Originally posted by SanExup
View Post
Originally posted by Evan D View PostI don't think anything will help. It sounds like play in the servos and linkage where if you give it some right it stays a little right when you go back to center and then you give it left and it stays a little left when you go back to center again.
Originally posted by Evan D View PostTry it and tell us. The rotor is like $12. Note it's not just the number of blades but the blade has a different design and pitch too.
I am frustrated with hooking up the servos. Esc is short and so maybe hook it all behind the battery?. Way too much excess cabling. Use extensions and hook it all up at the front of the plane? The connectors then get in the way of the battery. Post some pics of your receiver installs please. Uggh!!
Destroyed my Mirage. All my fault. SAFE will get you if you don't know it is active. Anyway,the power plant and all the servos and 1 of the 3 landing gear survived. Other 2 can be salvaged. I now have a bunch of parts. Thinking about the Gripen ARF+. I'll be getting the 10 channel lemon for this, so no SAFE!! Wearing my walk of shame shirt............
Guys hoping someone can help me out here having one hell of a time programming this Mirage how I like. I’m using a AR637t NX8 radio when I change the wing type the channel 6 becomes unavailable and says flaps which I don’t want. I use thrust reverse and where I have the ESC reverse plugged in. Servos all function properly safe works EDF still backwards easy fix provided I can get thrust reverse on my usual channel. This is my first delta without a true rudder, hope y’all can help can’t wait to get this bird in the air
Originally posted by shortround91 View PostGuys hoping someone can help me out here having one hell of a time programming this Mirage how I like. I’m using a AR637t NX8 radio when I change the wing type the channel 6 becomes unavailable and says flaps which I don’t want. I use thrust reverse and where I have the ESC reverse plugged in. Servos all function properly safe works EDF still backwards easy fix provided I can get thrust reverse on my usual channel. This is my first delta without a true rudder, hope y’all can help can’t wait to get this bird in the air
1. What wing type did you specify? It should be "elevon" or "elevon B"
2. What do you mean by "without a true rudder"? What is not true about the Mirage's rudder?
3. It seems to be a quirk of the NX when specifying elevons that it will call channel 6 "flap" even when you have not specified flaps. No biggie, just use the mixer to send the switch value (you don't say which switch) for forward/reverse to "FLP", or use "flap system" to do the same, and plug your ESC's reversing lead into slot 6. The value you send needs to be -100% for forward, +100% for reverse.
Have just gotten back into the hobby about 8-10 months ago once getting better at programming still not all that good why I reached out here. I knew I wasn’t the only person who is using a Spektrum AR series on this type of jet. This will be my first time even attempting to mix, I’ve gone slow on everything low rates getting used to several plane types then slowly changing things to my style of flying. Thanks for the reply sounds like your someone who can get me in the right direction
Originally posted by shortround91 View PostSorry I meant elevator not rudder, I set thrust reverse on my C channel I’m a south saw so it’s natural for me. EDF is also operating in the wrong direction which on my F16 is an easy fix using a channel to change properties.
Easiest way by far for you is to go into the "Flap system" menu, set the controlling switch to "C", and for the three positions set the flap value to +100 or -100 as needed (do not leave one of them at zero). If the motor is not running in the correct direction, just reverse the +100 and -100 positions. You can check on the channel monitor to see the values change as you move the "C" switch.
