  • Fast N Light
    • Apr 2021
    • 113
    Originally posted by davegee
    Hi Fast N Light: thanks for the suggestion on the lens covers. Question: is there a filament that will print in a clear look, not cloudy but more like glass? If so, I might try my first design at these light covers.
    My limited experience is with clear PC. It's not clear like glass, but maybe 80% transparent with a good print orientation. Resin printers can do much better, but I don't have one.
    That's why I purchased the lenses from AliExpress. 15degree has a tight beam. 60 degree is very splashy eg bright from wide angles. I like the way they appear different together.
      • Nov 2013
      • 2730
      • Cody, WY
      The foam covers really help out in transport in/out of my house to the car and then to the field. Th entrance road to he field is Very rough!
      The red ribbons are good to be sure I don’t take off with one or more of the foam covers on the airplane! Don’t ask me how I know, just asking for a friend!🤣🤣
        • Nov 2013
        • 2730
        • Cody, WY
        Hi FastNLight: I just ordered the light lens set from Ali Express. I found a pic of a F-22 closeup of the landing lights and I think I can come up with a reasonable facsimile using those light covers.
        Thanks!
        davgee
        • Timo
          • May 2022
          • 7
          I've got a used F-22 in good condition. I added lights and afterburner, filled the surface and airbrushed a fantasy desert design, based on the F-15 and the colourful tails of some F-16s. I used Vallejo for the first time, which was easy to use. Last step was weathering, which gives a more realistic effect. Grey is fine on the ground, but not in cloudy or winter sky conditions.
          It's a great flying jet :-)
          Timo
            • 5398
            Looks great!
            • shortround91
              • Nov 2023
              • 301
              • Princess Anne, Maryland
              Been flying my Raptor 90 a lot lately just got my highest speed on it running a SMC 9300/8k hivolt pack. Still flies great can feel the extra weight landing but 7min flights times oh hell yea
              • Ltk20
                Lee
                • Nov 2024
                I have the 90mm f-22 with the upgraded 8S setup. I’ve been having issues and leaning towards a speed controller issue. I’m looking to toss in a 120 avian esc so I can get all the telemetry from it. Do I need to tune the esc for this motor? Ie, max rpm, etc? I’m curious what settings to need to push to the esc via forward programming.
                thanks for the help, Lee
                  • 5398
                  I would try to troubleshoot the stock ESC first. Is it the big black one with a separate BEC or the newer blue one? What is it doing or not doing?
                  • billd3
                    Expert builder and pilot
                    • 45
                    • Charles City, VA
                    I am rebuilding my 90mm F-22 after a mishap...I ordered a new fuse which thankfully had all the extension wires installed...BUT... has no control rods installed on the nose gear doors. After my crash I could not find my old push rods for the nose gear doors either, so I need a couple if pictures of the push rods and how they are installed on the servo arm so I can make new ones...Can anyone help by posting some pics of this area?
                    Thanks in advance,
                    Bill
                    Indy Damnbeenie
                    • DCORSAIR
                      • 1918
                      • Selma, Ca.
                      Thanks in advance,
                      Bill
                      You can purchase all the pushrods separate, wouldn't hurt to have an extra set plus if you watch the build video on their web page you can see the nose gear door set up at around the 4:50 mark but you may have to slow the video down to see it properly, just a thought on that.
                      • billd3
                        • 45
                        • Charles City, VA
                        Which video do you mean? ...Can you tell me what the "post number" is?
                        Thanks,
                        Bill
                        Indy Damnbeenie
                        • Fast N Light
                          • Apr 2021
                          • 113
                          ..., so I need a couple if pictures of the push rods and how they are installed on the servo arm so I can make new ones...Can anyone help by posting some pics of this area?
                          Thanks in advance,
                          Bill
                          Hope this helps
ID:	414077 Click image for larger version
                          • DCORSAIR
                            • 1918
                            • Selma, Ca.
                            There you go, some nice clear pictures, better than the video I was recommending.....
                            • shortround91
                              • Nov 2023
                              • 301
                              Only issues I’ve had with my 90 that I’ve since fixed, front landing gear support and main landing gear strut screws kept coming loose. Ended up green locktite for the screws no more backing out and I bought a 3D printed support which cracked and I’ve yet to have a bounce landing so I made a 2 support mod that many many flights since not a single issue. Posting pics of what I did for the front gear. Very easy to do guys and no worries about 3D plastic cracking.
                              • billd3
                                • 45
                                • Charles City, VA
                                [QUOTE=Fast N Light;n414076]
                                Hope this helps
                                ABSOLUTELY PERFECT, Fast N Light...Many thanks!
                                Bill
                                Indy Damnbeenie
                                • shortround91
                                  • Nov 2023
                                  • 301
                                  Just finished up my 90 Raptor, KMRC blue burner, nav lights, running lights and illuminated cockpit. I also wired in disconnects for the wing lights so wings can be removed without wiring issues. Think she turned out great
                                  • Fast N Light
                                    • Apr 2021
                                    • 113
                                    If you are interested in a dual beam landing light, 3D print files (link) are available.
Name:	F22 LandingLight Side.jpg
Name:	F22 Nose Gear Light Side.jpg
                                    • shortround91
                                      • Nov 2023
                                      • 301
                                      That looks amazing great work
                                      • Fast N Light
                                        • Apr 2021
                                        • 113
                                        Thanks The download includes a .PDF with assembly guidance and more photos. The landing light is probably much easier than the others you have already done.
                                        I am also working on printed housings for the navigation and formation lights. Hope to get those and a number of other projects finished in December.
                                        • shortround91
                                          • Nov 2023
                                          • 301
                                          That’s super cool I love to do mods or add ons to my planes. I’ve done lights etc on my Mirage 70 Raptor many more I made my own cockpit set in the Mirage I get lots of compliments on how I did it
