Xfly Models B1B Bomber 70mm
    • 8228
    So the big question is what’s the new FL plane???
      • 5401
      Yeah, saw it early this morning and ordered it. Nicely done!
        • 8228
        Well Captain Dunce reporting...I examined the wings and discovered alas, I apparently did NOT install the center 16mm screws! Good lord. How on earth I missed that is beyond me! I would swear up and down I installed all 6 screws for the wings. Regardless they were missing on both wings. Mystery solved.
        I did go to screw them in and one of them started to tighten but just keeps spinning and won't tighten completely. The other won't tighten at all. Perhaps from the two flights the pin slightly bent? I'll have to investigate but I have to say I am not a big fan of allen screws. I'm thinking of getting regular screws at the same size. Thoughts?​
          • 4856
          Originally posted by Aros
          Well Captain Dunce reporting...Mystery solved...screw them in just keeps spinning, other won't tighten at all...not a fan of Allen screws, thinking of getting regular screws at the same size. Thoughts?​
          Aros, Sounds like you got it noodled, but this seems to be more than just a screw choice, though pan head screws would be what I'd swap out if I were in your position.
          Note: I bit the bullet and ordered M4 x 3mm headless grub screws on Amazium.Prim where a bag of 50 pieces is less than $7.00 USD.
          I am using those on the Corsair gear struts and have had those off about a 100 times so far with no wear or tear on the head.
          BONUS: When I drop one and it bounces, I find it later rather than sooner.
          Best, LB
            • 8228
            Thanks friend!
              • 8228
              I'll keep those in mind but for now I am going to try to see if I can't use my drill to seat those screws as they should be...I bought these...
                • 4856
                ,,,,When in doubt, I always use a 'bigger hammer'. Click image for larger version  Name:	image.png Views:	0 Size:	56.7 KB ID:	380950
                And then Mom said, "Remember, my children, only use your powers for good, not evil".
                Best, LB​
                  • 8228
                  Oh trust me, I've used a hammer when it called for a feather way more than once in this hobby!!
                  • kallend
                    • 1877
                    OK, now I have an image of you in my mind. Click image for larger version
                    • Coconut
                      • Apr 2019
                      • 212
                      That's too handsome.
                        • 4856
                        Originally posted by kallend
                        OK, now I have an image of you in my mind...
                        Hah, also looks remarkably like my ex-wife's 3rd divorce attorney. Honestly, 3 different attorneys over 33 months, but whose counting. Best, LB
                        • SanExup
                          • 912
                          • Western Wy.
                          Elbee From the sound of it, it's hard to discern whether she was trying to torture you or torture herself. That's quite the extended campaign. My condolences buddy!
                          • Gravythe clown
                            • Mar 2019
                            • 711
                            • Clovis, California
                            Well I’m picking one up on Monday. My plan is to bypass the stock gyro and put it on a S8R and use one 1-4 subs extender.
                            I may or may not ever use the gyro function in the S8R, but at least it will be there if I need.
                            My ch layout will be 1:Ail1, 2:elv, 3:throt, 4:rud, 5:ail2, 6:gear, 7:flaps, 8:ster, 9:gyr, 10:mode1, 11:mode2, 12:calib, 13:wing, 14: rev.
                            I want to play around with adding some up ailerons while wings folded back to maybe take some of the up nose up load off the elevator. I’ll put it on a switch so after I get her flying and trimmed in both wings back and out modes, I can then added it in to see if she climbs, does nothing or dives.
                            cant wait
                            Gravy
                              • 8228
                              Probably true!
                              • f4u ausie
                                • 1240
                                • Melbourne
                                Have u watched rc plane reviewer ,, had his own troubles,, like many..... looks like alot of up mix req folding wings.... shifts cg..... not req on fwi g f-14 .....?.
                                • kallend
                                  • 1877
                                  I’ll say it once more XT and EC are not compatible and if you decide to plug one into the other it’s a stupid decision. Kallend said in a pinch you can spread the pin to make a better connection but DON’T DO IT. In the picture are two types of pins used, these are both EC5 pins. The one on the left is what he’s saying to spread and yes I guess if you did it would make a connection but it’s just not designed to be used that way. I can’t believe a professor actual even suggested it. What’s next, missing that machine screw to hold your wings on, use a wood screw, it’s close enough?
                                  You'll love this bit of the video:
                                  https://youtu.be/EOez4qb07R8?t=126
                                    • 5401
                                    Look how much elevator he had to add to fly with the wings swept @19:50.
                                    • kallend
                                      • 1877
                                      No doubt due to using an EC5 with the XT90.
                                        • 5401
                                        If he added afterburners....
                                          • 8228
                                          Dang that's a lot of up mix in sweep wing mode!
                                          So even with an XT90/EC5 adapter it could overheat??
