Official Freewing F9F-8 Cougar 80mm EDF Jet Thread
    • 4873
    didier n, Best, LB
    • didier n
      • Oct 2019
      • 109
      • leopoldsburg Belgium
      First flight done! Started without gyro, had to trim aileron a bit, then switched gyro on..fly s great!
      All at Beerse modelvleugels Belgium Click image for larger version
      • didier n
        • Oct 2019
        • 109
        I made 6 flight this evening, fly's absolutely great! Stock setup and gyro, i moved the CG a little bit backwards, had to push elevator a bit too much inverted to my liking, way better now. Build went ok, only the gyro corrected in the wrong way on rudder.. luckily i bought the program box as well..
        Here is a short video of the maiden flight
        Didier
        • SanExup
          • 912
          • Western Wy.
          didier n How far back did you adjust your CG?
          • didier n
            • Oct 2019
            • 109
            Just a few mm back, in total i moved my battery 10mm back during multiple flights, i think it can go even further back, but it flew fine the way it is... might experiment more when weather permits..
            • Yellowred
              • Apr 2019
              • 39
              Hi Guys, just starting to put my Cougar together, can't see what way round the plugs go in for the tail? don't want to have to take it apart as I'm bound to plug them in the wrong way, Thanks
              Ah just seen the build vid and its positive to the right of the Fuz
              • Vlam
                • Jun 2023
                My Cougar just arrived today. The Aileron,Elevator,and Rudder service plugs Only has one wire. Could someone kindly enlighten how to install. I use Futaba T16iz
                • Shemp
                  • Mar 2023
                  • 7
                  James Where do i find the esc programming manual? This one makes different beeps and there is no manual linked in the support section.
                    • 5424
                    I got a paper copy with my spare parts Esc. If they don’t have a link I can snap a picture.
                    • Coconut
                      • Apr 2019
                      • 212
                      I think the Product Update on the gyro is wrong. It says if you pitch the nose up, the gyro should correct with right rudder. Shouldn't it be down elevator?
                        • 5424
                        Picky picky...
                          • 5424
                          I see he hasn't been back but if anyone else needs it here is a picture of my paper copy.
ID:	381198Click image for larger version
                            • 5424
ID:	381201Click image for larger version
                            • Shemp
                              • Mar 2023
                              • 7
                              Click image for larger version  Name:	D5E13432-FE96-43B5-A169-3519F473E642.jpg Views:	0 Size:	122.8 KB ID:	381201Click image for larger version  Name:	46134022-B7A8-468F-B67C-3369B12FB94C.jpg Views:	0 Size:	133.3 KB ID:	381200
                              I really appreciate you taking a picture. This is the same one that i found online but it isn't quite right and doesn't match the ESC that mine came with.
                                • 5424
                                What’s different? It is what I used to change settings on the spare parts one I got.
                                • Coconut
                                  • Apr 2019
                                  • 212
                                  Do I need servo extensions if I bypass the blue box?
                                    • 5424
                                    Many. If you are bypassing the MCBe you are bypassing the ribbon cables to the wings and to the tail, you'll need extensions for the ailerons and flaps from the back side of the root ribbon connector into the fuselage plus Y's and also extensions for the elevator and rudder servos plus a Y for the elevators. And if you want to bypass the MCBe for the landing gear and lights it's a lot tougher as you'll need a sequencer and something to power the lights.
                                    • Coconut
                                      • Apr 2019
                                      • 212
                                      Hi, I was wondering the same thing and hope someone would say how. Since the wires are coming out of the gyro, I look to see if there is a set-up video on the gyro. James from Motion RC has a video on it and shows how to plug it into your receiver. Hope that helps.
                                        • 5424
                                        Didn’t you get the manual for the gyro?
                                        • Coconut
                                          • Apr 2019
                                          • 212
                                          Yep, I did. I haven't put the plane together yet and didn't even think about looking at the manual for the gyro. Come to think of it, I have two manual for the gyro because I bought the program box for the gyro if the correction is backwards.
