The retracts themselves can not be sped up or slowed down. What I was saying is there is a delay built into the MCBe that delays when the retract starts working that can be taken away if you bypass the MCBe.
Just did a refresh on the 90, 8s some foam repairs supports ( nose area getting soft ) added wing lights along with a 8s 5280 burner that I modified. Guys check your main gear shaft pin screws mine came out on taxi causing some bad wing damage, remove clean and locktite them trust me. Here’s a few pics of where she’s at now and in processComment
Would the spectrum ar631+ be a good choice receiver for the f22 90m ,I'm not using thrust reverse or safe I just want the as3x I have a nx8 transmitter!Comment
Hey there,
great work here!
I've just ordered my F-22 90mm and can't wait to get it 😁
Will try to ramp up her scale level quite a lot in nearly every area 🤣
So let's see what we can achieve 😎
Kinda wanna take it to the next level so first thing I'll do will be 3D scanning some of the 22's areas to be able to reverse engineer surfaces etc.
Beside this there needs to be a way more scale'ish landing gear imo.
Regarding the tyres I've found out that originally she got:
- nosewheel tyre 23.5 x 7.5-10
- mainwheel tyres 37 x 11.5-18
which gives us:
- nosewheel 44 x 14 mm
- mainwheel 70 x 22 mm
with the landing gear slightly shorter than it comes with the Freewing F-22. So for the nosewheel the 80mm F-22 seems to be the perfect fit and for the main gear I will doo a whole new setup.
BenComment
I'm working with the Creality Ferret Pro and it works insane for me.Originally posted by freakbrotherBen,
Which 3-D scanner do you use and would you recommend it?
Did scan engine bays, fenders, skirts with great resolution and details.
Price wise it's a no brainer imo.
Super excited what I can achieve while scanning the 22.Comment
I have a f22 90 mm Raptor , I have a nx8 transmitter what receiver is a good one ar631 or ar637t dont need thrust reverse no safe just as3x best signal!Comment
Either one should be fine. I use ar631 when space is an issue. F22 90mm has plenty.
If signal is your concern, add a satellite Rx. Both will accept one, but the ar631 requires a special wire to connect it.
Also if signal is your concern, using SAFE as the failsafe system is definitely the way to go. Loss of signal EDF crash with failsafe set to ‘last command’ is typically a total loss (including lipo). If it comes down in SAFE, sometimes there is no damage at all. Ask me how I know….Comment
I use a AR8360t but also run tailerons also converted to 8s and wow what a performance upgrade. 8 channel also allows for the nose gear gyro that is very nice helping stop wing tips on landing etcComment
Hiya folks, I got one of these beauties for my birthday late last year, and I have a question about the thrust reversal. My runways are now limited to paved and I'm trying to find a way to slow the let down on landing. I've tried using the thrust reversal feature but the issue I'm having is that the jet yaws severely to one side, so much so that it will either scrape a wingtip, crash into a curb, run off the runway and get damaged by the tall/unfriendly grass, etc. I guess what I'm asking is, does anyone else experience this issue, and what am I doing wrong? Thanks for any advice, as I'm not flying it again until I can get this figured out.Comment
I have the 70, 80, and 90 and only the 80 did that to me. No matter what I did it would scrape tips when I gave it reverse. I put a steering gyro in and poof, perfectly straight landing. Assan...
nThanks Evan, so you installed a gyro on only the rudder/steering channel? Just making sure I understand. I have several Futaba GY-401 HH gyros from my heli days that I could easily tie into the thrust reversal switch.Comment
Steering gyros are specifically designed for steering. The one I use also disables steering when the gear are retracted. Your helo gyro may work, worth a try.
Assan ag61 anti-sideslip front steering wheel gyroscope gyro for edf jet fixed-wing rc helicopter airplane Sale - Banggood.comComment
Understood... thanks for the link!Steering gyros are specifically designed for steering. The one I use also disables steering when the gear are retracted. Your helo gyro may work, worth a try.
.png)
