Official Freewing 110mm F-35C Lightning II Super Scale EDF Jet Thread
  • f4u ausie
    • 1240
    • Melbourne
    Throttle trim???
    • NickTesla
      • Aug 2024
      • 2
      Originally posted by NickTesla
      Friends!
      I assembled F-35 today. But it was a disappointment to fail to set up the ESC / Throttle control. I use Spektrum receiver AR10100T with satelite and Spektrum Transmitter.
      So when I bind everything works, except the throttle. Plus it keeps emmiting beep tones as you power on.
      I tried everything: all the possible combination of throttle stick, throttle cut and reverse. I replaced with another receiver, add a new model from scratch . Nothing works so far.
      Do you have any ideas what could possible go wrong? The pity side is .. I can't find a manual for this ESC.
      Cheers
      I have fixed it! Let me share, if someone faces it. So, as you know the throttle wire has an Y split: one goes to ESC, another to the afterburner light. It looks like someone in factory connected the afterburner lead in wrong polarity! I flipped it and everything went smoothly!
      • Giovanbattista
        • Sep 2026
        • 7
        Bene ottimo a sapersi mi fa piacere per te e ti ringrazio per quando avrò il mio f 35 grazie ciaoo
