Xfly Models B1B Bomber 70mm
  • kallend
    • 1871
    Testing the Do-It-Yourself afterburner. Four independently driven tailpipes.
    https://youtu.be/pp_Pu0bHiBQ
      • 8211
      Niiiice!
        • 2817
        • Arlington, TX
        Well, to say the least, this was not how I was hoping the maiden flight would end… Spent hours setting things up exactly per Jermey’s videos and thought I’d give the stock flight controller a shot for the maiden flight and maybe bypass it later. A word to my fellow B-1B pilots, approach flight with wings swept very carefully, and be ready to bail out of it at a moments notice.
        The aircraft was configured with a 6S 5800 battery towards the aft side of the battery compartment, balancing at intake lip per the setup video. Controls all centered mechanically, no trim or sub trim as per the videos. 2 RC geek Center burners were also installed.
        The take off was uneventful, and it flew pretty well with wings out. Maybe a bit tail heavy in that configuration, but not bad. The stock gyro was doing a good job overall. 2 normal patterns were completed before I was confident to try sweeping the wings. I swept the wings on downwind, and attempted a turn to stay in the pattern.
        This is where it all went wrong. With the wings back, I found myself at full up elevator just to maintain level flight, and heading out towards the lake at the end of the runway. I gently attempted to coax it into a turn, with a bit of elevator, aileron, and rudder, but it was bleeding altitude. I then tried to get the wings back out, but by this point it was diving out of sight behind the tree line. Found it 10 ft away from the water, just as you see on the shore.
        Pretty much everything in the nose was destroyed, including the battery and my 9 channel Spektrum receiver. The aircraft itself is pretty much a write off. Only the far aft tail section survived intact.​
          • 4826
          F106DeltaDart, a cryin' shame. my friend. Looking forward to a final debrief. Condolences, LB
            • 8211
            Yeah as I said on RCG I'm really sorry to see that F106DeltaDart. I have a 2 hour drive to the club tomorrow and I am praying the 2 hour drive back home Sunday doesn't have the back of the car look like your photo. I was just going to post here to tell folks it appears there is an issue in wing swept mode. I will absolutely NOT put mine in wing swept mode on my flights until it can be determined the cause and the solution. Sucks you had to be one of the guinea pigs my friend.
            • kallend
              • 1871
              Originally posted by Aros
              Niiiice!
              Thanks.
              A single Arduino drives each of the four tailpipes independently. With decent electronic soldering skills you can put one together in about 2 - 3 hours for under $25 for parts. It will drive pretty much any LED lamp from 8 to 25 volts. I used Yorkim amber turn signal lamps in this one.
              No charge for full instructions and the Arduino code.
                • 8211
                You're assuming I'm not a helpless monkey that runs screaming from electronic tools. LOL! It really does set it off nicely. So what's your thoughts on the wing sweep/elevator issue?
                • kallend
                  • 1871
                  Need more data. "Once is happenstance, twice is coincidence, three times is enemy action"; Goldfinger, in "Goldfinger" by Ian Fleming.
                  I'd like to hear from Jeremy.
                  Having said that, the gyro does not fill me with confidence, for reasons that I explained on another forum.
                    • 8211
                    My buddy's comments post maiden:
                    "So I flew it. Flies good, but the gyro makes it feel crazy. I was fighting it while landing. Didn't fly it again but when I do I will have the gyro turned off."
                    My EC5 to XT90 adapter doesn't arrive until tomorrow and I will be gone by then headed to the filed which is a 2-hour drive. So besides gyro off, no wing sweep, I was planning on flying with my EC5 plugged into the XT90 and adding some Gorilla Tape for insurance. Is that too risky? If so I will just wait for another time.
                    • kallend
                      • 1871
                      Unfortunately the gyro has no remote mode, on/off or gain control, so once you take off with it, you're committed. Hmmm...
                      • SanExup
                        • 912
                        • Western Wy.
                        Aros I've used tape with XT's but worry about heat and adhesion, so I've also used zip ties in between the leads to keep em together.
                        Is it not possible to swap gyros with a higher quality one with adjustable gain?
                        • T- Elbert
                          • Sep 2020
                          • 98
                          • Helena, Montana
                          Boy that’s a bummer f106, I typically am skeptical of gyros but I do use them in a few planes and they work well, the combination of gyro and system or mode configuration has made me a bit uncomfortable with this jet. I have been putting off flying it. Not very characteristic of me , I am a roll it out and go guy. when other seasoned pilots have issues with new products I pay attention. 🤔 hmm what to do…..
                            • 5393
                            XT90 and EC5 are not compatible. The pin on the XT is 4.5mm and the tube on the EC is 5.0mm. Don’t do it.
                            • SanExup
                              • 912
                              • Western Wy.
                              My mind went to the part where he mentioned an XT90 to EC adapter. I use them but I zip tie the XT to XT side together. I've seen them get sloppy loose in a short amount of time.
                                • 5393
                                I've seen people put the XT into a EC. It goes but doesn't make a good connection.
                                • kallend
                                  • 1871
                                  I use an adapter but in a pinch you can slightly spread the pins of the male XT so it makes a tighter connection with the EC.
                                    • 2693
                                    My flying buddy RudyD54 maidened his B-1 yesterday and helped me maiden my Bronze Tiger Eurofighter. I believe he put on 5 flights with the B-1. Some were a little "wonky" as he was dialing it in but did comment that when the wings are swept back, it likes to dive and full elevator hardly brings it up. He's a very accomplished pilot and an electronics guru and to me, with some odd tendencies, it seems to be challenging yet interesting to fly but definitely lands super easy at least on grass. Hopefully he'll chime in here and give more coherent comments.
                                    • RudyD54
                                      • Aug 2020
                                      • 104
                                      • Miami, FL
                                      Click image for larger version  Name:	20230623_123540.jpg Views:	4 Size:	305.2 KB ID:	380452
                                      Haha, I didn’t realize you took this pic. I’ll copy and paste what I wrote in the other forum here:
                                      After maidening mine today, I’m convinced that the gyro in the B1 is some form of heading hold gyro. It acts just like one and would explain why trimming is a bad idea and it “self trims”. It’s more like it continues in whatever direction/attitude you put it in.
                                      It took me a while to find a CG where things felt ok. For me it’s roughly a few mm forward of the picture I attached earlier where I was pointing out the intake lip.
                                      This is where wings out felt the most stable, but at the expense of a lot of elevator authority with the wings swept. Wings forward the B1 is sensitive on pitch, and requires very little throw to toss around while wings back requires full elevator input to make a rather wide banked turn. It’s an odd sensation akin to flying two completely different models. I was able to improve the wings swept pitch authority by pushing the CG back, but that created a very touchy beast with the wings out.
                                      Honestly I feel like the internal gyro is just not setup ideally for this model. It’s “adequate” and will get the job done, but I feel like it’s the product of trying to make things easy to setup as it negates trimming, multiple flight modes, gains, etc. that are required on the Freewing F-14 for example. After 5 flights, I think the wings out mode needs more expo, less travel, and much higher pitch gains, and wings swept needs more throw. These things may have already been tested, and may have not worked, but that’s the best way I can describe what improvements I think can be made.
                                      I’ve got a Spektrum AS3X receiver in there which currently has the gyro disabled but I’m going to go ahead and try using it instead, as well as using flight modes and the necessary mixes while putting the elevator channel directly to the receiver so I can get more throw.
                                      Aside from that above the plane is very cool, and I did enjoy flying it. We have thick green grass at our field this year due to the constant rain over the last month that’s not cut very low, so the takeoff roll was pretty long, I’d say about 300 feet with flaps. I may add a few more degrees to see if I can get some more lift.
                                      Landing is a breeze, she settles in nicely and glides for a while.
                                      Weather is terrible here for the next couple of weeks so it’ll probably be a while before I can get her out again but I’ll report back once I test the changes.
                                      Here’s a short vid of the maiden:
                                      https://youtu.be/MDirmOZOqDg
                                      • kallend
                                        • 1871
                                        Since it was reported elsewhere that the wingtips are weighted, I checked to see how much the CG moves when the wings are swept back.
                                        I set the CG at the 81mm mark (by the lip of the intake as shown in the set-up video) with the wings forward. When I swept the wings the CG had shifed back to 105mm, a shift of 24mm (or an inch).
                                        So just be aware that when you set up your model's CG at the 81mm mark (or wherever else you think it should be), be sure that the wings are in the right place.
                                          • 8211
                                          Good report RudyD54 thanks!
                                          I successfully maidened mine over the weekend. I'll post the video later today. I actually did connect the XT90 to the EC5. I wrapped some Gorilla Tape around the connectors and it held fine after two sorties. Although I admit it was not ideal and a bit risky. The connectors were WARM after the flights. I got my adapter so I will be using those moving forward. The maiden was decent although I forgot to retract my takeoff flaps which would explain why she felt sluggish at full throttle (smacks forehead). Landing is a breeze. You could probably dead stick her in. When I swept the wings it felt wonky a bit. Seemed to not want to track straight and bank to the left so I quickly brought the wings back out.
                                          The wings had a ridiculous dihedral so I was hoping to get someone's advice...When you mount that metal bracket piece to the pivot point mech, did you use 16mm length screws for all of them? The manual confused me...Looks like two are a 6mm and the other is 16mm? Perhaps that would explain the dihedral? Not enough "meat" going into the holes?
                                          kallend I didn't actually check my CG location manually. I simply went off the photo of my friend who was using the exact same Admiral 6000. He took a photo of it in the tray and I simply emulated that and it worked great. So I still need to find out where my CG is at for when I want to try different batteries.
                                          Here's the portion of the manual I was referring to...And get a load of that dihedral!!
