Official Freewing F9F-8 Cougar 80mm EDF Jet Thread
  • Swarick
    • 36
    Originally posted by Coconut
    Hi, I was wondering the same thing and hope someone would say how. Since the wires are coming out of the gyro, I look to see if there is a set-up video on the gyro. James from Motion RC has a video on it and shows how to plug it into your receiver. Hope that helps.
    That is the SIGNAL wire. You do not need the power wires as the servos are powered through the blue box.
    • EA-6B Geek
      EW Misfit
      • 485
      • South Central Ohio
      Still a few details left to work on, then she needs a coat of clear.
ID:	381532Click image for larger version
      • DCORSAIR
        • 1918
        • Selma, Ca.
        Looks great, deffinitly like that paint/livery so much better....
        • SanExup
          • 912
          • Western Wy.
          V2!
          That's a winner!
          • Swarick
            • 36
            That paint job is amazing! How long did that take and what kind of paints did you use?
            • EA-6B Geek
              EW Misfit
              • 485
              Thanks for the compliment! I use Tamiya Spray Enamel that I get at Hobby Lobby. Colors are Competition Orange, Flat White and black. Decals are from Callie (who else could it be? Thanks Callie!). After it’s all had a few days to cure nicely, I go over the whole jet with either Testors Dulcote or Gloss, makes the entire finish much more uniform. Also, I have good luck with Tamiya 6mm masking tape. This one only took about three evenings of messing around to get done, so it’s no scale contest winning paint job. But, I hope it looks the part!
              • Cape Jets
                Member- Jet Jockey
                • Dec 2020
                • 120
                • Cape Cod, MA
                Just completed the new livery on the F9F-8 Cougar. This was my second complete repaint and although I see imperfections in the air she will look great. Went with the FMS 2000Kv 6S-EDF/ 12 Blade, Castle Creations 100amp ESC, Spektrum AR 8020T Receiver ( removed gyro), Hitec HS 5065 Elevator servo's. Of course could not have done this without the help and graphics from Callie Graphics. The pictures look like she is gloss black, but she is Deep Dark Blue. Once in the sun I'm sure the Dark Blue will show better. Just waiting now to bring her to the field for her maiden.
                • Cape Jets
                  Member- Jet Jockey
                  • Dec 2020
                  • 120
                  • Cape Cod, MA
                  Just completed the new livery on the F9F-8 Cougar. This was my second complete repaint and although I see imperfections in the air she will look great. Went with the FMS 2000Kv 6S-EDF/ 12 Blade, Castle Creations 100amp ESC, Spektrum AR 8020T Receiver ( removed gyro), Hitec HS 5065 Elevator servo's. Of course could not have done this without the help and graphics from Callie Graphics. The pictures look like she is gloss black, but she is Deep Dark Blue. Once in the sun I'm sure the Dark Blue will show better. Just waiting now to bring her to the field... Click image for larger version
ID:	381850Click image for larger version
ID:	381851Click image for larger version
ID:	381852Click image for larger version
                  • SanExup
                    • 912
                    • Western Wy.
                    Cape Jets Why did you switch out the stock power system? Had you flown it stock?
                    The repaint and scheme you chose looks great! I'm digging the repainted versions, thoigh i do like the classic stock paint scheme as well.
                    • Cape Jets
                      Member- Jet Jockey
                      • Dec 2020
                      • 120
                      • Cape Cod, MA
                      Did not switch out stock EDF power. Got my Cougar as an ARF-Plus and installed my own EDF and ESC.
                      • EA-6B Geek
                        EW Misfit
                        • 485
                        That looks really cool! Go Marines!!
                        • Ron1950
                          Retired ATC
                          • Oct 2015
                          • 887
                          • brandon ms
                          great paint job i really like the navy blue.. now to be like a real marine plane you have to beat the hell out of it like it would be before the navy gives it to them lol
                          • 3rdtime
                            • Nov 2020
                            Flew the Cougar this morning for first time what a great plane. Looks nice on the ground and in the air. My new favorite plane. Good job Motion on a sweet plane.
                              • 5385
                              Congrats and welcome to the forum!
                              • Cape Jets
                                Member- Jet Jockey
                                • Dec 2020
                                • 120
                                • Cape Cod, MA
                                Had the maiden flights of my new F9F-8 Cougar today. Put in 3 good flights and 1 flight with all the tanks and missile's on board. Only needed some small trim on the elevator and she flew great. Great flying plane and Dark Blue looks really cool in the sky. I look forward to flying her more this season.
ID:	382215Click image for larger version
ID:	382216Click image for larger version
                                • Yellowred
                                  • Apr 2019
                                  • 39
                                  Hi Guys Does it need half flap for take off ? Im flying off shortish cut grass, thanks
                                  • Alastair67
                                    • Jul 2019
                                    • 11
                                    • New Plymouth, New Zealand
                                    I maidened without flaps - rotated easily off well manicured grass.
                                    • EA-6B Geek
                                      EW Misfit
                                      • 485
                                      Maidened today plus 1. What is everyone’s opinion so far on landing flaps? How about flaps up landing? Just looking for some feedback.
                                      • orcabeattie
                                        • Jul 2023
                                        • 2
                                        Results of Maiden flight. I am an 20 year experienced R/C flyer, flew on a calm day, all controls checked ok. Some straight ahead taxi hops. Red light on the gyro (first aircraft with a gyro), and it sounded like the gyro was controlling the Servos , but I did not see much displacement. The Cougar climbed straight ahead normally to about 20’, started a slow roll to the left, then slowly dived into the mud. Not a snap roll on takeoff. I have sent a message to Motion about the gyro, everything else seemed ok
                                        • paulrkytek
                                          • Jun 2019
                                          • 526
                                          • North of England
                                          Did you have the Gyro on a 3 position switch, on, off and auto balance. Before you flew did you switch it to auto balance which would have given you the maximum amount of movement and then checked the direction of movement on each surface e.g. holding plane with nose in front of you, lift up left wing to vertical and left aileron goes up plenty. . Lift up tail relative to nose and elevator goes up, hold nose still and move tail to your right, rudder goes to right. If all checked out then you flick switch to gyro on and you SHOULD get small movements only. Flick switch to off then no movement or sound from gyro or servos. If you did not do this before you flew then you are assuming that the factory got it right, but they DO NOT ALWAYS GET IT RIGHT.? If you check the Motion r.c. assembly and setup videos I think they advise people to check all controls out before flight. If you did all this then its back to the traditional check the radio, range check, servo checks etc. If all that checks out then you may not have got up enough air speed before lift off and it stalled in to the left. Sorry if these points seem to be obvious to you but I am just exploring the possibilities.
