assume yours is also the FW 90mm). I installed the upgraded 12 blade 4068-1835kV in-runner and 155 amp ESC. Any advice as to CG (with gear up/down), rates and flap deflection with elevator mix? Any help or things to look out for with your experience would be appreciated. Expect to maiden it some time next week, assuming the winds die down-still getting rain and 30-40mph winds from Dorian, but lucky it missed and feel bad for those in the Bahamas, many of whom had very little to begin with.
- Likes 2
Yes, mine is the FW 90mm, I have the same fan unit in mine as well, I'am using the stock ESC with no issues after many many flights, gear down CG is about the 115-118mm mark, I hate the book CG but others are okay with it, I don't use a flap mix, never really seen the need, I like simple and the F-16 is that, flies awesome, this is my 5th one actually, I tend to wear them out, I don't remember my elevator throw but I know my ailerons are like 30mm up/down, it don't like to turn when you slow down in the stock mode, think that is why some use tailerons, works for me with more aileron travel flying it standard mode. It does not like the drop tanks at all, seems unstable and I have tried moving the CG but it doesn't seem to help, flies great with the ordnance on it though, keep your timer around 2:30 until you figure out how to get more flight time out of it, I don't back off to much, I just can't, it loves to go fast and you can also do slow high alpha passes with it, some guys are to scared to slow it down, it will but feels heavy because with the forward cg you have to hold up elevator, once you get used to how it flies you will love it, landings are tricky, when you turn to final pull throttle back and the nose will pitch up, hold it there with a little elevator and control the rest with throttle, my turn to final is really slow, then I add power as needed to maintain the high AOA, if you do it right then you won't need much of a flare, fly it in on the mains, it does best like a carrier type landing instead of trying to grease it in on the mains smoothly, that takes time.Hugh "Wildman" Wiedman
Originally posted by Skyboom View PostJamesonC if you had any issues with grass runway with these models? Just exploring some options in the near future. BTW. nice pic.
Originally posted by F106DeltaDart View Post
. No doubt!! Still working on the last few details. Have my 4077th MASH decals on the way from callie, and just finished adding the stretcher canopies.
