  • kallend
    • 1877
    Hard to tell since you don't mention names but, FWIW, I never said stabs were meant to be balanced on the CP.
    Neither did anyone else. I don't know where he got that idea.
    This said, installing a stab so that the pivot line is very far from CP will obviously cause a lot of innecessary torque that the servo, servo linkage and servo assembly will have to deal with.
    And the supporting structure.
    • Shaun Evans
      • Apr 2021
      • 125
      • California, USA
      Hi,
      Very true. Again, this is why I wish they'd apply some good science when they'd design these birds. Where that pivot is in relation to the CP (which is largely a function of airfoil/planform design) can be optimized (for least amount of work for the servo) for a given speed. Until then, a good linkage train and a good servo will have to do that trick. My main point was that the idea that balancing a FF stab on the pivot (without any requisite information on the design variables) is 'always necessary' or even 'always beneficial' isn't always true.
      For those of you who converted to turbine, how much fuel are you carrying? What kind of flight times?
      • fredmdbud
        • 451
        Over at the Aviation Stack Exchange, 1/4 of the mean chord seems to be a "magic number".
        https://aviation.stackexchange.com/q...al-stabilizers
        https://aviation.stackexchange.com/q...es/67069#67069
        • Shaun Evans
          • Apr 2021
          • 125
          • California, USA
          Hi
          Well, maiden done! Man, you guys weren't kidding about this CG being too far forward. Didn't help that my wheels weigh a ton, either. Gonna try again tomorrow with a relaxed CG.
          • kallend
            • 1877
            Originally posted by Shaun Evans
            Hi
            Perhaps you now believe my comment in post #4451.
            • kallend
              • 1877
              I believe someone mentioned that in this thread last November.
              Freewing MiG-29 Fulcrum Twin 80mm EDF Jet​ Freewing first established the Twin 80mm class of EDF jets with its popular F-14 Tomcat and then the A-10 Warthog, and now we are proud to announce the Freewing MiG-29 Fulcrum! Represented in 1/9 scale, this large aircraft is 1878mm (74”) long with a 1257mm (50”) wingspan,
              • Shaun Evans
                • Apr 2021
                • 125
                • California, USA
                Hi,
                Little shade in there? I didn't disbelieve your post, lol. 😁 I just ask questions and collect as many data points and information as possible--and never in a disrespectful or unfriendly spirit. I hope it didn't come off otherwise. I did read your (and others') comments regarding the CG being too far forward, so I arranged my components such that I could rearrange them easily after I had a chance to maiden it. So thank you.
                • 4qr1hu9n7
                  • Dec 2020
                  • 36
                  The E-Flite SU-30 has weights in their stabilizers.
                  4QR1HU9N7
                    • 8835
                    I have the SU-30 and even with those weights, I don't believe those stabs are "balanced". They may help but they aren't balanced at the pivot point. If you remove the rods, the stabs will fall to one side.
                    • kallend
                      • 1877
                      I think we need to be more careful distinguishing static balance from aerodynamic balance.
                      • viper1gj
                        • Feb 2020
                        • 81
                        Has anybody used the Top Design struts, wheels, and brakes that are supposed to be a drop in replacement on the Mig-29?
                        • Airguardian
                          Post Stall Svengali
                          • Aug 2020
                          • 1688
                          • Catalonia
                          As Kallend pointed out, I was talking about aerodynamic balance, not mass-balance.
                          • fredmdbud
                            • 451
                            https://www.hobbysquawk.com/forum/rc...967#post283967
                            The 2nd Stack Exchange answer quite a nice job using more conceptual and understandable English :)
                            • Shaun Evans
                              • Apr 2021
                              • 125
                              • California, USA
                              That was close....
                              I've GOT to find a a lighter wheel/brake combo. Relaxing the CG seems a huge improvement (as discovered and advised by many of you) but with wheels/brakes this heavy, it's almost moot since the gear-down CG and the gear-up CG are so significantly far apart :(
                              Luckily, I arranged stuff in there such that I had room to move stuff around some more. After a near-crash, I got two more decent flights. I'm getting 6 minute flights without having to carry external fuel, so that's good.
                              Last edited by Shaun Evans; Apr 26, 2021, 08:27 AM. Reason: Re-read my original post and decided it was dumb.
                                • 5426
                                Forgive an old fool but if the pivot isn't at the aerodynamic balance point wouldn't a change in air velocity change the force needed to move the stab? Even if you balance it as in your example when you increase throttle (air flow) it would change the force (thumb and forefinger) to move it?
                                In our case with the pivot being so far forward is it possible to get it reasonably balanced?
                                • kallend
                                  • 1877
                                  ....... the actual engineer who designed the stabs on my jet applied some tried-and-true formulas/calculations and a specific airfoil to the design. . . . .
                                  I think you assume too much.
                                  • Shaun Evans
                                    • Apr 2021
                                    • 125
                                    • California, USA
                                    Haha,
                                    For some reason I get the impression that you're no 'old fool', but you're absolutely correct. The way I understand it, these full-flying stabs (in full-scale aircraft) are designed to be most stable (requiring the least effort to move them) at a specific speed. Normally, that speed is some calculation of the 'average' speed the airplane will fly at during normal flight. Obviously, there probably aren't too many RC jet makers who incorporate all this, so it's mostly academic, I suppose.
                                      • 8835
                                      And not too many RC jets use hydraulics to move control surfaces.
                                      • Shaun Evans
                                        • Apr 2021
                                        • 125
                                        • California, USA
                                        Do tell?
                                        If you mean with regard to this MiG, I'm not assuming anything. My first post was asking about what calculations went into the stab design. After reading all the posts on this (and other posts on other birds by people in here whose comments interested me) it doesn't seem like the designer did much in that regard. If you're referring to the stabs on the jet in my story, then no, I'm not assuming anything at all--I'm stating facts straight from the designer.
                                        After re-reading my own posts, I see that I'm coming off as a know-it-all. That paired with being the last on the scene isn't a good look. You can't always infer tone on the net, so let me say that I'm not nearly as smug and condescending as it reads!
                                        • GliderGuy
                                          • 1417
                                          Not related to RC planes....BUT....interesting.
                                          Many of the FFS in full size aircraft (example Piper) incorporate “anti-servo” tabs on the trailing edge of the FFS to provide “resistance” to the control movement. This is done so the pilot gets “feel” feedback and thus avoids over stressing the airframe by deflecting the FFS too much.
                                          As the trailing edge of the FFS moves up, the anti-servo tab’s trailing edge also moves up. Thus....fighting the movement of the FFS. Same on the reverse movement. Downward FFS trailing edge is accompanied by the trailing edge of the anti-servo tab moving down.
                                          Bottom line, the general population of pilots needs to feel resistance to control movement.
                                          Aside - A lot of work goes into the design of hydraulic assisted systems on big aircraft to provide simulated control force feedback to the pilot for this very same reason. FFS or otherwise.
                                          For sailplanes, not wanting the drag of an anti-servo tab....engineers put springs on the FFS systems that the pilot must fight against.
                                          General population pilots might separate wings from aircraft by over Ging the airframe without pitch control pressure feel feedback.
                                          Click image for larger version  Name:	0F59F41A-EA00-4D5C-88D9-3B143EA94808.jpeg Views:	0 Size:	39.7 KB ID:	310266
