  • radfordc
    • 375
    • Lansing, KS
    If you didn't see it on RCG, here is an easy fix for gear doors that don't close. Thanks to our Belgium buddy.
    • Airguardian
      Post Stall Svengali
      • Aug 2020
      • 1676
      • Catalonia
      Interesting fix...
      • T- Elbert
        • Sep 2020
        • 98
        • Helena, Montana
        Great fix
        simple and functional
        • kallend
          • 1877
          Originally posted by kallend
          Forgot to add:
          Underwing pylons for the Gripen: https://www.thingiverse.com/thing:4713773
          • jaldendifer
            • Feb 2019
            • 14
            I discovered today my left gear not fully retracting. Had the problem before and found bind in the main gear (knee) joint which wouldn't allow full extension of gear. This time I discovered the plastic gear mount had about 2 mm of up and down play, as the factory glue is no longer holding it solid. Those who are having problems might check it.
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1676
              • Catalonia
              Aaaaand... about damn time!!
              • Airguardian
                Post Stall Svengali
                • Aug 2020
                • 1676
                • Catalonia
                Plus some more...
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1676
                  • Catalonia
                  A couple of solo flights doing TV aerobatics with smoke and the ground footage of the 'aerial photo session' with the DJI FPV ;)
                  • Airguardian
                    Post Stall Svengali
                    • Aug 2020
                    • 1676
                    • Catalonia
                    Clips without music:
                    • Airguardian
                      Post Stall Svengali
                      • Aug 2020
                      • 1676
                      • Catalonia
                      Smoke wingtip trails in slow motion are way too cool!
                      • McDaniel
                        • Jul 2021
                        • 11
                        Hey
                        to be honest I am a little pissed about this product, I bought it without due diligence, my fault. If you dont need the TV unit you are kind of screwed with the impossible CG...
                        SO what is the best way to add that stupid ballast weight? Thank you for any tips
                          • 5401
                          When I built my first one the TVs were not available yet. I knew I'd want them so in the joining area at the front of the rear half of the fuselage I made three or four 1/4" tunnels and put a few oz of lead in them. I tack glued the rear onto the fuselage and when the TV became available I gently pulled off the rear part and put the TV rear part on. It still needed a half ounce which I put under the vertical stab.
                          On #2 which I left non TV iI cut slots in the tail cone and glued lead in the slots.
                          Don't be pissed, just get it balanced (most have a balance further back than the book number) and fly it, It is a really good plane. By far my favorite one.
                          . Click image for larger version  Name:	TV new.JPG Views:	0 Size:	68.9 KB ID:	320496Click image for larger version  Name:	Gripen canard throws.jpeg Views:	0 Size:	221.3 KB ID:	320497
                          • McDaniel
                            • Jul 2021
                            • 11
                            Thank you, do you have a picture of your tunnels, so I can have a Idea where to start? I am a bit rusty with craftmanship...lol
                              • 5401
                              sorry, I did so I knew where they were but deleted the pictures after adding the TV.
                              Here is a post by someone else that did the same. RC Groups - View Single Post - Freewing 80mm JAS-39 Gripen
                              And John created a 3D printed tail cone that has spot to add weight. RC Groups - View Single Post - Freewing 80mm JAS-39 Gripen
                              • kallend
                                • 1877
                                Originally posted by McDaniel
                                Hey
                                My heavy nozzle not only looks better, it can add up to 120g of tailweight (it has slots for inserting up to 60g of lead, invisible once in place, in addition to the nozzle's own weight).
                                The Gripen needs weight in the tail to achieve an acceptable CG position. This nozzle has accommodation for up to 60g of small lead weights, in addition to weighing over 60 grams itself. Print wide-side down, with supports.You will need to peel off the plastic outer of the stock nozzle, and trim back the foam to leave a stub 13mm long to which you glue the new nozzle. I suggest taping the join on the inside to ensure smooth airflow,
                                • Airguardian
                                  Post Stall Svengali
                                  • Aug 2020
                                  • 1676
                                  • Catalonia
                                  Before the TV upgrade I had added 130g of ballast in the tail.
                                  I hid it inside the vertical stab, also on the foam right below the rudder, being careful not to protrude into the duct and also inside the nozzle on the aft end.
                                  I would recommend considering moving the EDF unit aft as much as you can. I managed to shift mine 2.5cm and that helped a lot.
                                  • McDaniel
                                    • Jul 2021
                                    • 11
                                    Thank you guys, I will try something...🤷🏻‍♂️
                                    • Roy M
                                      • Aug 2021
                                      I have read thru the forum. Looks like consensus is to move CG aft of molded markers on the bottom wing by 15 to 20mm ? I will be using roaring top lipos 4400mah.
                                        • 5401
                                        About 15 for me. Balance is balance, what battery doesn’t change the balance point.
                                        • Airguardian
                                          Post Stall Svengali
                                          • Aug 2020
                                          • 1676
                                          • Catalonia
                                          15 at a minimum. ( :
                                          I'm happier more aft.
