Originally posted by MANFRED
View Post
Don't try it if you are not EXPERT level.
Splitting off the flaps, ailerons, tailerons (just use the horizontal stabs as mixed elevator ailerons) from the multifunction board and developing a mix that locks ailerons and flaps in neutral while the wings are swept is recommended.
Wings swept, if the flaps come down you strip servos or rip the flaps off. If flaps are down and the wings sweep back it will rip the flaps off or jam the sweep system.
Scale would be to not have the ailerons on the wings act as ailerons at all, just extensions of the flaps at slightly lower deflection angle.
So, i did a lot of playing around and got it set up on my DX-18.
Then I decided to repaint for better visibility so right now the wings are off. I'm going for a NASA paint scheme with orange wings and tail-planes. Unfortunately the paint chosen isn't hiding the grey so I have to strip the whole airplane.
It is not super fast. Maybe 110 mph (I will know when I install telemetry)
Its a heavy bird and likes you to maintain airspeed.
I suspect that I can open the "cheater holes" (louvers in the belly toward the middle) and get better power for takeoff. Also I KNOW that Castle ESCs with updated firmware will improve the power.
One change at a time... might be a while before I change ESCs and then open the holes.
