  • f4u ausie
    Firstly. Need to replace my ar631 Rx because I pull the 1 wire thru the fuse behind the latch then glue .. a mistake.. after near disaster.. was about to rotate and lost power,,around 25 meters from me... After range check. Discovering the 1 wire on rx had pulled out of itself.. lucky,, was b4 rotation...
    I'm sure that happened. With flex in the fuse.. ifit was not glued it would not have pulled out.. anyway will replace. It. Sooo. Thinking about flaperons and tailerons.
    Hope I got the correct names?? Will b a first setup 4 me like this ..and getting out of my comfort zone.. so can I do it with 6 channel Rx. Or is 8 req. I'm using an nx7 which has been upgraded for plus Rx s. Here is the best part. I have no god damb idea how to do it.. make it simple cause I'm stupid
    And will it fly differently. And land slower :face_with_monocle: boy thatwas an effort on my fone. Thanx
    Originally posted by urrl
    Morning flights
    Nothing like some greasers in the morning! Well done.
    Just flew mine the other day. Great flyer!
  • urrl
    Thanks LB. Happy New Year to you
    urrl,
    Nice morning ops, Sir.
    Great lookin' Viper.
    Best and Happy New Year, LB
  • urrl
    Morning flights
  • f4u ausie
    Just bit of a report... After nearly crashing :: turning to final.. the 1100 grams of HRB was to heavy 🪨.. did fly very well... Went back to 6s for a bit, but struggling to get off the grass.. also to fly well on 6 U need alot of throttle.
    . Sooo. 2 HRB 4000 4 s and back in with the 8s fan.. vwalla magic.... They way 800 grams big difference...
    Great balance of power and weight.. and flys well at 50 percent throttle a safe new year to all
    Originally posted by Cbldog6
    Correction on inputs…. 0-100, not -100 to 100.
    That's where the difference is when using Spektrum. "0" is a mid-point on a switch travel. If it's at position "0", it doesn't really know which way to go. It could stay on forward or reverse, depending on where it started when the battery is plugged in. The danger being that while flying, position "0" is confusing for a Spektrum set up where it needs to see the far ends of the range (IE, -100 or +100), thus having the possibility of going the other way. It would be horrible for it to go into reverse while flying with no way to bring it back to forward. The only option would be to shut down the throttle and dead stick it in.
    Good thing you confined your search to your radio system.
  • Cbldog6
  • Cbldog6
    So…. Concerning my issues with reverse thrust, Xviper was attempting to give me direction/help on a couple weeks ago…. Finally after ?x’s hours, it’s working. Hopefully this may help someone else running Freewing f16 v2 8S with TX16S to ER8 rx. It was a combination of being brand new to the hobby/life, a flat learning curve, and NO idea how to achieve what I wanted other than all in determination to figure it out. There were no instructions anywhere, believe me. MotionRC gave me a YouTube video to set up the initial 2 channels, but I had that figured out already. So, the programming literature I had for the ESC read option 3 on programming for reverse thrust but was actually option 4. Once that was finally established and learning Morse code for the Tx programming , lol, I saw a small glimmer of possibility. The channel set up wasn’t bad. It was channel 3 throttle with -100 to 100 with the same for reverse set on channel 7 (for me) -100 to 100 and assigned to (SH) momentary switch . The mix was an issue with no trim on channel 3, but channel 7 had to have -78 trim!!!!! It was the key to tell the ESC that it’s supposed to reverse when momentary switch was activated. Time well invested, a headache or 3, and a 6c battery I took below 2.8v was the cost, but worth it. Hopefully this can help someone else using TX16S.
  • f4u ausie
    Airgardian. Is your F16 6 or 8s. Great flying.. I expect U have the cg back???
  • Cbldog6
    Xviper…. Thanks much!
    You make my flying style look like a grandma by comparison, LOL.
  • Airguardian
    Pushing the F-16 pretty hard on this one... if you want to see what this jet is actually capable of in post-stall, don't miss it out!
  • Cbldog6
    So, upon further investigation, the ESC for my f16 is programmed at the factory and shipped with the reverse thrust off. They don’t make a programmer for this reverse thrust ESC so I’ll have to attempt it with the radio. I get some may not need it but then in those cases, just leave the reverse lead unplugged. If it were easy…..
    Thanks for the help for this noob, everyone.
    As I suspected. Getting a manual for this ESC is very simple. All I did was go to the "support" tab in the MotionRC webpage for this plane. All you need to know about programming the ESC using the TX and beep tones. It's a PDF file.
    Buy Freewing F-16 V2 Ultra Performance 8S 90mm EDF Jet - PNP online at Motion RC. Order online with fast delivery.
    Try this:
  • Cbldog6
  • f4u ausie
    Or if U goina run off grass u don't need reverse mine stopps nicely. With out it
    Try reducing the travel on your channel 7.
  • Cbldog6
    Thanks again. Very much appreciated!
    At least now, someone with Radiomaster knowledge can come along and look at those details and possibly see where a fault might be. I'm a Spektrum guy and those points are the things I can think of to check but how these points need to be analyzed are likely different for your radio than for Spektrum. My only other thought on this topic has to do with the ESC. It is possible that in the ESC programming parameters, the reverse brake attributes was not set from the factory and you must go into it and define the reverse in that step.
    I had a similar issue years ago but it was with a twin ESC and Spektrum. Reverse only worked once just like in your case but in my case, it switched over to the other ESC and stopped recognizing the first ESC. I have one Radiomaster radio but it was pre-programmed for a RTF plane. Even still, that radio system completely confuses me.
    There are a few Radiomaster guys here. Hopefully one of them sees your question.
