Mostly depends on CG.
With forward CG, canards angled down will not work good enough, you'll end up requiring a lot of elevon trim to compensate which is not ideal... in that scenario, neutral canards will likely work better. But as CG moves aft (past 25-30mm) then the down trim really begins to shine.
Is that really so?
One would think EthOS should have a way to deal with that...
I don't use it myself but will ask a friend that does to see if I can help there.
Is that really so?
. Let me know if you ever need additional input on the brand and my experience with it.
